Cinderblock Foundation Reaplacing Posts
Old 02-21-2009, 10:22 AM   #1
PrecisionCandR's Avatar
Trade: Carpenter/General Contractor
i have a client that has an addition on the side of his house thats about 6 feet off the ground but its just held up with some 4x6's and he would like to get rid of those and replace it with a cinderblock foundation... now im not gonna do the work im going to sub it out but i just want to know the right way to go about doing this so A. i dont sound like an idiot and B. i know the job is getting done right... also uderneath it is all pavement and the room is about 16x16' with one wall connected to the house and its poured concrete foundation.... so a step by step on how the proper way to do it would be great so i can talk to some masons and talk to the home own sounds like i know what im talking about
thanks!
PrecisionCandR is offline
Old 02-21-2009, 11:30 AM   #2
Re: Cinderblock Foundation Reaplacing Posts
First, use concrete block instead
of cinder block or haydite.
neolitic is offline
Old 02-21-2009, 11:38 AM   #3
KemoSabe
loneframer's Avatar
thanks!
I can help with supporting the structure. saw housemovers do this. get a steel I beam, maybe w8 by 26 lb.per foot long enough to extend 6-8 feet beyond both sides assuming floor joists are perpendicular to poured wall. build cribbing with 4' 6x6s close to where I beam will touch underside of floor joists in a box design, Lincoln log style. Slip a 6x6 in between an open slot low enough to get a bottle jack under the I beam. Jack the beam up to point of resistance and shim snugly from top of cribbing. Make sure you leave room to excavate footing. If you hold the beam back about 30" from the front wall, the mason can bring his corners and front wall up to a point were you can support load and lose the beam.
loneframer is offline
Old 02-21-2009, 09:56 PM   #4
Thanks for the advise guys! For something like this in MA do they need to do a footing 4' down which is the frost line around here?
Old 02-23-2009, 08:57 PM   #5
menber
masonking02's Avatar
Trade: bricklaying
il think so unless theres already exiting courses of block laid for your mason's to build off of
masonking02 is offline
Ideas for a foundation and framing D.A.S.Anthony Construction 17 01-26-2009 01:47 PM
cut an opening in foundation Martydukes Masonry 18 10-04-2008 01:18 AM
Anyone have experience with Thoroseal to waterproof bsmt foundation? Jim S. Construction 1 08-26-2008 11:53 AM
How To - Finding New Posts Nathan Contractor Talk Tutorials - How To Use This Site 12 05-09-2008 12:59 AM
