Onarooftop
Trade: Roofing
Chimneys
Hi everyone. I own a rooifing company. More times than not when we go to do a residential shingle job, the chimney could use some TLC. What are some steps that I can take to help the chimney out while we are their doing the roof.
We always step-flash, and counterflash the chimneys and then use a polyurethane sealant like Np1 to seal where the reglet is. What about stuff like sealing the chimney with a clear coating. Using a rubber like coating on the top of the chimney (I think called the crown). Grinding out loose mortar and re-pointing. Things along those lines. Also, what brands of these products are the best to use. Proffesional Grade? Thanks, Onarooftop
Trade: masonry
Re: Chimneys
all of the above.
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
Re: Chimneys![]() |
Trade: Roofing Contractor
Re: Chimneys
Jon,
Would that Masonry Concrete product usage be considered the same as a minor tuck-pointing job, as far as a professional description of the work to be ensued? I have seen other brands, which have similar names, but all in allm they are just the same as poluurethane sealants with a gritty texture, such as Mameco/Vulkem Sealant. So, by applying what basically is a caulking, albeit a high quality product, would that be considered tuck-pointing, or qwould a different name be associated with that particular task? Thanks, Ed
Please Stay Tuned For A Very Important Message From Our Sponsor http://www.rightwayroofingcompany.com/ www.rightwayroofingcompany.com Roof Estimates, Roof Repairs, Roofers, Roof Leak Help, Elgin, Carpentersville, East Dundee, West Dundee, Sleepy Hollow, Algonquin, South Elgin, Huntley, Lake In The Hills, Illinois |
#5 | |
Re: Chimneys
I think its more, putting a bandaid on a surface wound as opposed to something that needs a tourniquet.
Re: Chimneys
More like cutting off your arm for a bruised finger.
Ed, that would be like me advising someone with damaged shingles to just spread some roofing mastic around on the area. To the original poster, it would be providing an added value to be able to competently repair chimneys while you are up there. That would include tuckpointing, sealing, and repairing/repouring crowns and installing chimney caps.
It ain't Rocket Science unless you are building rockets. |
#7 | |
Re: ChimneysQuote:
Personally, I would not call that tuck-pointing, but I wanted to see if that was anyone elses envisionment of a minor repair. Ed
Re: Chimneys
There is a short term benefit, with long term problems caused by it's use.
Re: Chimneys
What would be the problems associated with its use?
I will guess at one or two that I figure would make sense to me. When a true professional goes there in the future to point it correctly, the diamond blade will burn through the polyurethane sealant. Also, moisture which should evenly flow over the exterior would possibly be diverted in behind the sealant and cause additional shaling and moisture permeation. Further damage may not become evident, due to the concealment of the original problems that were obvious in the first place. Any more than that and am somewhat on target or way off base? Ed
Trade: masonry
Re: Chimneys
most of the chimneys I come across tuckpointing is just like putting a bandaid over it as well.
Many times the whole thing needs to be tore down because the brick are pretty much rotted right through for the better part of the chimney. Even there are spots on the chimney where the bricks face is popping or crumbling off, its more than likely best to rebuild it in my opinion.
Kamps Masonry & Concrete Countertop Design Green Bay, WI 920-680-3195 Visit our website @ http://www.concretecountertopsdesign.com/ |
Re: Chimneys
6 String has it. It is not so much that that caulk doesn't work, it is just that it doesn't fix the problem that caused the symptom that the caulk is used to treat.
Re: Chimneys
What are your guys opinions on applying a sealer on the exterior surface, not as a repair solution for what we were talking about previously, but as a bit of potential preventative maintenance?
Also, which product that is readily available would be appropriate? I subscribe to the Copperfield catalog, so am familiar with their line of products. I am asking, because I have heard both pro's and con's regarding trapping in moisture in the masonry structure. Would the crown need a sealer, which i would tend to think is an obvious Yes, bit what do I know? Ed
Re: Chimneys
You use a sealer that won't trap moisture. There are plenty, I prefer Chemprobe PrimApell 200 for hard brick and stone, and Sure Clean Siloxane PD for porous.
Onarooftop
Trade: Roofing
Re: Chimneys
THANKS,
Let's say I did all of what I said and installed a chimney cap. What would you charge for a service like that in your area? |
Re: Chimneys
OnaRoofTop,
I don't think the question,"What Would They Charge" is pertinent. I think you should determine what it would cost you to do it, how much overhead and profit you need from it and finally, what would the value of that additional service be for the home owner if it was provided for them. The few masons that have replied so far, really know their stuff and probably price accordingly to their trade skills and reputation. As a newcomer, you have both a negative and a positive working for you. A. You have no masonry experience to fall back on and refer to. but B. Once you have gained the confidence of the customer you have a contract with, they will more assuredly go along with your suggestions. Use B. to your advantage and offer a premium service, even if you have to hire the best and most expensive mason in your area to provide the skills worthy of those fees. Ed
Trade: Stonemasonry
Re: Chimneys I'm just impressed that you know the work "reglet".
Bill Baddorf Bill@artisanstoneworks.net www.artisanstoneworks.net www.stonefoundation.org |
Re: Chimneys
aka "Raggle Joint" too.
I stayed at a Hloiday Inn Express and instead of the Gideons Bible, they had the Masonry Bible. Ed
#18 |
Trade: stone masonry contractor
Re: Chimneys
reglet flashing without a good sealer is useless
#19 | |
Trade: masonry
Re: ChimneysQuote:
| Please help me with my confidence | GoodPainter | Painting & Finish Work | 21 | 08-22-2006 07:01 AM |
| Chimney | boardslinger | Construction | 4 | 01-08-2006 10:08 PM |
