Cement Board Outside
Old 06-10-2010, 08:35 AM   #1
Box Builder
Morning Wood's Avatar
Rewards Points: 8,612
I'm on a job where we are covering the outside of the foundation with rigid foam. The plan is to put 1/2" cement board over the foam and stucco directly onto the cement board. I'm wondering if there is a better approach rather then using cement board. the cement board does run below grade, so I'd rather not use ply and wire mesh as I don't think it will hold up. But, since cement board isn't tested for exterior use I'm wondering if the temperature differences outside will break it down? anyone have any thoughts or a better idea all together? Thanks, Nick.
Morning Wood is online now
Old 06-10-2010, 08:59 PM   #2
Tscarborough's Avatar
Rewards Points: 1,392
Re: Cement Board Outside
We do not use foam below grade here, but assuming it is OK for that application, I would terminate it and seal the top at 4" above grade and then do EIFS above.
Tscarborough is offline
Old 06-10-2010, 09:02 PM   #3
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
What brand CBU? Some are exterior rated, like Durock.
Angus
angus242 is offline
Old 06-10-2010, 09:31 PM   #4
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
I've woked on buildings that were felt papered over studs, wired and stuccoed. They are at least 15 years old and still look good. Maybe just wire over the foam, attached well to the foundation wall and do it up.
loneframer is offline
Old 06-10-2010, 09:37 PM   #5
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
what about large rolls of fibreglass mesh, we use it all the time at grade for the icf foundations we do.
a while back i was on an addition where the foundation stepped down to grade on the addition however the main part of the house had a 7ft concrete wall above grade. because of the stepped foundation we sticke framed the walls then sheathed it with concrete board, after that it was parged. i never heard anything of this working or not working though
woodworkbykirk is offline
Old 06-11-2010, 07:09 AM   #6
Box Builder
I'm not into stuccoing right over the foam because it is so fragile. It could get damaged pretty easy. I am using durock cement board. I know Hardi board isn't designed for exterior use.
Old 06-11-2010, 07:58 AM   #7
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Raise the grade to cover the part you need to stucco. What is the siding on the above grade portion of the building?
cleveman is offline
Old 06-11-2010, 09:32 AM   #8
Designer/Contractor
Rio's Avatar
Rewards Points: 740
It's not a good idea to use a product in an environment where it hasn't been tested or approved. Find out what type of cement board Angus mentioned and use that if you go forward.
In addition to suggestions here, drive around your area and see if anyone else is doing a similar project. They might have some good advice.
Go to your local building department and see if they have any standard construction details for your situation.
Contact manufacturers and see what they have to say.
Rio is offline
Old 02-25-2011, 04:02 AM   #9
GreenDesignBuil's Avatar
Trade: Design / Build, General
I'm unclear what the issue is. Is it moisture or temperature that's the concern? You can bond to ply-cem for "stucco" by first painting with diluted Concrete glue. You need to mesh tape the seems first before the glue. Then when dry, apply a slurry mix of grout. Yep, I said grout. Doesn't need to be thick. Just evenly covered. Think of that as your scratch coat. You can do that with a heavy nap paint roller too. Then you can trowel stucco as you need.
GreenDesignBuil is offline
Transitioning drywall with cement board Lone Wrencher Drywall 22 10-29-2013 09:59 PM
Veneer Stone on Cement Board? bstormes Masonry 15 09-25-2013 09:55 PM
cement board &shcullter system bbgcarpentry Drywall 15 04-07-2010 05:11 PM
stucco cement board Paulie Windows, Siding and Doors 3 12-03-2009 04:28 PM
cement board siding issues jcgranville Windows, Siding and Doors 9 09-26-2009 08:54 PM
