Candle Wax On Concrete Steps
Old 07-31-2006, 11:22 PM   #1
balanceact's Avatar
I've been tuning up a house to sell for a good client and we are both kind of stumped on how to remove candle wax that a tenant let puddle into the back steps. It's been there for a couple of years at least..
Any suggestions appreciated,
balanceact
balanceact is offline
Old 07-31-2006, 11:34 PM   #2
Moderator
Double-A's Avatar
Re: Candle Wax On Concrete Steps
That's a good question.
I used to use combine wax and acetone and use it on a rag to wipe down our machines to coat the metal and seal out moisture.
New York Times, July 20, 2006
Double-A is offline
Old 07-31-2006, 11:53 PM   #3
Tom R's Avatar
Set it on fire and belt-sand it clean??
Tom R is online now
Old 08-01-2006, 12:15 AM   #4
My custom title
Brushslingers's Avatar
This should work for ya, newpaper and a hot iron. put a few sheets of newpaper on the step and heat it up. I've done the same thing on carpet.. works like a charm.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 08-01-2006, 01:03 AM   #5
balanceact's Avatar
Double A - Maybe some acetone or other sovent might help get it out.
Tom - Setting it on fire isn't a bad idea but belt sanding would kind of change the look of the surface which is rather rough textured like stucco or mortar. Personally I'd like to take a jack hammer to the whole mess and replace them with wood but this wouldn't be worth the investment with this particular house going on the market.
Brushslingers - Your newspaper and iron is a great idea and if it doesn't work it won't make it any worse.
Thanks All for your suggestions,
balanceact
Old 08-01-2006, 06:56 PM   #6
General Contractor
RobertF's Avatar
I got some off a concrete counter using a putty knife, a torch and a pile of mechanics rags.
Scraped off as much as I could, then alternated between the torch and the rags to dab it up. Worked allright, IIRC I had to use a wire brush for a final cleaning.
-Robert F
RobertF is offline
Old 08-20-2006, 10:52 AM   #7
jmon12's Avatar
Trade: concrete contractor
have you tried using real hot water and pouring it on the wax, it may melt the wax for easy cleanup and not harm the crete.
Jeremy
jmon12 is offline
Old 08-20-2006, 11:56 AM   #8
Teetorbilt's Avatar
I'm lurking. I have a similar problem except it's on the side of a house that will be painted soon. I was planning to wet blast, It might be a viable idea here too.
Albert Einstein
Teetorbilt is offline
Old 08-20-2006, 03:55 PM   #9
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
What I've done before was to use my soldering iron and solder sucker. Takes a little time if there's alot of wax and not very friendly to the soldering iron tip, but it worked for me.
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 08-20-2006, 04:08 PM   #10
mdshunk's Avatar
What about those little steam cleaners that they're advertising to clean your bathrooms and kitchen countertops?
http://www.amazon.com/Eureka-350A/dp/B00005QX42
mdshunk is offline
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Concrete home denick Concrete & Paving 5 03-06-2007 04:32 PM
resurface concrete steps haskl33 Masonry 0 10-04-2006 10:13 PM
Rusty steps Eric S General Discussion 1 08-27-2006 06:53 PM
