Building A Fireplace And Need Some Input
Old 08-26-2008, 08:42 PM   #1
FrankK
kammerfrank's Avatar
Trade: Masonry
Hi,
I have built many fireplaces and have been doing masonry all of my life. I am now working on a project that consists a VERY large fireplace. The firebox opening is 12 ft wide and 5 1/2 ft tall and 5 ft deep. Do I have to install a damper or can I just use flue top damper.
kammerfrank is offline
Old 08-26-2008, 09:06 PM   #2
stacker's Avatar
Trade: masonry
Re: Building A Fireplace And Need Some Input
unless you want all the furniture in the room sucked up the chimney,i wouldnt worry about a damper.
stacker is offline
Old 08-26-2008, 09:40 PM   #3
FrankK
Trade: Masonry
Hey Stacker,
How far do you think I should roll the back wall in for a smoke shelf, Im starting the back slant at approx 3 1/2 ft high.
Old 08-26-2008, 09:54 PM   #4
FrankK
Trade: Masonry
Hey Stacker,
How far do you think I should roll the back wall in for a smoke shelf. I'm starting at about 3 1/2 ft. high.
Old 08-26-2008, 10:00 PM   #5
raskolnikov's Avatar
Trade: masonry
kammerfrank,
5 feet deep! Is it a firebox or an elevator shaft? Just curious how large/tall the room is that's housing this monster?
Duane
raskolnikov is offline
Old 08-26-2008, 10:08 PM   #6
FrankK
Trade: Masonry
2 stories. Event hall with 18 ft ceilings. 300 ft long and 90 ft wide.
Old 08-26-2008, 10:11 PM   #7
jaymasonry's Avatar
Trade: Masonry in St. Louis
sure would like to see some photos of that
Yeah thats me holding up a burrito from taco bell in a pittsburgh hotel lobby at midnight.
jaymasonry is offline
Old 08-26-2008, 10:36 PM   #8
Trade: masonry
Don't get me wrong, I was just thinking asthetics along with it working too. How many times have we all seen these massive fireplaces in a small room where they overpower the space and one finds the flue to be an 8x12 or maybe even a 12x12! And kammerfrank, this is not a dig, I just saw the size of the box and thought...
D.
Old 08-26-2008, 10:54 PM   #9
FrankK
Trade: Masonry
I have been racking my brains about flue liners. My thoughts were 2 2x2's but thats too large.
Old 08-26-2008, 11:07 PM   #10
Trade: masonry
kammerfrank,
I don't think that's even close to too large! What will the finish height be on this "quaint stack" from the floor of the smoke chamber to the lights for low flying aircraft? Really!
D.
Old 08-26-2008, 11:09 PM   #11
FrankK
Trade: Masonry
finished height will be 40 ft.
Old 08-26-2008, 11:22 PM   #12
Trade: masonry
IMHO you can get away with 2 2x2 'cept I think you need to pull the depth of the firebox to 30" or mayby 36". Is this supposed to be a working box or just for show??? Show would be better based on what I see from your post.
D.
Old 08-26-2008, 11:49 PM   #13
Tscarborough's Avatar
Considering the fact that you will need 2 ea 48" dampers and they call for at least a 13x18 flue ea, I would think you will need a double stack of 13x18 flues. The height will help. We lived in a house with a 10'x'5'x 3' deep fireplace and actually burned old RR ties. It was built in the 30's and was double dampered and had 2 separate chimineys. Use this to extrapolate the correct dimensions for your fireplace:
http://vestalmfg.com/PDF/FireplaceThroatDampers.pdf
Tscarborough is offline
Old 08-27-2008, 09:31 AM   #14
jvcstone's Avatar
Trade: Masonry / architectural stone carving
To get enough flue area, you could build the flue the old fashioned way with out liners. Double wyth of common brick parged inside and out. Other wise, it will need two conventional flues.
JVC
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Old 08-27-2008, 09:11 PM   #15
FrankK
Trade: Masonry
10% of the fireplace opening is 950 sq.". 2 2x2 flue liners give me 882 sq ". I am shy 68 sq.". Do you think it will draw? Any suggestions?
Old 08-27-2008, 10:20 PM   #16
Trade: masonry
k.
I wouldn't use smaller than 2x2s and 2 is probably enough with the height you have. Always error in the favor of bigger is better!
D.
Old 08-27-2008, 10:54 PM   #17
A forty foot stack will suck like Pamela Anderson on a boat.
Old 08-28-2008, 09:56 PM   #18
Trade: masonry
I guess that in ten years or so that fireplace won't suck at all based on that piece of info!
D.
Old 08-28-2008, 11:18 PM   #19
She is sucking now more than ever.....
