Building Curved Brick/block Walls
Old 07-09-2009, 09:49 PM   #1
INTRA's Avatar
Trade: Masonry
Rewards Points: 75
Just wanted to know how you guys build a radius masonry walls. For an example a front entrance way wing-walls Maybe 12' -15' in length with a 4"- 6" radius.. I always just build them using a level one course at a time or 3' at a time. Just curious if you guys have a faster way of building them. Like setting up using some kind of masonry poles for radius work, so it can be done with a line, not just a level to save time.
INTRA is offline
Old 07-09-2009, 10:33 PM   #2
mason
DQM's Avatar
Trade: Mason contractor
Rewards Points: 77
Re: Building Curved Brick/block Walls
I do it just like you .I know of no other way
DQM is offline
Old 07-09-2009, 11:17 PM   #3
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
You guys want to have fun and be done quicker?
Depending on the wall finish look at ICF, once the first two courses are done the rest of the wall just follows.
Radius are really easy
Chris
Chris Johnson is offline
Old 07-10-2009, 03:33 PM   #4
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
I level the entire wall with a 4' level but for plumbing the wall I pick a few plumb points and make a template out of plywood. Usually takes two bricklayers this way though because I like the template to be around 8'-10' long (depending on wall length). Plumb at your points and adjust the brick in or out to the template.
NJ Brickie is offline
Old 07-10-2009, 04:16 PM   #5
3-D Mason's Avatar
Trade: masonry...
Rewards Points: 25
ditto
3-D Mason is offline
Old 07-10-2009, 08:44 PM   #6
stacker's Avatar
Trade: masonry
Rewards Points: 542
i am working on an outdoor fireplace/kitchen.the outside wall is about 40' semi circle,15 courses high.i laid it 10 brick at a time,racking back and plumbing in several spots.took a couple days to get the outside wall done.after that the inside wall was easy,as i followed the outside wall for level and measured the keep the wall plumb.
stacker is offline
Old 07-11-2009, 06:03 AM   #7
artisanstone's Avatar
Trade: Stonemasonry
Rewards Points: 592
On a small radius, you can set up a trammel rod. Basically a piece of pipe, plumbed and braced, and an arm that can swivel from it.
artisanstone is offline
Old 07-12-2009, 09:30 PM   #8
cdkyle's Avatar
Trade: Concrete & General Construction
Location: The Heartland of the United States of America
Rewards Points: 466
I always used a radii line, really hard to find though. Look at your local supply store. Should be around the sky hook department.
cdkyle is offline
Old 07-13-2009, 05:56 AM   #9
tkle's Avatar
I keep mine in my hubcaps to keep the radius.
Ends and middles.Plumb the ends on one course, the middles on the next.
tkle is offline
Old 07-14-2009, 06:45 PM   #10
INTRA's Avatar
Trade: Masonry
Rewards Points: 75
Looks like the old fashion way I was taught is still a common practice. Thanks for your sharing ur practices
INTRA is offline
Demolition Specifications for Old Brick Building Bill Z Excavation & Site Work 4 01-15-2010 08:42 AM
Underground in building low voltage OhioTelecom NEC Discussion 4 03-22-2009 02:22 PM
Tall walls (2-storey walls) Zoltar Framing 21 03-11-2009 12:00 AM
metal building condensation 21sapptk General Discussion 6 12-25-2008 07:31 PM
Commercial Building Renovation Questions cacwgrlc General Discussion 13 11-22-2008 03:37 PM
