Brick Veneer Support Over Large Opening.
Old 07-31-2007, 02:41 PM   #1
Atlantex's Avatar
Trade: Residential Development
I'm a new designer for a residential developer and I've come across a seemingly basic question that I'm having trouble answering. I'm designing a 2-story home with a 2 car garage. The house has a standard brick veneer and per IRC2003 R703.7.3 veneer above openings shall be supported on lintels with the spans given in table R703.7.3. According to the table the largest span of a lintel with one story of brick veneer above is 12'-0". This has me confused because a standard two-car garage door is 16'+. So how does one support the veneer above the garage door? This seems like such a common issue that the code should reference it rather than requiring that a solution be engineered.
Looking at R703.7.2.1 there is no maximum span for supporting the veneer on a steel angle but I'm wondering if this applies it does not reference openings.
If there's anything that I can clarify please let me know. Otherwise, thank you in advance for any assistance or suggestions you can provide.
Atlantex is offline
Old 07-31-2007, 02:49 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Brick Veneer Support Over Large Opening.
Educated guess on what I have had in the past is a 12" steel I beam w another piece of flat steel welded to it this serves as the door header and can carry the load of the brick
Chris
Chris Johnson is offline
Old 07-31-2007, 04:58 PM   #3
stacker's Avatar
Trade: masonry
what i have done in the past is angle iron over the opening extending 8 inches over onto the brick(each side of opening).lag bolt it into your header about every two feet.set jack legs under it in a few spots where sagging is for sure to happen.and lay your brick.i know this may not be to code,but i have yet to have any problems.
good luck
stacker is offline
Old 07-31-2007, 05:45 PM   #4
Atlantex's Avatar
good luck
Thank you for the suggestion. At this point my primary concern is designing to code so I can get the plans approved and the permit issued. I'm just amazed that I can't seem to find anything in the IRC2003, the 2004 Supplement to the IRC2003, the IRC2003 Commentary, or the IBC2003 that discusses supporting a veneer over a span as large as a garage door where there is a story above the garage. The IRC (R703.7.3) states that the allowable span is 20' using a 2'-6"x3.5"x5/16" steel angle, but this applies only when there is no story above. When there IS a story above the span drops to 12'-0" which is 4' short of what I need.
I'm thinking I must be missing something in the code. However, I have found that an action was brought to the ICC to amend the code to add a design method for spans over large openings, including two car garage doors, up to 18'-3". Unfortunately the amendment was rejected on the basis that the language needed clarification and the span should be increased to 18'-6" so it has yet to be included in the IRC and thus I cannot build to these specifications until it is adopted, likely as a revision to the IRC2006. In the mean time I'm stumped.
Atlantex is offline
Old 07-31-2007, 06:31 PM   #5
Tscarborough's Avatar
You may have to do it via calculation. Go to BIA.org and look under Technical notes for Tech Note 31B. That should at least give you a basis on which to base your design, and a reference source to help with approval.
Tscarborough is online now
Old 08-06-2007, 03:14 PM   #6
RAY MERCHANT's Avatar
Trade: R.T.W BRICK & BLOCK WORK
STACKER IS 100 % RIGHT!
RAY MERCHANT is offline
Old 08-08-2007, 04:09 PM   #7
Bigbricklayer's Avatar
Trade: Masonry
The first pic we did the method Stacker mentioned 3"x4" angle iron lagged into the header. The second pic has a bit of an arch to it but we don't use an angle iron at all on those.
Brick Veneer support over large opening.-pictures-off-digital-camera-054-small-.jpg   Brick Veneer support over large opening.-pictures-off-digital-camera-065-small-.jpg
Bigbricklayer is offline
Old 08-13-2007, 11:12 PM   #8
lukachuki's Avatar
Interesting combination of brick and stone. I like HO's who have the guts to go for something out of the ordinary.
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln-
Less with the jaw more with the paw!
lukachuki is offline
Old 08-14-2007, 12:02 AM   #9
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
I'm a Gen in the Bay area,All our projects Must have Eng stamp. Also I do struct.welding. Because of our seismic location we must build strong.
I use a lot of 4"x 12" steel tube , Id weld 3/8" thick angle to this tube to carry brick. Supported by 4x4" tubing on each end. All would be 1/4" wall. I've worked so much with My eng. I think like Him. Using the code to size ,is a poor sub. for engineering,Don't understand that!
Driftwood is offline
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
brick veneer? sandyman720 Masonry 6 05-02-2008 04:32 PM
Brick Veneer on steel angle iron sandyman720 Construction 9 07-15-2007 05:20 AM
Brick Veneer Chimney w/ Factory Insert rhomfeld Carpentry 6 09-15-2006 09:23 PM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
