Can't Post
Trade: Construction
Brick Veneer?
I am trying to add a brick veneer to my addition that I am building. In lieu of adding an additional footing 30 inches for the brick, I was going to attach angle iron to the structure and start laying the brick on that. What does it mean that the angle has to be bolted to double studs? I was just going to bolt to my rim joist.
Here is what the code says: 1). R703.7.2.1 Support by a steel angle: The minimum size for steel angle support is 6 X 4 X 5/16 thick. This angle support shall be bolted to double studs by two 7/16 X 4 inch lag bolts. The double stud support shall be placed on 16 inch centers. Flashing and weep holes are required at the bottom of the steel angle. The maximum height of the veneer supported in this fashion is 12 feet 8 inches. A construction joint is required between this veneer and the veneer that bears directly on the concrete foundation. |
Re: Brick Veneer?
You have received the best information you can get in your previous posts on the various forums. If you are looking to get someone to simply agree with you, then ask a friend. ConcreteMasonry's advice was the best, followed by bolting the angle to the concrete.
Re: Brick Veneer?
It's your house,just bolt it to the rim joist.Not a big deal.If it's too hard using bolts screws are fine or nails for that matter,roofing nails being the easiest.Good luck and post pictures.
Re: Brick Veneer?
Tkle, that ain't nice.
Re: Brick Veneer?
pour the footing you will be happier with the results!
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln- Less with the jaw more with the paw! |
#6 | |
Trade: masonry
Re: Brick Veneer?Quote:
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
Re: Brick Veneer?
You guys are mean! LOL
| Brick veneer vs solid masonry | sean mccormack | Masonry | 16 | 04-23-2011 05:15 PM |
| Thin Brick, VS Regular Brick | Project53 | Construction | 25 | 03-11-2010 03:13 PM |
| Brick Veneer support over large opening. | Atlantex | Masonry | 8 | 08-14-2007 12:02 AM |
| Brick Veneer on steel angle iron | sandyman720 | Construction | 9 | 07-15-2007 05:20 AM |
| Brick Veneer Chimney w/ Factory Insert | rhomfeld | Carpentry | 6 | 09-15-2006 09:23 PM |
