Trade: General Contractor, Remodeler
Brick Facing Cracking
3" ABS downspouts are buried in the brick about 1/2" from the surface, solid brick everywhere but where the downspouts are. Top to bottom cracks at both downspouts.
I'm thinking the ABS is expanding in the heat and pushing forward on the 1/2" veneer brick. Anyone had this happen? I'm thinking the facing needs to be dismantled enough to get at the downspout, change the downspout to galv., and repair the facing. Do I have any idea what I'm talking about? ![]() Ideas?
now i am scared for my future i've got all ten smashed a lot of them stupidly before -john5mt |
Re: Brick Facing Cracking
Have never seen anything like that.
Why not patch the brick with brick, and hang the downspouts on the outside where they belong?
Trade: Masonry
It's not that the pipe is pushing out. It's that the wall is thinest there. Expansion and contraction, where the pipe is, is the weakest point. Saw in a control joint and caulk.
CJ has it right.
It ain't Rocket Science unless you are building rockets. |
#5 | |
Re: Brick Facing CrackingQuote:
![]() It's not that the pipe is pushing out. It's that the wall is thinest there. Expansion and contraction, where the pipe is, is the weakest point. Saw in a control joint and caulk. That would work, but sure look like poo poo. It's the front of the house.... maybe wouldn't look too bad. Guess I'll go look again. Thanks guys....
| Thin Brick, VS Regular Brick | Project53 | Construction | 25 | 03-11-2010 03:13 PM |
| Historic Brick Fireplace | Tommy C | Masonry | 11 | 10-04-2009 10:33 PM |
| wire behind brick | hurricaneflyer | Electrical | 7 | 11-13-2006 08:03 PM |
| Low (12" or so) brick garden wall questions | bindersbee | Masonry | 8 | 04-27-2006 08:31 PM |
| red brick has developed a white coating | wbsbadboy | Masonry | 4 | 02-28-2006 09:33 PM |
