Block Not Level Around Perimeter.
Old 10-06-2009, 02:07 PM   #21
izzy's Avatar
Re: Block Not Level Around Perimeter.
At this point (1.5" high) it seems the simplest solution would be to cut the block off at the correct elevations. The manson will probably have to relay several courses. I always shoot in my corners and step blocks for my masons and if they dont get it right from there they pay me to fix it.
izzy is offline
Old 10-06-2009, 06:29 PM   #22
NJ Brickie's Avatar
Trade: Bricklayer
Originally Posted by CMSStoneworks View Post
someone gets it! lol
I get line levels for free all the time when I buy chalklines etc....they go right in the garbage. I trust my 1000 dollar laser....not a 4.50 cent string that stretches and sag's. I only use stringlines for edges....and even then i use my 48 inch level to further insure im where i wanna be.
Straightline....might i suggest you or the GC stand over this guys shoulder. If I ever laid block like that i wouldnt have my business.
Not really sure you get it. If you build two corners and hang a line to lay to what is that line doing??? Plumb, straight, and LEVEL. In masonry a line is used for level, granted you need a benchmark on your corners and leads which is usually provided by a laser, builders level, or transit. But if you truly are a mason you know that a string line is used to level.
NJ Brickie is offline
Old 10-06-2009, 07:14 PM   #23
6stringmason's Avatar
Trade: masonry
Finally, another person gets what I was saying lol. A line level is something COMPLETELY different from a level line. I wouldnt trust a line level for anything. But I would trust to build up two leads on corners that have the same heights and run a level line to fill in the rest of the wall.
And if you've been doing it awhile, you can generally tell when you line is sagging and either tighten it, or put a twig in the middle, take your pick. But either way, Id be interested to see how people lay a 25' block or brick wall without a line. I can imagine its a slow process.
Kamps Masonry & Concrete Countertop Design Green Bay, WI
920-680-3195
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 10-06-2009, 10:03 PM   #24
Tscarborough's Avatar
Line levels do not give you a level line, but used correctly they can tell you if the two ends of the line are level to each other. As a rule, line levels are not used by any masons I know, but level stringlines are used every day, all day, on jobs from one side masonry residential to million block commercial. There is no other practical way to do it.
That said, I learned when not to use stringlines in my days as a rodman and instrument man, but that was layout and surveying, not putting masonry units in the wall.
Tscarborough is offline
Old 10-07-2009, 09:46 AM   #25
CMSStoneworks's Avatar
Trade: Hardscaping & masonry
I'll use a line stretched between corners or ends to keep it straight....but i dont use it as a level reference....I just level each block with my torpedo and in reference to the rest with a 48inch. Maybe im being too critical?
CMSStoneworks is offline
The Following User Says Thank You to CMSStoneworks For This Useful Post:
skyhook (10-07-2009)
Old 10-07-2009, 10:55 AM   #26
_SpinDrah's Avatar
Trade: Mason
You should not be using a lvel on a wall that has a line already! it is just a wast of time, the block should be layed from the edge of the block below it, to the line.
_SpinDrah is offline
Old 10-07-2009, 11:55 AM   #27
Gotcha, and it makes sense....im just too anal.
Old 10-07-2009, 11:57 AM   #28
mics_54's Avatar
Trade: contractor
I dont give a crap how you do it. If its 1.5 inches off when you are done you wouldn't do another one for me.
mics_54 is offline
Old 10-07-2009, 02:03 PM   #29
straightline's Avatar
Trade: new construction/remodel
Thanks for all the replies, I was down this morning and set up transit and shot all the corners and mid spans the one area we were talking about which is and inside corner was off 1 3/8" high and block ran down hill to outside corners approximatly 8ft in each direction. The mason said he would cut the top block down to level. The rest of the walls are with-in 5/8" at the worst point and one wall for stairs is low by 7/8" which I believe we will build up with mortor and lay sill in it to level. I have some pictures but dont have them downloaded yet. I will post later tonight. Thanks again.
straightline is offline
Old 10-07-2009, 02:21 PM   #30
Glad you are working it out.
Maybe you have also come to see
how messy and confusing it is to
double post?
neolitic is offline
The Following User Says Thank You to neolitic For This Useful Post:
Old 10-09-2009, 10:14 AM   #31
Not confusing to me, guess if your not an open minded person it could be. Why not get feed back from both the carpenty and masonry forum since that is the problem I was dealing with?
Old 10-09-2009, 10:25 AM   #32
If you look through both threads you will
find that we are more open minded than that.
You have responses from various trades
in both threads.
Most of us use the New Posts button,
and see what is on all of the forums.
Double posting is not good forum etiquette,
rather like typing in all caps.
Nor is insulting folks trying to help you.
neolitic is offline
The Following 2 Users Say Thank You to neolitic For This Useful Post:
skyhook (10-15-2009), XanadooLTD (10-09-2009)
Old 10-10-2009, 07:49 PM   #33
_SpinDrah's Avatar
Trade: Mason
I don't use the New Posts button, I don't do that on any forum, If he only posted in the Carp Hang out He would have missed my valuable Input.
The Following 2 Users Say Thank You to _SpinDrah For This Useful Post:
izzy (10-12-2009), lukachuki (10-10-2009)
Old 10-15-2009, 08:57 PM   #34
Burns-Built's Avatar
Trade: Residential Construction & Masonry
So if this guy is 1.5" low in one corner what i would like to know is how far out of square is this foundation??
Burns-Built is offline
Old 10-15-2009, 11:07 PM   #35
izzy's Avatar
Good point. I always shoot in my corners with a transit for my masons. A little more work for me but it keeps these problems at bay.
I would say you would be surprised at the builders who never even check for level elevations or for square.
He! He! Half of them don't even know the difference between a transit and a site level.
izzy is offline
Old 10-15-2009, 11:43 PM   #36
If you want the answers to these
and other questions......
Tune in to his "other thread."
A little bit here, an answer there.....
Double posting is fun.
neolitic is offline
Old 10-15-2009, 11:45 PM   #37
Super B
skyhook's Avatar
I recall one project were I let the concrete guy set forms. When I checked, he was 10' into the set back on a 2 story foundation. If I had not checked it would have cost me 1,200 square feet of construction and would have had to be torn down. Good thing I check the prints. I can about it.
skyhook is offline
Old 10-16-2009, 09:49 PM   #38
izzy's Avatar
Big 10-4. Form guys are notorious for losing or adding square footage if not checked. No offense to any form guys I was a concrete for-man for a stretch in my career.
izzy is offline
Old 10-16-2009, 11:10 PM   #39
As a Rodman, I held the dummy end and pounded stakes on the same building 3 times (3 days work each layout in Summertime Houston) before the @!#$%@#$% Job Engineer got it right. In Atlanta, still as a Rodman, we missed it by four feet to the South, but had it square to site and on grade on a half million SqFt warehouse complex. That one was built and accepted "as is".
The Following User Says Thank You to Tscarborough For This Useful Post:
essrmo (11-25-2009)
block work rebar question paintbob7 Masonry 4 05-31-2009 11:46 AM
window return in concrete block house bmancanfly Remodeling 10 05-15-2009 04:30 AM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
concrete block installed out of level pawlooch Masonry 10 05-04-2008 11:41 AM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
