Block Foundation Seepage
Old 03-04-2018, 08:24 AM   #1
cowboysdad's Avatar
Trade: Carpentry/Remodeling
Rewards Points: 68
Hey guys,
We just bought a new home. We are in Wisconsin, and it has a block wall foundation.
We've only been here a few weeks, but there has been some water leaking through the blocks on the only inside corner of the foundation. Yesterday I punched a couple holes in the blocks to drain some water, and relieve the pressure. I sealed up the blocks right way with hydraulic cement. This worked pretty well. But there is still some minor seepage right at the wall/floor joint in 2 spots. One is at the corner, the other is about 2 feet away.
Any suggestions for sealing this up the rest of the way. I want to finish the basement this summer, but need to get this fixed completely before doing so.
cowboysdad is offline
Old 03-04-2018, 10:14 AM   #2
fjn's Avatar
Trade: mason
Rewards Points: 9,134
Re: Block Foundation Seepage
Here are things to check,some are mandated by building codes. Soils should slope from building a minimum of 6" in first 10 '. Siding should be a minimum of 6" from existing grade,brick 4". Foundation should have more than a thin coat of spray tar as damp proofing. My go to product is Platon. There should be a 4" drain pipe 6" below top of interior floor slab (preferably SDR 35 covered in sock,well drained back fill ,either crushed stone or coarse sand.
Without the above systems in place,you will fight water issues til the cows come home.
fjn is offline
Old 03-04-2018, 10:37 AM   #3
fjn's Avatar
Trade: mason
Here you go.
http://www.jlconline.com/videos/foun...6325841595919c
fjn is offline
Old 03-04-2018, 12:54 PM   #4
General Contractor
greg24k's Avatar
Rewards Points: 7,358
Originally Posted by cowboysdad View Post
Hey guys,
Did a job for someone a while back with the same issue. Cut the slab, installed PVC to allow by-pass under the slab, no more water issues even after a 2-day downpour.
Block foundation seepage-drainage-_1.jpg   Block foundation seepage-drainage-_3.jpg   Block foundation seepage-drainage-_4.jpg
greg24k is offline
Fouthgeneration (03-11-2018)
Old 03-04-2018, 03:14 PM   #5
Windycity's Avatar
Trade: Masonry
Rewards Points: 5,798
Originally Posted by fjn View Post
I agree this is the only way to fix it...If you have a mini excavator digging the exterior foundation is relatively easy provided you donít have a lot of obstructions around the house
I have the same thing, a 1950s house with a block foundation with absolutely no water or damp proofing and tons of water seepage. This summer my plan is to excavate the soil around the foundation and fix it right...leaky basements suck big time
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
fjn (03-04-2018)
Foundation Concrete Block Fix No paint Mattymax Masonry 9 05-22-2017 10:54 AM
Block grout requirements. dom-mas Masonry 7 02-24-2014 06:52 PM
Block skirting under manufactured home, lay wet or dry? NYCB Masonry 25 06-12-2013 06:44 AM
12 inch block foundation Stoga21 Masonry 3 01-22-2013 07:37 PM
Block foundation parging? veloguru General Discussion 4 11-11-2010 08:02 PM
