Block Foundation Addition
Old 03-11-2010, 06:54 AM   #1
kubie's Avatar
Trade: general contractor
Rewards Points: 278
ok i adimt, i know almost nothing about block wall foundations.
a homeowner contacted me to build an addition. they have a block foundation and would like the addition to be the same.
i contacted a local mason and he said that he would just butt his block up to the old ones and mortar them in.
i asked him if the new joint between old and new would leak....he said no.
is this the way u would do the job? or would you remove the old block and tie into the old foundation?
i am just worried about that joint not being water tight
thanks for the help
kubie is offline
Old 03-11-2010, 07:17 AM   #2
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Re: Block Foundation Addition
So you would suggest making the existing foundation weaker to accept the new addition. How long have you been doing this?
I do 10-20 additions a year, I have never cut into the existing yet, but there is always that exception out there waiting.
Properly slope the grade away from the wall, provide drainage at the footer level and finally use a water proofing material on the block. Your good to go. If it is a basement then you might look into some of the more detailed waterproofing systems.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 03-11-2010, 07:20 AM   #3
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
I think he's referring to the intersection of old to new. The inside corner is notorious for leaking.
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 03-11-2010, 04:34 PM   #4
kubie's Avatar
Rewards Points: 278
why would it matter how long/many i have done?
im not a mason. so i ask for help.
kubie is offline
Old 03-11-2010, 04:36 PM   #5
NCbrickie
GoToBrick's Avatar
Trade: custom masonry and hardscape
I would score a little notch down the joint and fill with a good brand non-hardening caulk
Larry
farout@myself.com
http://www.centsports.com/?opcode=665464 ---just paste this to your browser to bet all favorite sport games
GoToBrick is offline
Old 03-11-2010, 05:01 PM   #6
tcleve4911's Avatar
It's a good question
C'mon all you masons....chime in and share how you do it.
Back in Maine
Dubbin' Around
Old 03-11-2010, 05:25 PM   #7
lukachuki's Avatar
Rewards Points: 1,002
thanks for the help
Just butt and butter. If you are worried about moisture issues you need other solutions such as draintile/membrane etc. Masonry no matter how it is tied into the existing foundation is problematic from a moisture standpoint. my .01!
I'm a little mean, but I make up for it by bein' real healthy. Earnest T. Bass
lukachuki is offline
Old 03-11-2010, 06:44 PM   #8
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
The joint will most likely crack, but that is usually how it is done. I would nail some wall ties into the existing and rake back the joint and caulk it. If there is a moisture issue you will need to address that no matter how you lay the block.
NJ Brickie is offline
Old 03-11-2010, 08:58 PM   #9
6stringmason's Avatar
Trade: masonry
Rewards Points: 1,136
Where are you located in WI? I'd be more than happy to give you a price!
Kamps Masonry 920-680-3195
https://www.facebook.com/pages/Kamps...31566206923069
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 03-11-2010, 09:38 PM   #10
Rockmonster's Avatar
Trade: Masonry
Rewards Points: 5,494
This is how I do it. If the cell where you are connecting is grouted solid, drill and epoxy rebar pins, I do the footing and a couple/few in the wall, maybe two in a crawl, maybe 4 in a full basement. I usually put a bend in the bar and go into the second cell in the new wall. Grout accordingly. If the cell is ungrouted, I will open it up, usually slot it about 4" wide, and insert rebar connecting new to old. I use what we call z bars, 2 90's in opposite directions. Waterproof is usually thoroseal brushed with tar, or I get it sprayed with (trade name escapes me) some hot bituminous stuff. Also may use FSB by silpro followed by concrete finish for a nice look and a good measure of protection. This is fairly bulletproof. At the joint, you can rake it and caulk with any number of great products, but I've found no need with my method, as I've never seen one open up. I am curious as to how others do this as well, but this method has worked for me....
Rockmonster is offline
The Following 3 Users Say Thank You to Rockmonster For This Useful Post:
6stringmason (03-12-2010), tcleve4911 (03-12-2010), UALocal1Plumber (05-25-2014)
Old 03-11-2010, 09:49 PM   #11
Tscarborough's Avatar
Rewards Points: 1,406
The waterproofing should be outside the CMU envelope, and should be designed to allow for movement between the existing and the new.
Tscarborough is offline
Old 03-13-2010, 08:46 PM   #12
Gumby
IanS's Avatar
Trade: Concrete
Rewards Points: 75
The new block just gets mortared into the old block.
block foundation addition-slide1.jpg   block foundation addition-slide2.jpg   block foundation addition-slide3.jpg
IanS is offline
Old 03-13-2010, 08:49 PM   #13
Gumby
IanS's Avatar
Trade: Concrete
Rewards Points: 75
One last pic.
IanS is offline
Old 03-14-2010, 12:05 AM   #14
CanCritter's Avatar
Trade: bricklayer/stonemason
Rewards Points: 342
to many varibles to be considered here...as Rockmaster said.. drill rebar and epoxy is a good start but then again more varibles...wall being drilled solid or block ?....has block been filled with concrete ect?...proffesional footing or will it settle and pull wall away or fail somewhere else causeing leaks ect ect
..most fasteners make me nervous around empty cores as l know how easly a block can fail given the wrong stress;s....what realy makes me nervous is folks on my chevy truck forum that use blocks for jackstands,,,
ps..good pics above
CanCritter is offline
Is Foundation Strong Enough For 2nd floor addition? Vince10 General Discussion 11 02-23-2010 12:27 PM
Best way to shim a block foundation forsmant Framing 22 02-01-2010 05:21 PM
Jacked up block foundation Nailerconstruct Framing 49 09-02-2009 08:45 PM
Damp proofing block foundation ??? SBI Masonry 4 03-01-2009 03:21 PM
6" block for foundation wall AustinDB Masonry 8 11-16-2008 01:39 PM
