Trade: Masonry
Bleeding Stone Wall
Hi everyone. Wondering of someone can explain why this happens and what to do so it does not happen.
My mothers stone wall that was constucted from blocks and then venered with stone and 1/2 to 1" joints. Wall was completed about 3 years ago. It now has a hard milky residue all over the stone. Looks like its dripping through the concrete from the joints and caps. The stone looks horrible now. SO How did this happen? Whats the cause? How do you prevent this? And is there a way to remove that crap? |
#2 | |
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Re: Bleeding Stone WallQuote:
Search for this word: efflorescence |
Bigmo
Trade: Masonry Restoration and Repair
Block are notorious for not taking well to excessive moisture infiltration. The water is likely coming from behind the wall due to improper drain or no drain installation. Will likely need more info and some picks to help you more than this.
Trade: home improvements and renovations
This is something that someone in the masonry trade should be able to help you with.
Is it a freestanding wall or retaining wall? Is it a 4" stone veneer or an adhered veneer? What type of stone and what is the cap design?
It ain't Rocket Science unless you are building rockets. |
Trade: Masonry
It's a retaining wall constructed from block and then veenered with Everalast Natural Colonial wall stone that varies in thickness from 1-3". Cement on between the block and stone is about 1 1/2" The cap is the same stone.
Dig out behind the wall to the footing. Waterproof the backside of the wall with a product like Thoroseal or a trowelable mastic. After this is done, you can use a product like 101 lime solvent or 800 detergent to remove the existing efflorescence. Post a close up picture of the efflorescence and detail if it is hard and glossy or soft and chalky.
Restoration Crazy
Was the block filled with cement?
Jason E Whipple, General Manager Historic House Restoration, Cincinnati, Ohio Facebook | Twitter |
Trade: Masonry consultant
The souce of the white deposit is probably the mortar and any mortar used to be the stone.
The water from behind the wall picks up the salts from the mortar (very likely) or the stone (not too likely). These salts (usually calcium) are deposited when the moisture on the face of the wall evaporates, leaving a stain behind. To stop efflorescence, eliminate the moisture in the wall, which was suggested by TS and is the most reliable approach. Jason - No one fills a wall with cement. If they are not as wrong, they use concrete. If they are right, they use grout. - just a matter of terms, but use the right terms around and inspector.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. Last edited by concretemasonry; 08-11-2008 at 05:17 PM. |
Trade: Masonry restoration
When ever we build a wall that the backside will be exposed to below grade moisture, we install a sheet membrane system follow by protection board and proper drainage. No more problems
| removing a retaining wall | Cache | Excavation & Site Work | 30 | 07-16-2008 05:57 PM |
| 6 ft stone retaining wall | mason22 | Masonry | 8 | 04-12-2008 03:57 PM |
| Stone Wall Pricing | CJKarl | Masonry | 45 | 01-09-2008 08:23 PM |
| Repairing Jog In Wall for Stone | Nailbird | Windows, Siding and Doors | 0 | 07-20-2006 06:58 PM |
| 18" stone wall ! Insulate or not? | deox719 | General Discussion | 1 | 05-02-2006 11:24 PM |
