Basement Walls (stone)
Old 08-10-2008, 07:35 AM   #1
mikecrisco's Avatar
Trade: concrete
I would like to know some opinions on the right mix for stone walls...I use 20 shovels of sand 1 bag of portland cement and 1/4 bag of lime to parg the walls...does this sound like a good mix, and if not could you let me know what you use...
thank you
mikecrisco is offline
Old 08-10-2008, 07:51 AM   #2
osborn's Avatar
Trade: Licensed Home Improvement Contractor
Re: Basement Walls (stone)
Do you parge your walls on the inside?
osborn is offline
Old 08-10-2008, 09:26 AM   #3
eekie34's Avatar
Trade: Masonry restoration
If it is interior walls typically we use a 4:1:1 ratio, just like a stucco mixture. If you are simply parging, do it in lifts if it is thick, or it will crack out. A bonding agent is always helpful. I do not parge anymore, I rewire and stucco. Better, long lasting job
eekie34 is offline
Basement Walls and Insulation highpeaks Construction 6 07-21-2008 06:36 PM
waterproofer to seal basement walls flashme18 Painting & Finish Work 15 07-09-2008 02:23 AM
Help! Need advice for waterproofing basement walls healthyhomes General Discussion 6 06-11-2008 06:44 PM
pricing stone walls? mason22 Masonry 17 04-04-2008 09:03 PM
Leak from my 100 + year old basement walls Ed the Roofer Masonry 22 06-04-2007 05:02 PM
