Basement Slab Question
Old 05-12-2006, 08:18 PM   #1
n74tg's Avatar
Trade: residential construction & remodeling
Am building a house that will have a partial basement; roughly 12'x22'. Basement walls will be concrete block (dry stack method). I am planning to pour concrete footers first; then form up and pour the reinforced slab second, then build the concrete block walls, installing expansion material between slab edge and block walls.
My question is do I have anything to gain by tying the slab to the footers with rebar placed at time footers were poured -or- will it be better to let the slab float on top of the footers.
n74tg is offline
Old 05-12-2006, 08:23 PM   #2
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
Re: Basement Slab Question
As long as footers and slab are on a solid base, you won't need to worry about tying them into each other. One thing you can do is do a monolithic pour, then lay the block up.
rino1494 is offline
Old 05-13-2006, 10:31 AM   #3
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
oops, wrong post
Mike Finley is offline
Old 05-26-2006, 08:20 AM   #4
cementhead82's Avatar
Trade: Cement Mason
Mike, I would pour the foundation, Build the walls to spec and then pour the slab within the walls. Once you have walls you will only need to put up forms at the exit's. Just remember to use expansion joint on all walls.
Also If you have lolly cloums helping to support the project remember to box them out and pour them at a later date when the job is under roof.
cementhead82 is offline
Old 05-26-2006, 08:22 AM   #5
Trade: Cement Mason
I am sorry I think I read your post wrong. Are you planning to build the wall on top of the slab. Why??? You are just asking to have water in your basement?
Old 05-26-2006, 04:38 PM   #6
tkle's Avatar
Lay your first course of block then pour to them.
tkle is offline
built up slab question stampcrete Concrete & Paving 9 03-27-2008 05:24 PM
Basement Block Question TBALL Construction 11 02-09-2007 06:40 PM
Basement Window Question gregt848 Windows, Siding and Doors 9 07-26-2006 06:29 PM
Mono Slab Question? TBALL Construction 3 07-26-2006 08:11 AM
Basement Heating and Air Question? Jet727 HVAC 1 12-09-2005 10:29 PM
