Anyone Used These Block?
Old 03-17-2009, 09:02 AM   #1
roo's Avatar
Trade: Bricklayer
I'm about to build a 35 meter wall in France. I ordered some blocks and got these (see attatched images) has anyone used these before. If so how do you use them. I assume the circular hole is for a steel rod, anyway i'm confused. any help please!
roo is offline
Old 03-18-2009, 05:55 AM   #2
AtlRemodeling's Avatar
Trade: Residential Remodeling
Re: Anyone Used These Block?
I assume you mean 35 meters long. If it is 35 meters high and you are that confused on the block... run away from this one, trouble is coming!
Anyway, no attachment that I can see.
AtlRemodeling is offline
Old 03-18-2009, 08:09 AM   #3
roo's Avatar
Trade: Bricklayer
Yes, sorry, 35 meters long. I'll try and attatch again, but I think I worked it out, I was just being a bit thick. They don't mortar their perps (vertical joints) out here. And the holes must be for steel rods for reinforcement as it will only be single skin. Its 35 meters long and about 1 meter high.
roo is offline
Old 03-18-2009, 09:20 AM   #4
jcalvin's Avatar
I guess you have to stack those vertically. Not much way to do a half lap and still use the steel holes. Hope your not trying to hold anything back with those.
Cal
You hired WHO
jcalvin is offline
Old 03-18-2009, 06:15 PM   #5
cleveman's Avatar
Trade: custom home building
Do you want french block with that?
cleveman is offline
Old 03-18-2009, 10:10 PM   #6
Rockmonster's Avatar
Trade: Masonry
My guess is that hole is for a conduit....with steel there would be more room for the grout, rebar being virtally worthless w/o it...good luck
Rockmonster is offline
Old 03-18-2009, 10:32 PM   #7
concretemasonry's Avatar
Trade: Masonry consultant
The supplier should know how they are properly used.
The block is typical low strength unit made on a "big board" machine.
I guess it proves the French do not want to use the superior German or American systems.
1 meter high is not that such and an interlocking unit would not use a footing or any mortar.
If you have any information on the size of the unit and where (manufacturer and/or city) it came from, I may be able to get some information from a friend in France.
Dick
concretemasonry is offline
Old 03-19-2009, 07:05 AM   #8
tkle's Avatar
Sometimes a hole is just that and nothing else. A place to hide hidden gems? Alas simply a key for the mortar.Rebar? I seen Bob Villa try that on some cored brick. Said it right out loud like he knew. Once a wise man said there are no stupid questions...He is no longer wise. Like a real wise man once told me," Shut up and lay the damn thing".
tkle is offline
Old 03-20-2009, 10:23 PM   #9
billy d's Avatar
Trade: carpenter
Roo not trying to bust your balls my friend but the holes are not for rebar, but there just so you can put your thumbs in the holes pick them up and lay them on your bed. billy
billy d is offline
Old 03-21-2009, 11:00 AM   #10
bobcaygeonjon's Avatar
Trade: Bricklayer / contractor
These blocks need to be perped. They are not interlocking.
bobcaygeonjon is offline
Cinder Block walls, block filler and a leak...question SeanATL Painting & Finish Work 9 03-09-2009 04:33 PM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Segmented Block Options LNG24 Masonry 7 10-16-2008 09:46 AM
Just boguth a new short block for race car:) IHI Off Topic (Non Trade) 4 09-21-2006 09:25 PM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
