#1 | |
FLORIDA CRACKER
Air Compresor Freon Line Sealed Wth Concrete
I live in Florida things might be different here . the air compressor is outside and the freon line runs up the wall to the attic where it is connected to the air handler. outside they put a metal casing around the freon line and it is open at the bottom this is where they fill it with spray foam but I seen a c guys put a concrete in there to seal the bottom does anyone know what it is?? it looks like concrete but it has fibers in it
Trade: Masonry
Re: Air Compresor Freon Line Sealed Wth Concrete
The fibers most likely are a product called Fibermesh. Mixed with the concrete for strength. You/they should really avoid having copper lines in direct contact with concrete.
#3 | |
FLORIDA CRACKER
They rap the lines with foam I have seen this used to seal cracks in sulfitt too. You may be right with the fiber. Do thy sell together? if not do you mix it with quickcrete concrete patch
#4 | |
Trade: Masonry
Re: Air Compresor Freon Line Sealed Wth ConcreteQuote:
You can buy fibermesh bulk, or just order it with the ready mix concrete, |
| Shingles Nailed Above Nail Line.. Help!! | Unregistered | Roofing | 24 | 04-20-2011 09:14 PM |
| Fiber Optics in concrete countertops | 6stringmason | Concrete & Paving | 17 | 03-16-2011 05:49 PM |
| Hardwood to concrete floor, with nothing in between?? | SBI | Flooring | 7 | 08-01-2008 02:21 PM |
| Straight Horizontal Line | Speer007 | Carpentry | 17 | 12-15-2006 06:26 PM |
| Stamped Concrete | Chicago | Landscaping | 19 | 07-08-2006 02:44 AM |
