Aging Stone To Match Existing
Old 05-09-2009, 09:05 PM   #1
RZB's Avatar
Trade: masonry
Were about to build a set of stone steps for a client out of credit valley sandstone to match the old foundation. The existing foundation has a blackish patina or oxidization on it. Does anybody here know of a way to stain the new stone to match this. We've asked around and heard pickle juice, which just makes it look green and smell like pickles, not quite the effect we were looking for. Any suggestions would be greatly appreciated.
RZB is offline
Old 05-09-2009, 09:35 PM   #2
Tscarborough's Avatar
Re: Aging Stone To Match Existing
It is a very complicated process:
Let them age.
If that is unacceptable to the customer, charge them to clean the old ones to match the new ones.
Tscarborough is online now
Old 05-09-2009, 09:40 PM   #3
Resta's Avatar
Trade: Ornamental Plasterer/Restorer
Take an extra peace of stone and make a few samples. Wash stone from dust, make a color mix - "liquitex" matte medium and colors: charcoal grey, raw umber, hunter green. You can use a powder or acrylic paint. I like raw umber powder and other colors acrylic. On the glass of water use 1 spoon of matte medium, 1 spoons raw umber , 2 charcoal grey and 1/8 dark green. Mix it, put a large round brush into mix, take it out with right hand and keep in front of stone 1/2 inch, in the left hand have a spray bottle with water and spray on the brush toward stone and keep sraying on the stone to mach intensity of existent patina. Or you can use some textured sponges too.
Resta is offline
Old 05-09-2009, 09:53 PM   #4
The problem with staining them to match is that once the aging process proceeds they will no longer match. You can rub dirt on them, but do not apply any permanent paints or stains.
Old 05-09-2009, 10:49 PM   #5
Resta's Avatar
Yes it will match. They will age together. You must to make a stains match and penetrate in to sand stone, not a film/skim.
Resta is offline
Old 05-09-2009, 11:44 PM   #6
RZB's Avatar
Trade: masonry
We told the HO we had a method but it would take a while, roughly 80 - 100 years, they didn't like that option so I just thought I'd see if anyone else had done a similar application. Has anyone seen the article where a company restored a cathedral in Chicago with a paste that peeled off like a facemask (or so my wife has told me anyway ) and the building went from a black caused by a century of pollution to white. Even the paintings inside, pretty cool stuff.
RZB is offline
Old 05-10-2009, 09:29 AM   #7
jvcstone's Avatar
Trade: Masonry / architectural stone carving
Since the aged patina is caused by the growth of organic critters (molds, fungi, lichens) , the aging process can be hurried by creating an environment that encourages such growth. Regular applications of growth medium such as liquid fertilizer, manure tea, buttermilk, can help establish the colonies of micro-organisms that result in the aged patina. (once buried a stone table and bench set in a compost pile for a few months--spectacular result)
Conversely, an application of bleach (or two) to the weathered stone will lighten it close to it's unweathered appearance. This will not remove the "case hardening" that also results from the weathering, but the results can be acceptable.
Your client needs to understand that it is an "aging process", and while the above can help speed the process, it won't happen over night. Stone exposed to the weather will darken faster than that protected by roofs and overhangs--(ever notice how much faster the chimney will darken above the roof line than the wall veneer does). To get immediate results, you could attempt to play momma nature with a paint mixture as suggested by Resta. Of course, practice on a few scrap pieces first. Might work out well enough to get you off of the job.
JVC
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Old 05-10-2009, 09:45 AM   #8
Resta's Avatar
Do you want to clean or put some aging on ?
Sandstone wary in color and cleaning with solvent with acid may cause discoloration. This paste what you say is call 'poultice' and it's made from kaolin, fuller's earth, whiting, chalk or talk. For whitening use amonia or peroxide. When poultice drays it pulls out the stain and pollution residue.
Resta is offline
Old 05-10-2009, 10:05 AM   #9
Resta's Avatar
To get aging look patina in natural organic way. Take natural wood coal dust, put on the piece, put a hay on that and wet it with a goat urine, bury not deep and watering with urine for 2 weeks. Dig out. Works well.
Resta is offline
Old 05-10-2009, 10:38 AM   #10
Resta's Avatar
Aging with colors looks like that. It may be to dark for you, but strength of color you make what you need.
Resta is offline
Old 05-10-2009, 10:42 AM   #11
Resta's Avatar
"Tea stain" color match on heart stone.
Resta is offline
Old 05-10-2009, 11:07 AM   #12
Resta's Avatar
You can do and match everything.
Aging stone to match existing-neptune.jpg   Aging stone to match existing-neptune-2.jpg   Aging stone to match existing-bench.jpg
Resta is offline
Old 05-10-2009, 11:29 AM   #13
RZB's Avatar
Trade: masonry
Thanks guys, alot of great tips. I really appreciate the help.
RZB is offline
Old 05-10-2009, 11:34 AM   #14
RZB's Avatar
Trade: masonry
Resta I was wondering how permanent are the stains you use? Do they fade or weather differently with exposure. Your work looks really good, we have never tried using any kind of dye or stain on anything before, just curious.
RZB is offline
Old 05-10-2009, 12:16 PM   #15
Resta's Avatar
If you want keep it permanently you must use more medium matte and seal. If you use certain amount of medium matte it will fade very slowly and natural aging converts on the top. Like all artist coloration - it fades...sadly we see that on old paintings, frescos, murals...also on fabrics, drapery and etc.
Resta is offline
Old 05-10-2009, 03:56 PM   #16
denick's Avatar
We've gotten results getting an initial start on aging where black was desired by using a black compost/humus. rubbing it in or making a mud / slurry and brushing or spraying on. Experiment in application and time before removal.
It has worked on several churches and homes to get an initial "old" look.
Nick
"Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein
denick is offline
Old 05-14-2009, 02:31 PM   #17
Bigmo
Michael Olding's Avatar
Trade: Masonry Restoration and Repair
Just a note about the staining... make sure you take your time! If you don't have an artistic bent with colors then hire someone who does.
Most stone are pretty forgiving but some are not and will stain deeply and quickly so go slowly.
By the way Resta I love that tea stain on that hearth. Very nice.
Michael Olding is offline
Stone is grouted but not sealed caustin Ceramic & Stone Tile 22 01-04-2010 01:48 PM
Linseed to color match new and existing fir???? sparehair Painting & Finish Work 2 02-17-2009 10:38 PM
Cultured Stone over Existing Brick Fireplace fakie99 Masonry 7 12-01-2008 06:10 PM
cultured stone ? wellbuilthome Masonry 7 08-19-2008 12:33 PM
