After Repair Repair
Old 03-15-2007, 12:27 PM   #1
ContractorTalk Flunkie
dayspring's Avatar
After Repair Repair
I recently done some major repair to a floor that was rotten due to a bad leak and poor drainage, long story. Anyway, the floor had dropped an inch or so in the area which also had a stone fireplace. The mortar joints had opened up in this area. After jacking the floor up and back where it should be the joints still have cracks. Since the stones had moved would they need to be reset in mortar before regrouting?
Advice on properly fixing this?
How would you estimate the work? sf of area or lf of joint?
Thanks
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 03-17-2007, 09:32 PM   #2
dayspring's Avatar
Re: After Repair Repair
Maybe my question doesn't rate a reply, oh well. I wasn't asking how much to charge at least.
T.C.
Old 03-17-2007, 10:08 PM   #3
6stringmason's Avatar
Trade: masonry
All of the joints in the fireplace have cracked?
If they are just small cracks I imagine you could just clean up the joints with an angle grinder and tuckpoint new mortar in.
If they are large gaps in the joints and stone are loose, you might have to relay the bad areas of the fireplace.
What type of stone is this?
Kamps Masonry & Concrete Countertop Design Green Bay, WI
920-680-3195
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 03-18-2007, 06:28 AM   #4
dayspring's Avatar
I know this will sound stupid, but they are just rocks. They appear to be local, many people around here used rock right off their property. 10 - 16" x maybe 3" thick. It is loose on one side, Gaps in joints vary
T.C.
Old 03-18-2007, 02:24 PM   #5
stacker's Avatar
Trade: masonry
remove and replay all loose stone and tuck point all cracked joints,its that simple.
more than likely it is native stone to your area,but that has nothing to do with what you need to do to fix your problem.
stacker is offline
Plaster Repair Thewallfixer Drywall 3 09-14-2009 12:08 AM
Foundation repair (New business) Help! crosshair66 Business 10 05-18-2008 09:19 AM
Tool Repair Services madchad Tools & Equipment 0 08-15-2007 09:16 AM
Chicago Home Repair License? Grumpy Contractor Licensing 24 09-15-2006 12:48 AM
Ok, ceiling repair Question Knyte260 Drywall 18 10-23-2005 01:15 AM
