Adhesive For Flagstone To Concrete
Old 06-05-2006, 11:47 PM   #1
dirt diggler's Avatar
Trade: contractor
is there an adhesive out there that can bond stone to concrete (do not have room for 2" of mortar --- have more like 1/4" - 3/4:" gap)
any takers?
dirt diggler is offline
Old 06-06-2006, 06:38 PM   #2
stacker's Avatar
Trade: masonry
Re: Adhesive For Flagstone To Concrete
thinset might work.i watched this old renthouse saturday,and they were appling stone veener to concrete wall using thinset.it might work.and it might not.
stacker is offline
Old 06-06-2006, 08:15 PM   #3
tkle's Avatar
Thinset will work,but it doesn't have any body to it to adjust for the varying thickness of stone.I would use a thin bed of some rich morter,possibly spec mix in combination with the thinset applying the thinset to the concrete and the stone with a thin morter joint between or mixing the two together creating a thinset with body.
tkle is offline
Old 06-06-2006, 10:00 PM   #4
jvcstone's Avatar
Trade: Masonry / architectural stone carving
Or you could use the granite/marble medium set from HD. Has a little more body and can be used up to 3/4 inch thick. Would work best if all of the stone was of the same thickness.
JVC
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Old 06-06-2006, 10:25 PM   #5
tkle's Avatar
JVC
I've seen the G/M set but have never used it.I take it's basically thinset with a larger grit. Sounds like a good idea.A latex additive or concrete glue wouldn't hurt either with the thin bed,especially if freezing or ice is a problem.
tkle is offline
Old 06-06-2006, 10:36 PM   #6
stacker's Avatar
Trade: masonry
i have never used this product either,but the house i am on now has a boat load of slate i have to lay and that is what they have to lay it with.the h/o has layed the slate in the laundry room already and it seems to work very well.i hope it does because the slate tiles are not very equal in thickness.
stacker is offline
Old 06-06-2006, 10:42 PM   #7
Trade: contractor
yeah Thinset was what I figured
hope it works ...
hahah guess we'll find outeek:
Old 06-06-2006, 11:08 PM   #8
tkle's Avatar
hope it works ...
Not sure what kind of flag you're using,but you're liable to get a lot of voids with straight thinset.The mediumset as jvc suggested sounds better.
I like to pack in the joints as i go, leaving them down only enough for grout.About 1/4 ".It helps lock in the stone.Wetting the back helps with adhesion,parging with thinset or neat is better.Make sure the back is clean.Many times people will wonder why their grout joints are cracking when it's really a void and the stone is actually flexing(quartzsite especially)or come loose.
tkle is offline
Fiber Optics in concrete countertops 6stringmason Concrete & Paving 17 03-16-2011 05:49 PM
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Concrete home denick Concrete & Paving 5 03-06-2007 04:32 PM
Hollow steel lally or concrete filled? kusa24 Construction 4 04-23-2006 08:49 AM
