Adding Mortar To Painted Brick
Old 10-13-2017, 11:05 AM   #1
timmy4402's Avatar
Trade: General
Rewards Points: 2
I have a client who is trying to 'clean up' their fireplace in addition to several other projects. The fireplace is brick from floor to ceiling and the current mortar is 1/4 - 3/8 inch deep from the face of the brick. They would like to lessen the depth of this to make is less chopped up and more (but not fully) contiguous surface. I was going to begin by just apply additional mortar to build it up closer to the brick surface, but they have painted the entire surface (brick and mortar) in the past.
I'm wondering if I need to do something to ensure that the new mortar will adhere to the painted surface.
After this step, the entire structure will be painted again.
Many thanks,
Tim
timmy4402 is offline
Old 10-13-2017, 08:42 PM   #2
Renaissance Man
superseal's Avatar
Rewards Points: 4,948
Re: Adding Mortar To Painted Brick
As long as the paint is sound and is not water soluble, Weld Crete is a legitimate candidate...I call it blue bond, it works very well.
http://www.larsenproducts.com/weld-crete/
supersealconstruction.com
superseal is offline
The Following 3 Users Say Thank You to superseal For This Useful Post:
fjn (10-13-2017), Fouthgeneration (10-14-2017), JBM (10-15-2017)
Old 10-18-2017, 12:55 PM   #3
johnnyN's Avatar
Trade: Architectural Precast Concrete and Cast Stone
Rewards Points: 8
I wouldn't go over the paint.
score or remove the surface paint so you can get to the substrate, then when you use a good product as superseal mentioned it will stick better.
I would use a grinder and be quick but aggressive.
johnnyN is offline
Pref fab brick panel questions charlie lazor General Discussion 8 04-23-2015 10:22 AM
What is your favorite brick & why? fjn Masonry 43 09-09-2013 01:14 PM
Drywall Patch Flashes Through Paint BobbyCA Painting & Finish Work 18 05-04-2013 08:04 AM
Bagged premixed lime mortar for tuckpointing wazez Masonry 158 10-28-2012 08:02 PM
Sill plates on top of brick Skinny General Discussion 5 03-26-2012 10:18 AM
