#21 |
Trade: underground
Re: 80 Lb Bags Of Quikrete
So the top ring on the bucket is about the 7-1/2 gallon mark? Learn something every day. Thanks.
Fortunately I keep my feathers numbered for...for just such an emergency. -Foghorn Leghorn |
#22 |
The rim on the bucket varies, but the top ring is generally 1 CuFt.
#23 |
Trade: masonry
wtf,just buy more than you think you will need.when you are done,take the others back to the lumber yard.
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
#24 | |
Re: 80 Lb Bags Of QuikreteQuote:
Thanks for straightenin' that out, T . . . |
#25 |
Moderator
Thanks T. Now my head is really spinning. I'm glad we don't use sack mixes much.
Stacker, they let you buy when you're naked, but you get arrested when you return in the buff.
#26 |
#27 | |
Just cover the extra bag real good until it gets wet than return it. |
#28 |
#29 | |
Deck Designer/Builder
I definitely book marked that one! |
#30 |
If I layed 48,000 sq.' 6" thick according to the calculator ,I would need an additional 9,000# if I used 60# bags.
#31 | |
Trade: Hardscape
An 80lb. bag fits about perfect into a 5 gal. |
| The Following User Says Thank You to orionkf For This Useful Post: | SC sawdaddy (03-05-2011) |
#32 |
That is correct, I was wrong.
#33 |
Trade: masonry
Just when I was beginning to think you knew what you were talking about!
Just kidding Tscar!
Kamps Masonry & Concrete Countertop Design Green Bay, WI 920-680-3195 Visit our website @ http://www.concretecountertopsdesign.com/ |
#34 |
If I knew what I was talking about I would charge you for it!
#35 | |
Trade: Masonry
Just read the bag, it's on there. |
#36 | |
I'm new, and will just go ahead here and start stupid... I'm forming up for a set of steps against a stone house (stone-rubble construction). The bottom step is about 100"W X 52"D. There are 3 treads each on two sides of the small staircase ending at a landing to the front door. The rise / run is 7" / 11". The form is up against the house, and will join the steps to the house with rebar; the steps are on either side of the form. There are no steps approaching the house from the front- there will be a railing across the front and down the sides, at the outside edge of the 'treads' as they go to the ground. The form is in 3 stacked and strapped-together sections, made of ledger-board (1x6), each section ending at a successive step on either side. The dimensions of each form section are: Step 1) 100"W X 52"D X 7" Rise Step 2) 78"W X 52"D X 7" Rise Step 3) 56"W X 52"D X 7" Rise So I don't do much concrete work, but it's part of a job and here I be. I'm a little confused, still, about how to go about calculating how many bags (renting a mixer) to use. I come up with some pretty outrageous numbers... I would just hire a concrete company, but the house is in a logistically-challenging situation and a truck will be hard-pressed to get a chute over to the spot. Please pardon my obtuseness... or have at it! But any (useful) advice would be great! Thanks. |
#37 |
Trade: Masonry
I rounded up to the nearest foot and came up with 6.3 bags http://www.concretenetwork.com/concr...calculator.htm
#38 |
Pompass Ass
Re: 80 Lb Bags Of Quikrete |
#39 |
The Old Master
Trade: Plumbing & Heating
| pink framers bags | cwilson | Tools & Equipment | 24 | 01-30-2012 08:58 PM |
| Bags: store bought vs. custom | Scottsdale | General Discussion | 18 | 11-25-2009 09:28 PM |
| what tool boxes and bags do you use? | chippy uk | Tools & Equipment | 13 | 08-19-2007 12:42 PM |
| hangin up the bags | Scott Young | General Discussion | 11 | 06-01-2007 04:27 PM |
| bags of cement per yard | Rundog | Ceramic & Stone Tile | 1 | 04-23-2007 07:26 PM |
