6" Block For Foundation Wall
typically, 8" block is used in my area for foundation (crawl and basement) walls. I just ran across a bunch of 6" block-is it acceptable (by code) to use 6" and rebar/grout to get the strength of a standard non-grouted 8" wall? The question pertains to a 1 or 2 story structure w/ basement.
Trade: Residential Home Design/Custom Home Building
Re: 6" Block For Foundation Wall
I think if you bond it with the brick veneer. However I would check code.
I'm a Mac
Trade: ICF Construction
I do 6" structural pour in place walls all the time, above and below grade.
Guessing here for CMU, it would work if it was backfilled on both sides, such as a garage wall where you are building down below the frost line.
Chris |
Structurally it is fine, but code rules.
It ain't Rocket Science unless you are building rockets. |
Masonry walls under 9 ft high for a 1 story are allowed to be 6" by code. 8 inch becomes the minimum over 9ft.
does anyone build foundations out of 6" block? I've dealt with 4", 8" and 12"'s, but never knew there were 6" block! thanks for the feedback guys.
Trade: General Construction
Tom M is right about the code. I typically shy away from using 6" block due to to headache of having to run so far to get them in my area. I usally just go with an 8 out of sheer preference. But yes, a 6" can be used in some applications.
Trade: masonry
i have never laid a foundation with 6 inch block.most of the 6 in i have laid are for partion walls.
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
Trade: Masonry consultant
There is nothing wrong with using 6" block and it usually is a benefit to the owner.
If you have an unbalanced load, you may (not always) need some or more steel and grout. Just check local code, which is perscriptive and required for your area to be legal without using and engineer to use something different. If it is worth the money, you can always hire an engeer to come up with a different design. Unfortunately, American engineers and contractors are really not aware what can be done with masonry and what is being done elsewhere - I am being polite. I have seen groups of 5 to 20 apartment buildings that were 10 to 22 stories built using 6" load bearing block that were partially reinforced. There were no steel or concrete columns - just knowledgeable suppliers, contractors and engineers.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
| Does fireplace opening in block wall opening need support? | Square-One | Masonry | 6 | 11-22-2008 02:31 AM |
| framing against block wall | JohnHomeMatters | Framing | 12 | 10-01-2008 10:19 PM |
| How to cap off 8" concrete block wall | Michaeljp86 | General Discussion | 18 | 09-20-2008 08:18 AM |
| Smooth over painted block wall | karma_carpentry | Painting & Finish Work | 5 | 05-22-2008 07:58 AM |
| Does fireplace opening in block wall opening need support? | Square-One | Construction | 1 | 02-28-2006 01:59 AM |
