1st Row Of Bricks On Lentil Dry, In Mortar, Or Either?
Old 08-19-2008, 10:32 AM   #1
TomBrooklyn's Avatar
Trade: Roofing, Waterproofing (Thoro, pointing), Masonry (mostly chimneys, lentils, parapets)
Question
When putting the first row of bricks on a lentil, is it OK to put them on the lentil dry (without mortar?). Or should they always be in a mortar bed, or does it matter?
I had a situation yesterday where I put a row in dry because I had just about enough room for a row of mortar above.
Today I have a situation where I'd like to put in a thick mortar bed because I don't have enough room for three rows of bricks, but two rows is short and I have to use wide mortar joints.
This is for the opening for a basement door below a front porch.
TomBrooklyn is offline
Old 08-19-2008, 12:31 PM   #2
stacker's Avatar
Trade: masonry
Re: 1st Row Of Bricks On Lentil Dry, In Mortar, Or Either?
i have never had a problem laying them dry or with a mortar bed.most times if your lentil is put directly on the top of a brick,then the thickness of the lentil makes up for lose of a mortar bed,therefore mud is not needed.
stacker is offline
Old 08-19-2008, 12:33 PM   #3
Tscarborough's Avatar
The most import thing to determine if you place a bed joint will be continuity of the coursing with the rest of the wall. I have seen it both ways.
Tscarborough is online now
Old 08-19-2008, 10:31 PM   #4
Tommy C's Avatar
Trade: Mason
Send a message via AIM to Tommy C
Lentils are what goes in my mother's soup. A Lintel is an architectural detail.
Just messin' with ya...both methods are fine.
Tommy C is offline
Old 08-21-2008, 04:16 PM   #5
OK. Thanks. Cheers.
Old 08-28-2008, 05:58 PM   #6
menber
masonking02's Avatar
Trade: bricklaying
i would only use mud on a lintel to cacth my hights if im a low crossing over the jams
masonking02 is offline
Old 08-28-2008, 06:02 PM   #7
mickeyco's Avatar
Trade: Squirrel Handler
After 40 or 50 years they crap out, why not use stainless (I know cost) or coat them with something? They appear to come with a primer coating, do you guys paint them or just slap them up?
mickeyco is offline
Old 08-28-2008, 06:09 PM   #8
menber
Trade: bricklaying
we use galvanized lintals so they dont rust over the years
Old 08-28-2008, 10:10 PM   #9
raskolnikov's Avatar
Trade: masonry
Hey mickeyco,
We paint it all, lintles, dampers, cast fresh air feeds, it just adds to the shelf life! A couple of cans of Rustolium aint gonna break the bank and it help's to seperate the men from the boys! Although I'd like to be a boy again...
D.
raskolnikov is offline
Old 08-28-2008, 10:37 PM   #10
Where I get mine they come with a light coat of rust. I didn't paint them as I wanted to get them in right away, but I'll paint the underside and edge (it's over a door.)
If I thought about it, I could have thrown a coat of rust proof primer on it. Next time I will. Good idea.
Old 08-28-2008, 10:42 PM   #11
We install galvanized gutters and leaders sometimes. They rust out eventually. I don't think they last any longer than aluminum although I could be wrong. They both last around 25+ years.
Old 08-28-2008, 11:17 PM   #12
Primed and flashed, they will last a couple hundred years if not for the lifetime of the building.
Old 08-29-2008, 10:48 PM   #13
cvspude's Avatar
Trade: masonry
a row of brick
cvspude is offline
Old 08-29-2008, 11:02 PM   #14
tkle's Avatar
Inside the house,the only thing affecting the angle iron is heat. They would have to be repainted often. On the outside I don't leave them exposed. I notch my brick around them.
tkle is offline
Old 08-29-2008, 11:07 PM   #15
mickeyco's Avatar
Originally Posted by cvspude View Post
a row of brick
course of bricks
mickeyco is offline
Old 08-30-2008, 09:13 AM   #16
6stringmason's Avatar
Trade: masonry
course of bricks
of course
Kamps Masonry & Concrete Countertop Design Green Bay, WI
920-680-3195
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 08-30-2008, 04:01 PM   #17
Gatorate's Avatar
Trade: Retired
deleted
Gatorate is offline
Colored Mortar ophnurse Masonry 8 02-14-2009 09:50 PM
Custom-formulated concrete & mortar - or overkill? bob_cntrctr Masonry 5 06-05-2008 07:58 AM
Should I Demo Up The Existing Mortar Bed For New Marble? bluethumbnail Ceramic & Stone Tile 3 01-14-2008 08:12 PM
Mortar Bedding for Stone on Concrete Question. lukachuki Masonry 10 05-26-2007 10:09 PM
Changing mortar color? kcrossley Masonry 1 12-17-2006 01:44 AM
