12ft High 2" Stone (slate/shale) Veneer. Rock Fall Hazard? - Page 3 - Masonry - Contractor Talk
Old 09-28-2016, 06:22 PM   #41
Windycity's Avatar
Trade: Masonry
Rewards Points: 6,200
Re: 12ft High 2" Stone (slate/shale) Veneer. Rock Fall Hazard?
Originally Posted by superseal View Post
You could also broadcast blasting sand into your fresh sealant...two part sealants would be the premium choice in terms of quality.
Looks great. Do you add the sand immediately after you caulk it or do you wait a few?
How do you like using the sausage gun? I have never used one before but recently I watched someone else using one and i want to get one to try it out. Looks smooth ...not exactly cheap though but i fill enough expansion joints i think it would be worth it
Windycity is offline
Old 09-28-2016, 09:51 PM   #42
Renaissance Man
superseal's Avatar
Rewards Points: 5,590
You add it as soon as possible to get the best tack...In terms of sausage guns, the one I showed is actually a bulk gun I run 2 part sealants through. Not much different than a sausage except for the internal piston selection which can be easily modified.
I use pretty much nothing but Albion guns because I think they're the best and happen to be locally available and my supplier carries all the replacement parts and accessories.
1 part products are surely okay, but once you go 2 part, you'll experience a higher quality, but most importantly,...a tooling factor that cannot be beat.
Some of my guns can hold a serious amount of sealant, hence less filling and more work getting done...perfect for large control joints where you're sucking up a lot of material.
12ft high 2" Stone (slate/shale) Veneer. Rock fall hazard?-img_1657a.jpg   12ft high 2" Stone (slate/shale) Veneer. Rock fall hazard?-img_1668a.jpg   12ft high 2" Stone (slate/shale) Veneer. Rock fall hazard?-img_1669a.jpg   12ft high 2" Stone (slate/shale) Veneer. Rock fall hazard?-img_1671a.jpg   12ft high 2" Stone (slate/shale) Veneer. Rock fall hazard?-img_1686a.jpg
12ft high 2" Stone (slate/shale) Veneer. Rock fall hazard?-img_1676a.jpg
supersealconstruction.com
superseal is offline
Old 09-29-2016, 10:30 PM   #43
RedBaronww1's Avatar
Trade: Log Homes
Rewards Points: 102
Thanks for the photos that looks great, I like the idea of blasting the sand in, gives the texture I was hoping for. I have the same style of gun we use it for chinking the log work. I could probably use the same chinking (https://www.permachink.com/log-sealants/energy-seal) for the control joints and find a dark sand.
We also have a bunch of backer rod left over from the log work.
I will look into that Siloxane PD.
I'm still having a hard time deciding where to put the control joints. It seems to me the corners would be best as they are the junction of the aspects and temp gradients however the control joints would be much shorter and less noticeable running them through the door and window openings.
Thanks guys, planning on washing things up tomorrow then pointing it up on Monday. I will get some pics once its all cleaned up.
all the best
RedBaronww1 is offline
The Following User Says Thank You to RedBaronww1 For This Useful Post:
asevereid (10-05-2016)
Old 10-01-2016, 06:56 PM   #44
Windycity's Avatar
Trade: Masonry
Thanks for the info, i guess i need to bite the bullet and just buy some stuff and give it a shot. I do enough caulking to justify it. Alot of the "wider" joints i finish are acceptable but me being critical of myself i look at them and think they look like chit...so I definitely am interested in the 2 part sealant finishing better. Does the two part products come in any smaller quantities or are they all in large pails? After it is mixed how much work time do you have and is there any shelf life if there is leftover product IE can you save it for a later date? I have done a quick search online but cant really find any good info about the 2 part stuff...
Thanks superseal!
Sorry to hijack your thread OP, looking forward to the finished pics!
Old 10-01-2016, 07:29 PM   #45
Renaissance Man
superseal's Avatar
Thanks superseal!
Tremco Dymeric 240fc is packaged in 1.5gal and 3gal with pre measured curative and color packs. The 1.5 is shown in the picture.
I use a lot of Sika as well...manly 2C NS. Same packaging sizes but less color oppurtunity with 40 colors...Tremco has 70 colors.
Once you mix it, you gotta use it. Pot life is approx 3 to 4 hours depending on temps.
The Following User Says Thank You to superseal For This Useful Post:
Fouthgeneration (10-08-2016)
Old 10-01-2016, 07:31 PM   #46
Renaissance Man
superseal's Avatar
http://www.tremcosealants.com/category/sealants.aspx
http://usa.sika.com/en/construction-.../sealants.html
Here's some links windy if you need them...
Old 10-01-2016, 08:00 PM   #47
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,712
I use Albion guns too, great company to deal with.
Inner10 is online now
Old 10-02-2016, 03:06 PM   #48
Windycity's Avatar
Trade: Masonry
Thats for the info guys! I went to albion website and they have a couple short videos about their guns and the different types of pistons, etc giving me enough info so i know the differences. There is a supplier close to me so if i have a chance i will stop in there this and talk to them..
Old 10-02-2016, 03:44 PM   #49
Inner10's Avatar
Choose the right piston, I found out the hard way the rubber one reacts badly with Yellow77.
Old 10-05-2016, 01:02 AM   #50
Trade: Log Homes
Rewards Points: 102
Finished the rock work but have held off on grouting the joints. I have been talking to my friend again and he had a good idea to put up the seal coat and then groute them like regual tile and skip the whole groute bag **** show as the joints are 1/4" and the grout bag seems to clog up and I need to cut the end at 1/2".
Currently I do like how you can see the cracks with the dark shadow between them. If I go with grey I'm thinking the rocks will really blend however I think black is to dark so I'm going to aim for a dark grey.
What do you guys think about this method, maybe I should go with two seal coats does Siloxane PD give a really tight seal? I have never grouted slate tiles but I'm guessing the same process would work just iregular lines.
Here is a pic
Old 10-05-2016, 10:48 AM   #51
fjn's Avatar
Trade: mason
Rewards Points: 9,560
Here is a pic
Get a jar of this stuff,it is like adding grease to the grout.
https://www.amazon.com/Gibcos-MRF-Dr...ords=gibco%27s
fjn is offline
Old 10-05-2016, 04:18 PM   #52
Windycity's Avatar
Trade: Masonry
Here is a pic
I think it would be a mistake to try and grout that way, probably make more of a mess smearing grout on the face needing more washing...if your bag is clogging up use a plasticizer like FJN recommends and also make sure that your sand/cement is screened to make sure there is no rocks/chips/lumps that you mix into the bag...personally i dont like bags cause the mix needs to be a little looser and I usually make more of a mess. I prefer to use a hawk and mud that is a tad stiffer. This works better for me and i can work faster and make less mess on the stone face. People have their preferences and i dont have a lot of experience using a bag so i prefer not to use it
Old 10-05-2016, 04:25 PM   #53
JBM's Avatar
Trade: Masonry
Rewards Points: 5,442
Are you using pre bagged stuff, cuz that stuff is sh!t for grout bags. Get mason sand and type n powder. I would have just washed it when I was done.
JBM is offline
Old 10-05-2016, 11:55 PM   #54
Trade: Log Homes
Rewards Points: 102
Thanks guys, I will order some of that grease thats a great idea. I have been buying sand from a local supplier that screens it. Its very low clay content and the sand grains are fairly big both which probaly make it challenging to bag. I'm mixing it with lafarge concrete. Our hardwarestore doesnt bring in any type S OR N mix.
Looking at those caulking guns made me curiouse about the mortar guns. Anyone used those with any luck? I would imagin they would work better then a bag and with the differnt kinds of nosiles one would think you could get pretty accurate with it.
Still havent grouted I started doing another job while I think about how to best do this. Was thinking about waiting until spring to do it as were only 3-5 weeks before things really freeze up around here.
Old 10-06-2016, 02:39 PM   #55
JBM's Avatar
Trade: Masonry
You might have to find a masonry supply yard. But even lowes and homedepot sell powdered type n mortar that you add sand to around here.
Im not sure what you mean by lafarge concrete?
If you cant get the mortar to go through a bag it will never work in a mortar gun.
JBM is offline
Old 10-06-2016, 04:27 PM   #56
Renaissance Man
superseal's Avatar
This is hawk and slicker country if I ever seen it.
I would do it all with a stiff 2.5:1 mix whipped into a consolidated lump using a 1/4" or 3/8" Rose type slicker.
A nice bucket trowel and hawk, a horsehair brush and a loop handle wire brush used at thumbprint hard for a perfect finish.
Take your horsehair on a final brush and you're done...no cleaning, no pre-seal and no mess.
Imagine me doing that in a raised ribbon technique...would knock your socks off.
JBM (10-06-2016)
Old 10-06-2016, 05:29 PM   #57
Windycity's Avatar
Trade: Masonry
Lafarge is a manufacturer of bagged mortar cement...thats what i use as well as brixment..they are the two more common ones round here
The Following User Says Thank You to Windycity For This Useful Post:
JBM (10-06-2016)
Old 10-06-2016, 06:12 PM   #58
JBM's Avatar
Trade: Masonry
Yes we have it here as well, was wondering about the concrete part
JBM is offline
Old 10-07-2016, 12:57 AM   #59
Trade: Log Homes
Rewards Points: 102
lol Sorry had a long day meant to say cement not concrete. That would sure make for problems in the grout bag.
Thanks for the tip superseal. I really like the low mess factor!
As for the Lafarge cement I dont think it has any special additives. On there site they say its "A general-purpose cement suitable for all uses for which the special properties of other types of portland cements are not required"
I find it a bit confusing as I always thought type N just referred to the ratio of cement to sand eg/ 3 parts sand to 1 part cement and type S 2:1. Does the Type N cement have special additives like polymers or Lyme?
Looking on there site Lafarge also makes type N and S and a whole bunch of other cements. Its interesting to me as no one around here use's anything but the general purpose cement. I tried convincing the hardware store to bring in some type N but they couldn't source anything out.
Old 10-07-2016, 02:07 PM   #60
JBM's Avatar
Trade: Masonry
The link I will add shows that psi of the mortars as well as the ratios that make each. The higher the psi the less lime and more portland that is used.
http://www.engineeringtoolbox.com/mo...es-d_1735.html
JBM is offline
Installing felt over block chimney for veneer stone Gary Birk Masonry 16 04-11-2016 10:00 PM
Installing veneer stone work on a metal building Jethroe Masonry 16 03-13-2016 05:48 PM
Stone veneer and code question N Carolina mkc1962 Masonry 16 02-11-2015 08:20 PM
Veneer Kitchen Stone ArtisticDecks-Bob Decks & Fencing 2 05-20-2014 11:38 AM
Finally upped some videos from last fall - in Afghanistan wallmaxx Framing 8 05-27-2012 11:05 PM
