Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Community > Contractor Swap
Old 10-03-2009, 11:20 AM   #1
Electron Flow Manipulator
480sparky's Avatar
Trade: Electrons for cash
Progressive 2003 Cable Fault Locator
Near-new Progressive 2003 cable fault locator.
You can see this is in 'good-as-new' condition... it's not torn up or beat to death. It works just fine as I have tested it a couple times.
It also comes with a home-made A-frame:
Yea, it looks home-made, but it does the job intended!
$425, shipped anywhere in the lower 48 states.
The transmitter needs a new battery as it doesn't hold a charge, but I will get one and install it before I send it out.... I thought I'd hold off spending money on that to see if someone was actually interested in buying this first.
I've using my other one several times to pinpoint (OK, not pin-point, but within ¼" of the actual fault!) broken and damaged cables more than enough times to pay for it several times over.
This would be a great addition to anyone's tool arsensal.
Age is just a number but mine is unlisted.
480sparky is online now   Reply With Quote
Old 10-12-2009, 09:12 PM   #2
480sparky's Avatar
Sale pending.
Old 11-04-2009, 04:27 PM   #3
480sparky's Avatar
Sold.
Display Modes
Running DATA Cable, New Construction spoolin Low Voltage 31 10-16-2009 10:34 AM
floor heat cable metal lathe floor mix carterarce Ceramic & Stone Tile 9 02-01-2009 11:51 AM
Satellite / Cable-TV exterior cable routing bob_cntrctr General Discussion 10 11-25-2008 02:31 PM
High Speed Cable & P.O.T. Separation? redzthredz Low Voltage 10 11-05-2008 01:43 PM
Cable Locator vans Tools & Equipment 2 08-13-2007 06:46 AM
