Need Urgently Reply
Old 01-06-2008, 09:39 PM   #1
Raymond888's Avatar
Trade: Aluminium doors and windows, Curtain Wall
Need Urgently Reply
Hi, everyone.
I hope anyone can reply my question.
How can i find all the regulations of Aluminium doors and windows online??
The regulations contain certifications, CE standard,.....
If anyone knows how to find, pls contact me on MSN.
My MSN is shiwei_1126@hotmail.com
Or you can reply via the email,
my email is shiwei_1126@hotmail.com
Thank you in advance!
Maggie
Raymond888 is offline
Old 01-06-2008, 10:15 PM   #2
General Contracting
LNG24's Avatar
Trade: Real Estate Broker, Property Manager
Re: Need Urgently Reply
Nothing in a Google Search?
A Better question would be; Why are you posting this is Contractor Swap?
LNG24 is offline
Old 01-06-2008, 10:21 PM   #3
mdshunk's Avatar
A. American National Standards Institute (ANSI)
1. ANSI A250.4- Test Procedure and Acceptance Criteria for Physical Endurance of Steel Doors and Hardware Reinforcements
2. ANSI A250.8‑ Recommended Specifications for Standard Steel Doors and Frames.
B. American National Standards Institute / Builders Hardware Manufacturers Association (ANSI/BHMA)
1. ANSI/BHMA A156.1‑00. American National Standard for Butts and Hinges.
2. ANSI/BHMA A 156.2‑96. American National Standard for Bored and Pre‑assembled Locks and Latches.
3. ANSI/BHMA A156.3‑01. American National Standard for Exit Devices.
4. ANSI/BHMA A156.4‑00. American National Standard for Door Controls‑Closers.
5. ANSI/BHMA A156.5‑01. American National Standard for Auxiliary Locks and Associated Products.
6. ANSI/BHMA A156.6‑01. American National Standard for Architectural Door Trim.
7. ANSI/BHMA A156.7‑03. American National Standard for Template Hinge Dimensions.
8. ANSI/BHMA A156.8‑00. American National Standard for Door Controls‑Overhead Stops & Holders.
9. ANSI/BHMA A156.13‑02. American National Standard for Mortise Locks and Latches.
10. ANSI/BHMA A156.15‑01. American National Standard for Closer Holder Release Devices.
11. ANSI/BHMA A156.16‑02. American National Standard for Auxiliary Hardware.
12. ANSI/BHMA A156.18‑00. American National Standard for Materials and Finishes.
13. ANSI/BHMA A156.21‑01. American National Standard for Thresholds.
C. American Society for Testing and Materials (ASTM)
1. ASTM A 153- Specification for Zinc Coating (Hot‑Dip) on Iron and Steel Hardware
2. ASTM A 653‑ Specification for Steel Sheet, Zinc‑Coated (Galvanized) or Zinc‑Iron Alloy‑Coated (Galvannealed) by the Hot‑Dip Process.
3. ASTM A 924‑ Standard Specification for General Requirements for Steel Sheet, Metallic‑Coated by the Hot‑Dip Process.
4. ASTM C 518‑ Standard Test Method for Steady-State Thermal Transmission Properties by Means of the Heat Flow Meter Apparatus
5. ASTM E 283‑ Standard Test Method for Determining Rate of Air Leakage Through Exterior Windows, Curtain Walls, and Doors Under Specified Pressure Differences Across the Specimen
6. ASTM E 330‑ Standard Test Method for Structural Performance of Exterior Windows, Doors, Skylights, and Curtain Wall by Uniform Static Air Pressure Difference.
7. ASTM E 331‑ Standard Test Method for Water Penetration of Exterior Windows, Skylights, Doors, and Curtain Wall by Uniform Static Air Pressure Difference
8. ASTM E 1886 Specification Test Method for Performance of Exterior Windows, Curtain Walls, Doors, and Impact Protective Systems Impacted by Missile(s) and Exposed to Cyclic Pressure Differentials.
D. American Society of Civil Engineers (ASCE)
*ASCE 7-98- Minimum Design Loads for Buildings and Other Structures
E. Factory Mutual (FM)
1. FM, Factory Mutual Approval Guides.
F. Federal Emergency Management Agency (FEMA)
1. FEMA 361 Guidelines
G. International Code Council (ICC)
1. International Building Code 2000 (IBC)
H. National Fire Protection Association (NFPA)
1. NFPA 101, Life Safety Code.
I. Steel Door Institute (SDI)
1. SDI 105‑ Recommended Erection Instructions for Steel Frames
2. SDI 117‑ Manufacturing Tolerances for Standard Steel Doors and Frame
3. SDI 122‑ Installation and Trouble Shooting Guide for Standard Steel Doors and Frames
J. Underwriters Laboratories Inc. (UL)
K. United States Department of Energy (DOE)
1. DOE Order 420.1, Facility Safety
2. *DOE-STD-1020-94 Natural Phenomena Hazards Design and Evaluation Criteria for Department of Energy Facilities (including Change Notice #1 dated Jan 1996)
3. *DOE Newsletter dated January 22,1998 Interim Advisory on Straight Winds and Tornadoes
L. Waste Treatment Plant (WTP) Standard Guidelines
1. 24590-WTP-DC-ST-01-001, Structural Design Criteria
mdshunk is offline
Display Modes
Would you even respond to this person? wackman General Discussion 72 11-28-2007 10:11 PM
Take a glance and feel free to reply tlfettled Drywall Picture Post 2 09-17-2007 01:38 AM
Why I'll never do business with SKIDSTEERSOLUTIONS.COM finehomes Excavation & Site Work 37 08-28-2007 10:09 PM
Raises, How often do you give them saucedo80 Business 16 09-22-2006 11:45 PM
Brutusthedag here’s my reply to your deleted spam post. Peladu Off Topic (Non Trade) 1 09-20-2006 09:03 PM
