Trade: Drywall
2008 8 X 20 Enclosed Trailer With Tandem 10,000 Lb Axels.
I bought this 2008 trailer for my business and to haul my Buicks. I have had my Regal in it to check clearances, and it fits well with about 3’ clearances in front of vehicle, and circa 10” on either side. It is however a little to small for its primary business purpose, and I would like a 24’ trailer. The trailer has less than 3000 miles on it as of this date. I installed five outlets, two lights and a breaker box, as well as a propane heater. These items can be removed it they are not needed. There are two holes drilled through the floor for the gas line and the power cord, and various wall ties screwed onto the walls. These can be removed with little effort, and are secured by drywall screws. The specifications/dimensions can be found below. Clear title…located in south central Nebraska…Hastings, zip 68901.
Trailer without additional electrical/heater. $5400.00 Trailer with additional electrical /lights/heater. $5800.00 Trailer details: Manufacturer: Carry-On trailer, built in Missouri Valley, IA. Framing members: ceiling 2’ on center with Ύ” wall and floor sheathing. · 9990 lb. GVWR · 15" Tires · Bright Aluminum Fenders · Treated Plywood Flooring · Front Stone Guard · Long Life LED Tail Lights · Fully Lighted to D.O.T. Requirements · Sporty Rear Aluminum Dressing · Galvalume Steel Roof · Aluminum Exterior Siding · Tandem 5200 Spring Axles · Brakes on Both Axles · Trailer Tongue Jack · Interior Lighting · Rear Ramp Door · Side Door . 4, D ring tie downs in floor. . Electronic breakaway system for trailer brakes. Interior dimensions: Form wheel well to wheel well 82”... 6’10” From side wall to side wall 90 ½”... 7’ 6 ½” Front to back 238”... 19’ 10” Peak height 78”... 6’ 6” Rear door 82” W X 70 H... 6’10” X 5’ 10” Side door 36” W... 3’ Last edited by Cole; 01-05-2008 at 01:27 PM. Reason: Moved to Contractor Swap! |
Trade: Counter tops & Fiberglass
Re: 2008 8 X 20 Enclosed Trailer With Tandem 10,000 Lb Axels.
looks like a great rig, I just bought a countertop business and need one!!
Still available?? I'm in Fremont NE What is your tow vehicle? how does it handle the resistance? Does the heater have a thermostat? to keep constant temmp over night. how much LP comsumption on low over night, do you use it like that? Waiting to hear form you, need to do something by months end!! Swendog |
Trade: Drywall
Swen,
The trailer is still available, no one has sent a deposit. I will try to answer your questions. What is your tow vehicle? how does it handle the resistance? I tow with a Ύ ton diesel, and do not have any issues with handling. Does the heater have a thermostat? to keep constant temmp over night. Yes, the heater does have a thermostat. how much LP comsumption on low over night, do you use it like that? I do not run it over night, but the heater has been used for up to 14 hours at a time. The tank size is 100 lbs ,and estimate it would run between120 to 160 hours from the tank depending on the setting. It cost me $52.00 to fill the tank. SOLD Thanks, Patrick Last edited by Plains Drifter; 02-03-2008 at 09:18 PM. |
| Display Modes | |
| Enclosed trailer suggestions | Wellcraft | Tools & Equipment | 49 | 03-03-2008 09:03 PM |
| WTB Apla-Tech producs and an enclosed trailer | hutch04 | Drywall | 6 | 03-03-2008 01:08 PM |
| enclosed trailer for sale | jb3628 | Contractor Swap | 18 | 09-12-2007 08:48 PM |
| WTB used enclosed trailer (upper midwest) | Humble Abode | Contractor Swap | 0 | 08-28-2006 12:15 PM |
| to all enclosed trailer owners | Starboyz66ftp | Vehicles | 6 | 04-30-2006 12:16 AM |
