Radiant Supplier With Questions
Old 01-26-2009, 03:05 PM   #1
Radiant Heat
Kengineer's Avatar
Trade: Electric Radiant Floor Heat
Howdy, folks!
I'm a Pacific NW supplier of electric radiant heat. I have been at this a while, living in a comfort zone of installing under tile. Now I'm trying to bring some solutions to my customers who want to install under laminate, vinyl, and hardwood. So I'm asking the experts how they get their best results with a conventional wire product, and I also have some questions about a new material I am thinking of introducing. Anything you can share about radiant, particularly electric radiant under laminate, would be MOST appreciated. I am posting more specific questions in the forums.
Kengineer is offline
Old 01-27-2009, 06:08 PM   #2
Warmsmeallup's Avatar
Trade: Sales/Distribution/Installation of low or line voltage radiant heating and snow melting systems
Re: Radiant Supplier With Questions
Not much choice here Ken. The cable is inserted in a SLC first. Then whatever you want over the top. You just have to be sure that the glue manufacturer (if one is being used) is ok over radiant.
Warmsmeallup is offline
Old 01-27-2009, 08:29 PM   #3
Sean
SLSTech's Avatar
Welcome to CT, sorry but I can't see an electric product working under those products unless it is embedded in thinest or gyp-crete & then I bet it would probably void the manufacturers warranty
SLSTech is offline
Old 01-28-2009, 06:24 PM   #4
Hey SLS!
Check out ZMesh. It can go directly under carpet padding (though we suggest laying 1/4" luon over just to smooth out the runs), Pergo (and it's foam pad), hardwood etc...you can nail through it without a problem too.
Old 01-30-2009, 11:11 PM   #5
Crash Test Dummy
ChainsawCharlie's Avatar
Trade: Landscaping
Welcome to the site.
ChainsawCharlie is offline
Tags
hardwood, laminate, radiant
Tile over hydronic radiant heat angus242 Ceramic & Stone Tile 23 05-20-2010 10:06 PM
Insulation under Radiant? Kengineer Flooring 1 01-26-2009 03:54 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
Pricing questions Brian Painting & Finish Work 3 10-13-2007 09:38 AM
