I Would Like To Know The Best Way To Install 3/4 Hard Wood On Solid Slab Concrete
Old 09-21-2007, 09:51 PM   #1
amberwood425's Avatar
Trade: designer remodeling
hi to all i'm new to the site
amberwood425 is offline
Old 09-21-2007, 10:21 PM   #2
Super B
skyhook's Avatar
Re: I Would Like To Know The Best Way To Install 3/4 Hard Wood On Solid Slab Concrete
Hey Amberwood,
Welcome to CT
I could tell you what I've paid to have it done. Instead I'll let an expert answer your Q.
skyhook is offline
Old 09-26-2007, 09:29 AM   #3
woodman42's Avatar
Trade: commercial and residential remodeling
Welcome amberwood.
Did you say tool sale?
woodman42 is offline
Old 09-26-2007, 11:48 AM   #4
JacobCB's Avatar
Trade: Commercial and Residential General Construction
hello amber you might like this answer or you might not. The only way to fasten 3/4 hardwood to a concrete slab is to first lay down 4mil or thicker plastic vapor barrier then fasten down 5/8 or 3/4 pressure treated plywood sheathing to the concrete slab. This will give you a surface that you can nail your 3/4 hardwood to. The only type of floor that you can glue down directly to the slab without and vapor barrier would be an engineered floor, which is usually 3/8 to 5/8 of an inch thick.
JacobCB is offline
Old 09-26-2007, 12:19 PM   #5
I like 1X sleepers @12" oc over 6mil myself. Either way you have some real grief with doors, jambs, etc. And 1˝" transitions are pretty ugly,MHO.
neolitic is offline
Old 09-26-2007, 12:59 PM   #6
Mod / ArchiBuilder
Cole's Avatar
No real easy way to attach hardwood to a slab unless you planned for this from the beginning. That way, things could have been designed and done the correct way so that you do not have 1 1/2" transitions stated above.
Cole is online now
Old 09-26-2007, 06:07 PM   #7
Grumpyplumber's Avatar
Trade: Plumber
I've had to install radiant floor panels over concrete (owner decided to add this, after the slab was long since poured).
We put down insulation/vapor barrier, then used tapcons to tack down the panels.
The tapcons predictably don't all hold, but a ramset woulda split the panels.
Grumpyplumber is offline
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
Basement slab question n74tg Masonry 5 05-26-2006 04:38 PM
Re-routing copper pipes in slab DRIFT-O-MATIC Construction 7 12-18-2005 04:36 PM
Wood on concrete slab Unregistered Flooring 3 02-05-2005 09:18 PM
How to Install Solid Hardwood Flooring on Concrete Foundation gilamherst Flooring 13 02-05-2005 07:02 PM
