I Need A Perfect Arch And I Dont Have The Room
Old 03-22-2007, 12:19 AM   #1
newnoise's Avatar
Trade: carpenter
quick question does anyone know how to get a perfect arch with out using a nail a tape and scribing it on a sheet of plywood ...i dont have the room for this. i did the math and i would have to be like 50 some odd feet away from the top of the arch to scribe an arch that is 16 feet wide and only drops 6 inches from the center to the side
newnoise is offline
Old 03-22-2007, 12:27 AM   #2
Forry's Avatar
Trade: General Contractor, Remodeler
Re: I Need A Perfect Arch And I Dont Have The Room
Saw a formula in the best tips thread....
Forry is offline
Old 03-22-2007, 12:38 AM   #3
newnoise's Avatar
Trade: carpenter
wheres that
newnoise is offline
Old 03-22-2007, 12:44 AM   #4
Forry's Avatar
It's called "Share aTip - 50 words or less"
In general discussion
Forry is offline
Old 03-22-2007, 09:51 AM   #5
Charitable animal
Bone Saw's Avatar
Trade: decks
Bone Saw is online now
Old 03-22-2007, 12:20 PM   #6
reveivl's Avatar
Trade: Renovations
Newnoise, you're looking for a circular arch or elliptical? Or some other shape?
Circular, go outside and draw it on two pieces of ply with your string.
Elliptical, you'll need to do a bit of research on how to build the appropriate jig. Basically it's a "T"-shaped (or "X" for the full ellipse, not a 1/2) jig with two sliding connections attached to a wand that holds your pencil (or router). Google "ellipse jig" and you'll get the idea.
Other shapes, cut some thin stock and bend it to the shape you like then mirror it for the other side.
reveivl is offline
Old 03-22-2007, 06:12 PM   #7
woodfreak40's Avatar
Trade: General contracting
If you are in the field try putting 2-1" pvc pipes together (not glued) on each end of the 16 ' set the center on your 6" centerline and trace it.
"Smile, it makes them wonder what your up to"
woodfreak40 is offline
Old 03-24-2007, 03:20 AM   #8
newnoise's Avatar
Trade: carpenter
thanks every body that was very helpful with the srch . p.s hand cuttin a roof is alot of work whew!
keep fit and have fun
newnoise is offline
Old 03-27-2007, 08:56 PM   #9
Central Florida Painter
YourWayPainting's Avatar
Trade: Painter
Welcome newnoise.
A good paint job isn't cheap. A cheap paint job isn't good.
YourWayPainting is offline
frame and sheetrock an arch ch0mpie Carpentry 30 12-08-2010 12:00 PM
Question about a arch building? wraiths Electrical 2 10-24-2006 09:00 PM
Arch fault breakers edirector Electrical 17 08-25-2006 03:27 PM
Timber frame arch & Iron need sources Oregon_Rob Carpentry 0 07-27-2006 01:03 AM
Arch prices 6stringmason Masonry 4 02-28-2006 07:41 AM
