I'm considering buying a cargo van for my next work vehicle. The problem is, I live in a relatively rural area of Wisconsin and we get quite a bit of snow/sleet/ice. I'm worried that a 2wd van won't hack it. I also don't know if a 1/2 ton awd Chevy van can handle enough weight for me and those 4x4 conversions are a little out of my price range.
Any how, every time I ask another local contractor how their van works in winter I get the old, ah it works fine. The thing is most guys around here (myself included to some degree) tend to just make things work and I want the vehicle to work WELL.
Anyone have any personal opinions to share about using vans in snowy areas? Thanks!
I started running 2wd cargo vans in the late 90's. I live in northern maine. We get a lot of snow, I mean feet apon feet. i run studded tires all the way around them and do ok. Now dont get me wrong, its far from a 4wd pickup but it will work. I tend to have alot of weight in mine so that helps alot. Usally when we have a large storm over 16" i take the day off. But as far as icy roads, light snow, my van seems to do pretty good. But i wouldnt want to go threw a winter up here without studs, thats for sure!:thumbsup:
I used to drive a pair of late 80's G20's (back in my youth, when they were new) in upstate NY delivering radiators from New Paltz to Glens Falls and west past Schenectady. Studded snows, for sure. They did pretty good when loaded, empty not as good, but doable.
The worst part was the heat, or lack thereof. Get an auxiliary heater, brrrr.
I run a one ton van with BF Goodrich M&S All Terain tires on the rear. These things are great. !
I can go almost anywhere, never been stuck.
Part of the reason is there is weight in the truck. An empty pickup will not perform well in snow either. That's why transport trucks are not bothered by it as we are - weight.
I had 3/4 tons up until this new van. !/2 ton won't carry any weight. I would opt for a least the 3/4 ton.
You can buy four wheel drive vans. Are there a lot of hills in your area? I've seen vans tip over in the snow around here, but we have lots of hills, and people don't know how to drive. I think if everything is flat, and you have four wheel drive winter tires then you will be fine. I just had the Blizzack tires put on my truck and they work great in the snow. You can get a fairly good price at tirerack.com.
I run a 1/2 ton 2 wheel drive all year round while my 3/4 ton 4+4 sits in the driveway except to plow. I do carry a set of quick attach chains but have never used them.
I drive a 2WD E250 and it just plain sucks in the snow. I grew up in lake-effect snow territory north of Pittsburgh, so I've had some practice.
I will echo the comments above though--keep some good weight in it and a set of chains, and you'll do fine. Can't speak for studded tires, as they've never been legal where I've lived.
My old business partner had a 2wd full size van and we used to call it the [FONT=Arial, Helvetica, sans-serif]toboggan. The thing was awful in the snow. Never had studded snow tires or anything on the van but I'm sure that would have helped it a bit. [/FONT]
I drive a 2wd pickup which drives similar to a van. Rear wheel drive no weight over drive axle. I ordered the last 2 with a Posi rear, helps, but as posted above, too much snow, stay home.
He usually has around 10 60-70 pound sand bags that yu can pick up from the hardware store. He runs studded Hakkapellita tires on it, and it goes well. He keeps a set of chains in the back in case hes going up a long steep drive, or down a bad dirt road.
He will take it out in most any weather, as long as you take it easy and dont expect to drive like a 4x4 pickup, then it will do just fine.
Its obviously not perfect, but it does more than just "get by"
I used to drive a Dodge B100, short little bugger with the 318/auto. Being young i did a lot of burn outs with it thus blowing the rear end. I got lucky with a replacement that had a true Posi in it. The thing was a tank in the snow after that. So IMO spending some coin on a rear locker or a good clutch posi would be well worth the investment.
I've driven a lot of vans in my life---The Dodges were the worst in snow--the Fords the best--
Chevy not bad--Keep weight in the truck and good tires--That is the key--
Oh, and learn how to drive in snow----Around here most of the cars that I see stuck or rolled over are 4 wheel drive SUVs---An idiot could wreck a snow mobile--Mike--
They suck. I have had mine for 6 years now. Ford E350 extended which makes it longer and taller and able to catch the wind better. Going is not as bad as stopping. As with any vehicle, the driver makes a huge difference. Took me a couple winters to get used to how it handled in the snow. Good tires help but are not the cure all. I was out in mine today with not so decent tires and made it home alive with about 8" of snow throughout the day. Only one major slide and I was able to right it although it was close and required an underwear change after I made it home.
Thanks, another good point. I do have a 7 x 14 enclosed trailer. One of my thoughts with the van was to reduce the need to haul the trailer constantly. I can see towing that sucker in 2wd in winter sucking when I will need it though.
Vans suck in bad weather. If you can have 4wd installed-do it.... I bought a 2wd e-350 cutaway in 07 and if I had it to do over again, I would have spent the extra money to have 4wd installed.
Thanks for all the input! I wish studded tires were legal here in Wisconsin. I'm still unsure, I've gotten pretty used to my 4X4 GMC pickup.:thumbup: The thing I like the best about cargo vans is the relatively low price vs. a comparable 4x4 pickup. I don't know if it's worth it though.
I love my Van and cannot imagine driving a pick up, I will run down to the tire store as soon as I see a snow flake and have them put on the sonw tires for free that I bought last year.
It ran like a champ, just have to keeo out of the way of the 70 mph 4x4 SUV's
I have a Ford E250 and it's ridiculously bad in the snow.
I live in the land of drizzle so it's rarely a problem (once every couple years) but it's pretty well parked once the snow hits.
I need to go up a short minor gradient street to get to the main roads and it's pretty much not going to happen in that rig. When it snowed a couple years ago I took a flat shovel and scooped a trail down that silly little grade change. I'm sure I looked ridiculous but it got the job done.
RCT - first, the real spelling is Luxembourg to be authentic - from a Luxembourger (my great-grandfather lived north of Milwaukee).
4WD is a good bail-out for drivers that get themselves in trouble. I have a 4WD Jimmy (Micheline LXT M/S tires) and rarely use the 4WD, except in an emergency or unavoidable situation. It is worthless for stopping unless you gear down to get out of a problem created by a false sense of security or others. - It is fun to come up on a problem and shift down and go up and around people on a ramp, but that is rare.
Even when I go to lock in the 4WD in low range, it makes little difference in stopping or steering/control, but helps get out of bad situations, but does not use the engine to slow the vehicle if it is really slipper/icy. I switch to 4WD once or twice a year to make sure it functions.
You are in a relatively flat area, so stopping is more important than "bulling" your way through the wet snows and ice may you get. - Just from a old driver from MN and NE MI where the snow it not quite the same as yours.
When it comes down to basics, it is up to the driver to determine the needs. The problem comes if you have an employee that can't drive well and blames situations on the vehicle. If the guy can't drive and blames the equipment, ask a few questions.
Really good point about employees driving the vehicle. I had a helper a while back that always drove like a maniac. I'd have him take the truck to get materials and sh*t would be all thrown around inside when he got back. Best I can figure is he was taking corners like it was a Porsche or something. That guy would have a van in the ditch in no time!
Thanks for the info, by the way I always wondered why Luxemburg, WI is spelled the way it is and not Luxembourg like the country.:blink:
Our e150 handles like crap in the snow. Every winter it gets stuck even with snow tires and chains. 4wd drive makes a massive difference in the snow. I got stuck in my f150 quite a few time last year and 4wd saved me every time.
I could go almost anywhere I needed even in my '96 pontiac sunfire when it had snow tires on. I can't imagine an F150 stuck in the snow if you had snow tires on. Did you put some weight in the back of the truck?
Pretty much the only time I would ever get stuck while I have snow tires on is if the snow was higher than the bottom of my vehicle (taking the weight off the tires).
If you live in a place that gets a lot of snow, then it should be plowed away before it gets that high.
Yep we did a few times last winter. We had over 2 ft of snow in one night and we travel out of state a lot on work so also hit snow in other areas. They are ok vans if you can keep them on the road. Once you hit the grass the chains don't do nothing other than dig you deeper.
Here's one of the snow days from last year.
Related Threads
3.5M posts
151.3K members
Since 2003
