Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Vehicles
Old 10-15-2009, 07:50 PM   #1
van shelves out of luan
for past vehicles I've made solid aluminum (plank) shelving but can't find the same materials and have a lot of shelves to construct (08 Sprinter 170" ). I'm making shelf framing out of aluminum but considering glueing two layers of luan for added strength. Not a lot of weight-just tools, tool boxes and the sort. I'll use aluminum bracing every 2-3' under the shelf for structural stability. has anyone tried one/two layers of luan? birch/ply would be nice, but with 88LF of shelves, that could get real expensive. was hoping to stay away from 1/2" ply b/c of the weight (5 1/2 sheets!)
any other good ideas would be welcomed.
72chevy4x4 is offline   Reply With Quote
Old 10-15-2009, 08:41 PM   #2
SC sawdaddy's Avatar
Trade: GC, Remodels, New Homes, Whatevers biting
You are correct about the weight. I'm in the experimental stage now putting shelves in my new(er) van. I've pulled them out 3 times already because I keep trying to improve on them. I considered mounting a 3'x4' bolt bin for supplies but scratched it because of the weight factor.
If the guy thats going to do the lettering will get on the ball and get started, I can make the tool transfer from old raggley Dodge to new Dodge with payments and stop thinking about it.
I like the dbl luan idea. It will be slick though. May want to think about some rubber mats to keep tools from sliding around while driving.
I ended up making mine from 3/8 ply on 2x4 a frame.
Rubber mats were not in my budget, I put 3/4 x 3/4 divider strips every 10-12".
I also considered coating the shelves with some type of slip resistant...stuff.
Cool seal might work?
SC sawdaddy is offline   Reply With Quote
Old 10-15-2009, 08:44 PM   #3
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
Use aluminum expanded metal. Or just regular steel expanded metal.
Originally Posted by Gus Dering View Post
It may be just a gateway tool to the hard stuff. Be careful
WarnerConstInc. is offline   Reply With Quote
Old 10-15-2009, 09:54 PM   #4
lsat set of shelves I glued down cheap automotive carpet (the kind you get on a roll from auto part store) on the shelf. It soaks up oil, is easily vacuumed and keeps stuff from sliding. I used the 3M adhesive in a can and lightly misted carpet-has not pulled up in 2yrs.
The Following User Says Thank You to 72chevy4x4 For This Useful Post:
SC sawdaddy (10-16-2009)
Old 10-15-2009, 11:29 PM   #5
Faking my Way
TBFGhost's Avatar
Trade: Architectural Trim and Punchlist Work
3/4" 7 ply birch plywood is $37 at Home Depot around here....Not sure what the 1/2" price is but I would look into it, it might not be too much....
TBFGhost is offline   Reply With Quote
Old 10-16-2009, 07:27 AM   #6
Trade: carpenter/ handyman
You get what you pay for. Luan de-laminates easily. It won't hold up like the birch. I made the shelves for my Sprinter from 3/4 sheathing with 1x2 pine facing. Cheap & has held up well for almost 3 yrs.
http://www.contractortalk.com/f41/sh...ess-lwb-55906/
Steve
stp57 is offline   Reply With Quote
Old 10-16-2009, 08:13 AM   #7
Handle It!
MALCO.New.York's Avatar
Ozite!
http://www.ozite.com/
Do NOT use ANY other brand if you wish the carpet to stay set!!! (you MUST spray BOTH surfaces!!!)
8080
http://www.rochfordsupply.com/produc...?path=0210.jpg
or
90
http://images.smarter.com/300x300x15/40/36/566836.jpg
Neither is Inexpensive!!!
Ultimate Wisdom---------
http://www.youtube.com/watch?v=_k1Ug...ture=rec-HM-r2
MALCO.New.York is offline   Reply With Quote
The Following User Says Thank You to MALCO.New.York For This Useful Post:
Old 10-16-2009, 09:11 AM   #8
nEighter's Avatar
Trade: Painting/Framing/Drywall/Tile
let them slightly tack up before putting them together, AND you better have it where you want it.. no pulling the 2 apart after setting them together...
nEighter is offline   Reply With Quote
Old 10-16-2009, 10:24 PM   #9
Originally Posted by MALCO.New.York View Post
I carry a can of this adhesive on the truck-very convenient for fixing counter top ends that are popping off and other odd uses-not used often but very glad to have it when needed.
MALCO.New.York (10-25-2009)
Odd shelves for Odds and Ends wallmaxx Finish Carpentry 6 10-08-2009 12:42 AM
Brick shelves dakzaag Masonry 28 03-30-2009 06:20 AM
adjustable shelves for trailer? platinumLLC Vehicles 1 02-15-2009 12:57 AM
luan wall covering? boman47k Drywall 2 11-14-2008 11:30 AM
Stapling Luan????? diezeldawg Flooring 10 12-19-2005 10:58 PM
