Trade: Painting Contractor
Trailer Size
Hi guys. Quick question about trailer size. Anyone of you bought 6x10 trailer and after few months started think that you should buy one size bigger?? Advice needed...thanks in advance
ActivePainter |
The Deck Guy
Re: Trailer Size
Bigger is always better with trailers for the most part. A 610 fills up very quickly one you start fitting shelving in.
I'm a Mac
Trade: ICF Construction
Re: Trailer Size
The more space you have the more you will find stuff to go in the space, I run with a 8x24...it's pretty much full, if it wasn't for the axels and tires it would be overfull.
Chris |
Trade: Remodeling contractor
Re: Trailer Size
I run a 6x12. It's not perfect but it's made me a lot of money by not having to run to the store everytime I need something.
You have to organize it well and use every nook & cranny. I see too many guys have a big trailer and everything is just thrown in there. ![]() ![]()
Back in Maine Dubbin' Around Doin' good stuff ...... |
I like Green things
Re: Trailer Size
7x16 or 7x18 would be ideal. Trying to up grade my 7x14 but, I think the two sizes I mentioned earlier are the most popular and hard to find used.
Re: Trailer Size
Hello everyone . Do you guys protect the trailer floor from dirt, snow, rain somehow? How about applying industrial epoxy paint or spar varnish to seal the floor?? What do you think...Thanks
Grampy
Trade: Remodel & Repair Contractor
Re: Trailer Size
I have tread plate on my floor. I use a 6x14 low pro.
woodchuck2
Re: Trailer Size
"I run a 6x12. It's not perfect but it's made me a lot of money by not having to run to the store everytime I need something.
You have to organize it well and use every nook & cranny. I see too many guys have a big trailer and everything is just thrown in there." X2, my 7X14 is quite full and i keep it as organized as a i can. Some times the mess can get ahead of you and will take 3-4 hours to re-organize. But time is money and my trailer is a rolling hardware store. I hate not having what i need when i need it. It has cost thosands of dollars to stock up my trailer but it worth it to me. I used to keep all my tools is their cases but i found it was too easy to forget a tool somewhere if the case got closed, it took more time to pull the case for the tool and the cases were taking up alot of room. I now keep the tools out in the open on the top shelf with dividers, i can visually see at a glance of a tool is missing and they are at an easy reach. This gave me more room for supplies. My 7X14 is technically 16' long being a v-nose and it is not too bad to manuever around. I do alot of work on the lakes around here and those are the only tough driveways where i have any problems, we all know how steep and narrow those driveways are. As far as treating the floor i havent bothered, the little bit of sand that i track in gives me a non skid surface in the winter. My brother-in-law has a 6X10 with a covered floor and that damn thing is like being on a sheet of ice with wet feet. He is pulling the floor up this spring before he seriously gets hurt. |
woodchuck2
Re: Trailer Size
Here are a couple pics of mine, its fairly clean in these pics.
Trade: Pipe Cleaner
Re: Trailer Size
My 12' serves me well, other than its as old as the hills!
Trade: Custom deck builder
Re: Trailer Size
I have 6x12 and would like to upgrade to 8x20-24... Can always use a little more space.
Pompass Ass
Re: Trailer Size
I have an 8.5 x 20, thought about a 24' but it is too long.
#13 | |
Sean
Re: Trailer Size
ActivePainter, here is what I posted in a similiar thread
Trade: Pretty much anything with wood
Re: Trailer Size
I've got a 7x12 7k GVWR trailer. If I did it again I would go with the 7 wide but a 14'-16' length. You can always put more stuff in. I think a tool trailer with a single axle is no good. Those tools and fasteners weigh alot and they pile right in there quickly. I like the 7' width because it isn't much wider than a vehicle and be parked in a street space without sticking out too much and fits in spaces vehicles usually fit into. Sometimes 8' don't quite fit. If you are going over 12' I think the upgrade to 10k GVWR is necessary too. There is always the V nose too for a little more room. Just have to use it carefully.
Trade: Exteriors
Re: Trailer Size
I have 2 cargo mate..."Canadian name".... but I do know they are made in the States 16x8 trailers with built in roof racks.......... can`t beat the size Shelves on one side pole hangers on the other for cords hoses table saw and so on.... I need more posts for pictures though...
Trade: Carpenter/contractor
Re: Trailer Size
wood chuck, Im impresssed!
Trade: Painting in Utah
Re: Trailer Size
Painters need a little different set up, here is mine. I wanted smaller and lighter because I commute thru hills 45 miles each way!
#18 |
Carpenter/Finisher
Re: Trailer Size
I agree it does depend on the trade youre working in.
If your a typical gc/remodeler, the bigger the better (unless you work in chicago, Newyork, or some other over crowded area). and it depends on the size of crew that will be using it. i have a 6X12 and i think if i ever get around to building some smart shelves it should hold most of what i need it to. I had an 8.5X22 and that was a beast to get around town. i would rather have a 7X14-16 at full height...but i have to work with i got for now.
1st Gen tradesman My summer job in college became my profession |
#19 |
Trade: Historic Restorations
Re: Trailer Size
This trailer is 7x14 and is perfect for me. I quickly grew out of the 6x10.
#20 |
Trade: G.C. - Residential Endorsed
Re: Trailer Size
Was working out of a 32' Gooseneck horse trailer. Heavy duty and fine for the summer but what a pain to tow around town (parking) and not much fun in the winter. I removed most of what I commonly use and placed it in our 5x10 COSTCO trailer along with the 8' Service Body truck. Of course when we want to make a run to COSTCO I have to dump all my stuff out. At least I have it all in milk crates for the most part. Gooseneck to big and 5x10 to small. I agree with the common size of 7x14,7x16 or 8' wide, same length. What I have works fine but tight for room. I also have a 20' conex in the back yard full of tools that I dont normally use. I think the horse trailer will become a storage trailer for firewood next summer.
Will start looking for 7' or 8' x 14/16 come spring. |
| Enclosed Trailer Needed | thoelkeg | General Discussion | 6 | 03-12-2009 06:37 PM |
| Service body VS Enclosed trailer | EPD | Vehicles | 8 | 03-04-2009 09:41 PM |
| Trailer Size Advise | Bettercarpentry | Vehicles | 9 | 12-16-2008 08:31 PM |
| 2003 Asv rc-30 skid steer with 20' trailer, auger, snow plow, 2 buckets | kklick | Contractor Swap | 0 | 09-27-2008 07:33 PM |
| Couple of trailer questions for the pros | Mike Finley | Vehicles | 38 | 12-07-2006 12:36 PM |
