Trailer Ladder Racks
Old 01-07-2007, 07:21 PM   #1
ch0mpie's Avatar
Trade: Geotechnical PE
I want to put ladder racks on my trailer but I'm not sure what kind to go with. The ones for vans won't really work because the roof is rounded. I've considered the trac-rack which is what I have on my pick up shell, but don't really want to go for extra $. I'm trying to think of something I could make up myself as the trailer is more for go then show. oh and I don't have a welder. Any ideas?
ch0mpie is offline
Old 01-07-2007, 07:24 PM   #2
mdshunk's Avatar
Re: Trailer Ladder Racks
Kindorf.
mdshunk is offline
Old 01-07-2007, 07:24 PM   #3
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Really glad you posted this. I built shelves in the front of my trailer last week and now my extension ladder does not fit well inside. I was going to start my search Monday and this thread might help.
dougchips is offline
Old 01-07-2007, 07:48 PM   #4
Squrtgun's Avatar
Trade: Pressure Washing
http://www.adriansteel.com/tlrracks.htm
Karvonen's Pro Clean
Pressure washing/Low pressure roof cleaning
229-776-7856/229-344-5596
Scott Karvonen
Squrtgun is offline
Old 01-09-2007, 06:41 PM   #5
ch0mpie's Avatar
Yea I have them inside now and I have to take them out almost anytime I need something..pia
Originally Posted by Squrtgun View Post
nice, but similar in price to trac rack as I mentioned in the initial post.
Originally Posted by mdshunk View Post
Kindorf.
Good idea. I've never used the stuff but it looks like the old erector sets.
Thanks guys
ch0mpie is offline
Old 01-09-2007, 07:05 PM   #6
Student of Life
Murphy's Avatar
Trade: Remodeling, Restoration, and Repair
Go to your trailer hitch supply locally. I went to mine for ladder racks for my stepvan and they ordered cut and installed for 400 three bars all aluminum. I would try there first. Murph
Murphy is offline
Old 01-09-2007, 07:24 PM   #7
wolffhomerepair's Avatar
Trade: General Remodeling
Definatly try your trailer dealers. Mine sells them for $75 per rack. I put on 3. That included installation and they are aluminum.
http://www.wolffhomerepair.com
" Of course I don't look busy, I did it right the first time "
wolffhomerepair is offline
Old 01-09-2007, 07:41 PM   #8
Insert title
dougchips's Avatar
Someone sold you the "sucker braces" for your trailer. When I bought mine the salesperson said that if I don't buy them the trailer can flip over backwards with me in it and I could die or get crushed. I used them for a month before I figured out that the trailer was not really going to flip over. Nothing like driving down the road with them down.
Old 01-09-2007, 11:04 PM   #9
Toothpick's Avatar
Trade: Home building
Wolf, It sounds like you got the same racks as I got on ours, 3 racks for $75 each. I hope yours works out better than ours did. Our trailer is a flat top type that has a coninous aluminum rail that runs the length of the trailer and the racks are simply screwed straight down into the rail. The first time I was going to use them I was putting a 32' fiberglass ext. ladder on it. Needless to say I leaned one end on the rack and I picked up the other end to give it a push forward and the p.o.s. collapsed, bending forward as I was "walking" the retaining brackets over the rack. No, I did not drop the ladder on it or give a big shove, I put very little strain on the bracket. After that I put the ladder inside the trailer because I thought if they bend over that easily, I can imagine what going to happen when I have 3 of my ladders up there coming up to the first stop sign or light. Funny part is my partner was backing up the trailer a short time later and took out the middle p.o.s. with a small tree branch. Two down and one to go and they never seen anything on top. The moral of my story is stay away from the factory cheapies and buy a good aftermarket racks.
Toothpick is offline
Old 01-10-2007, 07:23 AM   #10
Well I carry a 36' aluminum and a 28' aluminum ladder on them every day. No problems. I have trimed trees with them driving down some side streets. No problem. I have had 6-2x12x16 on them. Again no problem.
Toothpick
It must depend on your trailer type some. Mine are bolted in on both sides into the top frame for the wall. Everything I put up there gets slide on from the back as I have the exended height and cannnot reach it any other way.
Old 01-10-2007, 07:29 AM   #11
Doug
I think you are talking about the rear stabilizers not ladder racks? If so I agree you don't need to use them if you have a tandem axle. Espacially if the truck is still hooked up. I have used them if the trailer will sit at the jobsite for an extended period but other than that I don't bother. And no I did not ask for them to be installed, they were standard with the trailer.
Old 01-10-2010, 01:17 PM   #12
Custom Builder
Chris@Sunrise's Avatar
i had mine welded cant upload pics yet, went through the factory aluminum ones in about a year and a half. Guys are tough on them and they only attached to the top of the sides mine now attach farther down the sides
Chris@Sunrise is offline
Old 01-10-2010, 02:51 PM   #13
tcleve4911's Avatar
Trade: Remodeling contractor
Low budget idea
Go the hardware store or pipe supply.
Buy 1" threaded pipe 4-5' for the width you need.
Install tee fittings on each end that extends 4-6" up and extends 4-6" down.
On the top screw on a cap to keep water out.
On the bottom attach a floor flange and bolt it through the roof.
You can use a U bolt to wrap around a ceiling crossover to get added support.
No welding..... just fastening.....
Did 3 racks on one of our cargo trailers for about $100.
Just an idea..................
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 02-15-2011, 07:14 AM   #14
kubie's Avatar
Trade: general contractor
got any pics?
kubie is offline
Old 10-07-2011, 11:47 PM   #15
Raymonds's Avatar
Trade: General
Does any one have experience with the ladder racks that uses 2x4 as cross members?
http://cgi.ebay.com/ebaymotors/ALUMI...item19c72d6bbc
Raymonds is offline
Old 10-28-2011, 01:51 PM   #16
TennMan's Avatar
Trade: Decking and Fencing
Try ryderracks they do custom aluminum racks for trailers and trucks and the work is top notch. they're in Nc.
TennMan is offline
Trailer: Customizing ideas needed. Long Robie Vehicles 195 11-06-2011 11:32 AM
Anybody have Hauler ladder racks? dkillianjr Vehicles 24 07-30-2011 10:30 PM
trailer roof racks Bone Saw Off Topic (Non Trade) 2 07-11-2007 06:23 PM
Ladder Racks on Trucks gtdail Vehicles 7 01-18-2007 08:17 AM
Trailers With Ladder Racks? JNLP Vehicles 6 11-07-2006 12:33 AM
