Tires For My Truck - Vehicles - Contractor Talk
Tires For My Truck
Old 08-19-2017, 09:22 PM   #1
Bexcavating's Avatar
Trade: Excavation
Rewards Points: 2
Tires For My Truck
I pull a gooseneck 24' with 12 to 14 k everyday. Do I need to keep load range E? I'm thinking yes but not 100% confident. I do not under any circumstance want bfg all terrain tires. I can't get them to last over 35k. I know I haul heavy things yada yada but even the oil guys gripe, any tire suggestions? I have a 4x4 I'd like an all terrain.
Bexcavating is offline
Old 08-19-2017, 09:30 PM   #2
The Sheriff
Jaws's Avatar
Rewards Points: 8,362
Re: Tires For My Truck
I put load range e on all tires and all my trucks 3/4 and over
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
The Following User Says Thank You to Jaws For This Useful Post:
maxfederle89 (11-05-2017)
Old 08-19-2017, 10:30 PM   #3
Quality5280's Avatar
Trade: Hardscape ,Landscape and Roll off Containers
Rewards Points: 178
I would defiantly run 10 ply
Sent from my iPhone using Tapatalk Pro
Quality5280 is offline
The Following User Says Thank You to Quality5280 For This Useful Post:
Jaws (08-19-2017)
Old 08-20-2017, 09:23 AM   #4
tgeb's Avatar
Rewards Points: 1,478
If I could find load range "F" for my trucks I'd put them on.
And by the way, I doubt you would find a tire place that will downgrade your tires to load range "D". You crash that rig with the wrong tires and you could be in a world of hurt legally.
As far as tire recommendations, I have good service out of Firestone brand, some friends of mine run Michelin and think they are worth the premium $.
www.gebcon.com
tgeb is online now
Old 08-20-2017, 09:38 AM   #5
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,658
I had Ds on a one ton Chev and all the belts inside the tire broke and they got completely chopped before wearing through the tread. Es only for me thanks.
Sent from my Nexus 6P using Tapatalk
Inner10 is offline
The Following 3 Users Say Thank You to Inner10 For This Useful Post:
maxfederle89 (11-05-2017), sparehair (08-21-2017), tgeb (08-20-2017)
Old 08-20-2017, 12:21 PM   #6
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,467
I have a transit 250 that came with 10 plys from ford. When they wore out at 29k miles I got the cheapest 10 ply available. Firestone Transforce HT. Outstanding tires for towing. The difference in stability was 10 fold. My Transit is around 7000 lbs and the trailer varies from 3-5 thousand. Even at my max combined weight rating the tires are the best I've had in 15 years of contracting.
Now the actual firestone store, they can suck it!
WBailey1041 is offline
The Following User Says Thank You to WBailey1041 For This Useful Post:
Old 08-20-2017, 12:27 PM   #7
Rewards Points: 178
purchased 2 sets of these tires
purchased them as take offs and paid 500 a set back when the oilfield needed more of an aggressive tread
Old 08-21-2017, 07:45 PM   #8
TimNJ's Avatar
Rewards Points: 3,142
I run Bridgestone Duravis M700 on my Chevy 2500.
I never rotate my tires. I got 70,000 miles out of the original fronts and about 50,000 out of the backs.
TimNJ is online now
Old 08-21-2017, 08:20 PM   #9
tjbnwi's Avatar
Rewards Points: 4,906
I have E rated KO's on my Excursion, ordered a new set today. Will have them installed later this week.
Can't get them in raised white any more. This sucks.
tjbnwi is online now
Old 08-22-2017, 03:25 PM   #10
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 2,250
Last time I needed Load Range E tires I went to the RV forums and researched what lasted and produced good traction. The Bridgestone Dueller HT seemed to come out on top. I left the white walls in the 50's...
Peter_C is offline
Old 08-22-2017, 07:22 PM   #11
TimNJ's Avatar
Getting four newBridgestone Duravis M700's 265/70-17 tomorrow.
$1104.68 out the door.
TimNJ is online now
Old 10-04-2017, 10:23 PM   #12
rblakes1's Avatar
Rewards Points: 1,942
I got about 95k out of the ta kos that came from the factory in my truck, replaced them with the ta ko 2s and have about 40k on them now. I'm not expecting to get 95 out of this set as they seem to be a softer compound ie quieter than the stock ones. E rated on a Ram 2500
Sent from my SM-N910V using Tapatalk
rblakes1 is online now
Old 10-05-2017, 07:40 AM   #13
Inner10's Avatar
I don't know how you guys get such good mileage out of tires, maybe it's because I'm on the brakes more but I can't get any tire to run more than 35k miles before it's toast.
Inner10 is offline
Old 10-05-2017, 07:48 AM   #14
rblakes1's Avatar
Stop doing burnouts and donuts!
On my first set I did a lot of highway driving, 100+ miles a day. The roads I generally travel are pretty smooth, too. Aside from that, I made sure I kept the pressure where it was supposed to be and rotated them as recommended in the manual.
Old 10-05-2017, 08:04 AM   #15
Inner10's Avatar
What pressure are you running? I know the door sticker says 80 rear 65 front.
Inner10 is offline
Old 10-05-2017, 08:08 AM   #16
Inner10's Avatar
As you can guess it's tire time for me...I have my eye on the K02s as well...
Inner10 is offline
Old 10-05-2017, 08:09 AM   #17
rblakes1's Avatar
I have a 2012, 60 up front and I can go down to 45 in the rear if I'm empty, or bump up to 70 loaded/towing
Old 10-05-2017, 08:18 AM   #18
rblakes1's Avatar
I like them. The only times I've had any grip issues were when the ground was a little wet and I was on an uphill exit/entrance loop with an empty bed, but that was because I was going a little too fast for conditions.
I got them at the dealership with their buy 3 get one almost free because of the cost of the tire. It was just under 1000 including alignment
The Following User Says Thank You to rblakes1 For This Useful Post:
Inner10 (10-05-2017)
Old 10-05-2017, 08:24 AM   #19
rblakes1's Avatar
Happened to be next to my truck, I'm at about 5/32 rear, 6/32 front after 40k
Old 10-05-2017, 08:38 AM   #20
Inner10's Avatar
If I have less than 70 in the rear I get warning lights popping up on my dash. Even though I think 80 PSI unloaded is brutal. I delivered a thousand cans of beer to a friend's cottage in the summer and had my truck unloaded for the first time in almost 2 years. Almost scary the way the back end bounces around without any load.
My current tires are wearing a little un-even. Probably time for an alignment and new boots.
Inner10 is offline
Pick up truck organization. FramingPro Vehicles 189 12-05-2016 08:45 PM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
making truck cap fixed side windows open duburban Vehicles 15 05-21-2012 04:51 AM
Truck tires Dan_Watson Vehicles 48 11-14-2009 10:10 AM
Skid steer tires Golden Gate Excavation & Site Work 11 09-13-2009 09:10 PM
