Snow Tires
Old 09-11-2009, 10:51 PM   #1
Anderson's Avatar
Trade: Home improvement contractor
Snow Tires
Winter is coming and I have a chevy 2500 van, no allwheel drive.
Which snow tires does everyone use..
Anderson is offline
Old 09-11-2009, 10:55 PM   #2
Yard Boi
HusqyPro's Avatar
Trade: Landscaping
Re: Snow Tires
Yokohama studded tires sell pretty good around here.
My Treadwright MT's grip fine in the snow so I use them, but I have a lever I can pull to engage the front axle if needed.
Bob's Lawn & Landscape
When You Want The Best
Serving the LC Valley & Moscow-Pullman
HusqyPro is offline
Old 09-11-2009, 11:00 PM   #3
solar guy
naptown CR's Avatar
Trade: solar contracting
Re: Snow Tires
They are called snow days
you stay the heck off the road with that squirrely assed thing
naptown CR is offline
Old 09-11-2009, 11:35 PM   #4
Trailer park boy
shanekw1's Avatar
Re: Snow Tires
I run Nokian Hakkapeliitta LTs on my truck, kicks ass on the blizzaks.
shanekw1 is online now
Old 09-12-2009, 01:10 AM   #5
Teetorbilt's Avatar
Re: Snow Tires
BIG help naptown. Nothing would have been better. Please try to be constructive in the future.
Albert Einstein
Teetorbilt is offline
Old 09-12-2009, 01:51 AM   #6
oldfrt's Avatar
Re: Snow Tires
Anderson,
Studded snows and some evenly distributed weight over the rear axel is about the best you can do.
I'll just take anything that can be studded.Can't tell you a brand yet.Hoping they are available this year,because they weren't last year for the new trucks.
oldfrt is offline
Old 09-12-2009, 06:34 AM   #7
MarkNoV's Avatar
Trade: Windows & Doors
Re: Snow Tires
Cooper Discoverer M+S WITH STUDS on my F150 2 wheel drive. Same thing on the Dodge Caravan. Will probably go with Coopers on the Accord.
Mark
MarkNoV is offline
Old 09-12-2009, 11:17 AM   #8
Project Manager/Carpenter
TBFGhost's Avatar
Trade: Carpentry/Reno
Re: Snow Tires
Winterforce Studable on my 4x4 Ranger. :-) Makes driving in the snow easy.
TBFGhost is offline
Old 09-12-2009, 11:50 AM   #9
Anderson's Avatar
Re: Snow Tires
I live in CT and I am pretty sure studs are not allowed.
Anderson is offline
Old 09-12-2009, 12:15 PM   #10
MarkNoV's Avatar
Re: Snow Tires
Studded tires are allowed in CT between Nov15 and April 30.
http://www.theheartofnewengland.com/...SnowTires.html
Mark
MarkNoV is offline
Old 09-12-2009, 12:26 PM   #11
woodchuck2
woodchuck2's Avatar
Re: Snow Tires
Mark
X2, i run these on my trucks in the winter and the wifes Honda Odysee van. I just dont run studded although studs do work well. They are hands down the best tire i have ever used for plowing. They have a soft compound rubber tread with alot of siping that really grip. I have never had any issues with shakes or out of balance with them, smooth ride and are quiet on the road. they do however wear quickly but i expect this from a traction tire.
woodchuck2 is offline
Old 09-13-2009, 11:25 AM   #12
oldfrt's Avatar
Re: Snow Tires
I'm in Ct, run them every winter,I couldn't even get out of my own driveway without them,not to mention uncleared roads that haven't been sanded/salted yet.
My old F-150 had no traction,even with substantial weight over the tires.
I imagine a van to be the same.
Try em,you'll love em!
oldfrt is offline
Old 09-14-2009, 08:26 AM   #13
Anderson's Avatar
Re: Snow Tires
So I understand that studs are best, the next question is, do you break down your wheels and tires each time to switch them or do you keep them on a seperate rim.
The problem I have is that my van has a tire pressure monitoring system and I cant find a tire and rim pkg with the sensors
Anderson is offline
Old 09-14-2009, 08:33 AM   #14
oldfrt's Avatar
Re: Snow Tires
Rims should be available through your dealer or check auto salvage yards,ebay.
I was told last spring that the studded tires will be available this fall for the pressure monitoring systems.
You may have to switch off the old tires if you can't find the rims,as there is a hefty fine for not using them.
oldfrt is offline
Old 09-14-2009, 05:13 PM   #15
woodchuck2
woodchuck2's Avatar
Re: Snow Tires
A hefty fine for what???? Thay cant fine you for not running the TPMS. Thats like saying you can be fined for not using you ABS or traction control. This is just another gimick for the tree huggers pushing for more economical vehicles and the government has bought into it. I also disagree with the auto manufacturers with how they force the consumer into buying another set of wheel sensors if someone wants to run a different set of tires. The early TPMS used the already existing ABS system to monitor pressures. After so many revolutions it would compare the difference of revolutions between the tires and set a light to check tires. This system would automatically reset itself and you could run any tire pressure you wanted. The new system requires the TPMS to be reset every time the tires are checked and there is a specific order that it is done in. This system also requires you to run all the tires at the same PSI, that sucks for anyone like me who has a front heavy diesel truck with sometimes little weight in the rear. So now i am forced to run 80psi in the rear so the center of my tires wear quickly and it rides like a buckboard wagon. No more of the days that i run 80 psi in the front and 50 psi in the rear for the better ride, the government says tires are cheaper then fuel!!
Old 09-14-2009, 06:24 PM   #16
Dave from Macatawa
macatawacab's Avatar
Trade: GC, cabinet maker and remodeler
Re: Snow Tires
In west MI we got 140" of snow last year. Cooper is my favorite. Studs not allowed. Used to be calle the Cooper WeatherMaster. Waffle pattern and I agree with the other posts, soft and great. traction
macatawacab is offline
Old 09-14-2009, 06:42 PM   #17
oldfrt's Avatar
Re: Snow Tires
New technology s*cks,
We can at least change our own oil,I think!
There are some people trying to do away with the gov.intervention here,but it"s falling on deaf ears:http://www.tireindustry.org/pdf/TPMS_Comments052305.pdf
But here is the current take by installers when asked:
Can't you guys just disable that annoying TPMS light? I don't want to pay to fix a system I don't even want!
No. It is illegal to disable the TPMS light per FMVSS 138. We're not willing to pay fines or go to jail to reduce your annoyance. Are you required to fix the TPMS light? No, you're not. Could we install 24" non-TPMS rims with 35 series tires on your Corolla. Absolutely not, but not because it's illegal, it would just look really silly. The law says your warning system must not be disabled, but apparently a working warning light is considered "working". Goofy rims without TPMS are legal, so long as an auto repair shop does not disable your TPMS light. Can you disable your own TPMS light? It's fine with me. I won't tell anybody.
oldfrt is offline
Old 09-14-2009, 09:37 PM   #18
Inner10's Avatar
Trade: Control Systems
Re: Snow Tires
These are awesome in the snow just awesome!
Michelin's are a better ice tire but the nokians are snow kings.
Coopers have gone up in price but the quality hasn't changed.
I'm just going to run my BFG Commercial T/A all-seasons again and be caseful.
Inner10 is online now
Old 09-15-2009, 09:49 PM   #19
HitchC&L's Avatar
Trade: Construction
Re: Snow Tires
My father drives the same van. GMC 2500 extended length 2WD.
He runs studded hakkapalittas (spelling?) and it does well considering.
He cant make the driveway sometimes in snow storms, but it you know how to drive, you dont have any problems on the roads.
HitchC&L is offline
Old 09-16-2009, 11:15 AM   #20
10fingers's Avatar
Trade: Contractor Residential Construction
Re: Snow Tires
Can't believe you use still use a rear wheel drive van in winter?? Here's what you do. Install a posi-rear end differential. Turns your 1 wheel drive van into a 2 wheel drive. Both rear wheels now drive the van when required. No more wheel spinning at lights or stop signs. These things work great. Only the gears are changed so you keep everything you see at the rear end, dif, brakes, shocks. Last time I had an install the cost was $1200CDN. Best money you can ever spend. This system can be used on any rear wheel drive vehicle.
Here's a little diddy on Auburn (other makers of these systems out there so check around):
For 48 years Auburn Gear Inc. has been the leader in performance limited slip differentials, spools, & mini spools. Our unique cone style differential provides more bias torque as compared to any other limited slip brand.
The Auburn ECTED locking differential is a SELECTABLE limited slip to a full locking differential.
Our current product catalog features our full line of limited slip differentials, the ECTED Auburn-Locker, spools, mini spools, as well as a complete listing of service kits.
This unit replaces what's inside your rear differential:
10fingers is offline
The Following User Says Thank You to 10fingers For This Useful Post:
HusqyPro (09-16-2009)
Customer has 4 flat tires MEL Business 89 02-22-2009 06:42 PM
Single Axle Dumptrucks for Sale And meyers snow plow setup 4theroc Excavation & Site Work 2 01-08-2009 09:30 PM
Snow, Oh Beautiful Snow!!! Ed the Roofer Off Topic (Non Trade) 3 12-13-2007 06:14 PM
Snow, Oh Beautiful Snow! Ed the Roofer Off Topic (Non Trade) 3 02-14-2007 05:34 PM
Winter Blues in Vermont CE1 Off Topic (Non Trade) 3 02-25-2006 11:35 PM
