PVC 6" Conduit Holder
Old 05-17-2009, 03:01 AM   #1
huntington beach, ca.
hbelectric's Avatar
Trade: electrical
I need to make one for my ladder rack. Any good ideas before I go make one myself. Type of PVC, end pieces, securing? I see they are about $100.
hbelectric is offline
Old 05-17-2009, 10:17 AM   #2
JonM's Avatar
Re: PVC 6" Conduit Holder
Go to the plumbing department...get some 4" white PVC a couple of cleanouts then go to the hardware department get a couple of large U clamps and have at it...simple
JonM is offline
Old 05-17-2009, 04:59 PM   #3
Kgmz's Avatar
Years back when I had a van I made some out of 6" pvc with a slip cap glued on one end and a 6" clean out adapter with threaded plug on the other. I mounted them to the rack with U-bolts, just not sure if I bought the bolts or made them.
Kgmz is offline
Old 05-17-2009, 09:57 PM   #4
leakygoose's Avatar
Trade: Finish Carpentry
Just a word of warning ;years ago I saw a van with a PVC holder on the ladder rack and he rear ended a car at a light and I saw a 4' wood level shoot out the front cap and all the way across the intersection like a missile .
leakygoose is offline
Old 05-18-2009, 02:41 AM   #5
hbelectric's Avatar
Trade: electrical
Thanks I realize it is simple, but never hurts to ask.
Old 05-19-2009, 07:18 AM   #6
mrmike's Avatar
Trade: Electrical & Carpentry
I have had a rectamgular pipe/conduit holder & I should have taken it off before I sold the Van. You could reach in & get to the shorter pieces & fish them out easier. With my round pvc one it doesnt hold much & you need to just use it for full lenghts or else the short ones go to the front & you can't get them out unless you pull everything.
If you do make one-drill your threaded end plug & put a wire & attach the other end to the Rack-- I lost quite a few plugs & nearly missed cars by leaving it on the top of the van!!
mrmike is offline
Old 05-31-2009, 11:30 PM   #7
unhique's Avatar
Trade: Whole house remodeling & Custom home building
Hello all,
I know it depends on the trades, but what you put in your conduit carriers? And how long is yours?
I used to carry my 4" black ABS conduit in 12' for my plastic window trim (for retrofit installation) on my window replacement jobs only. Then just leave it home when not needed.
Just bought a 6" conduit cap set from System One:
Is white schedule 40 what people usually use? (like what pictured here)
I saw one guy have a short one tied to his cross bar right behind the cab glass for shorter item (6' ?) which is a good idea to me if you want to seperate & carry 2 conduits.
Other than that, like someone had mentioned previously, it's pretty hard (if not impossible) to get stuffs out once you have it screwed down.
Thanks.
unhique is offline
Piecing 6" x 6" together ... casey344 Decks & Fencing 43 04-15-2009 09:52 PM
mounting conduit on existing flat roof bhe Electrical 24 02-15-2009 09:42 AM
Is my Conduit Leaking? robertc65 Electrical 14 04-03-2007 03:05 PM
Pricing for painting 1" conduit saucedo80 Painting & Finish Work 10 10-06-2006 01:27 AM
Removing old wiring from conduit duke Electrical 3 01-29-2006 11:04 PM
