New Tires
Old 04-25-2006, 03:57 PM   #1
Building & Remodeling
Wills03's Avatar
Trade: Building & Remodeling Contractor
New Tires
Hi Guys. I own a 2000 G2500 8600 GVW van which I had been running LT245-75-16 load range E. The truck rides rough and wears the rear tires down the center. Tire shop said to run less pressure and should only need load range C. I agreed and purchased a pair for the rear. Driving the first few miles truck seems to be swaying and rocking. I checked the pressure and the tires are only rated for 2205# at 50 lbs. which is the pressure the shop put in them. I pulled invoice from last trip to landfill and I weighed 7200 empty. Maybe I am just imagining the handling problems but I am concerned that the tires are almost maxed out now without a payload. Not to mention I also tow a boat with this truck which you could not even tell was there with the old tires. I know what my advice would be to myself just looking for other opinions because I always tend to go to heavy duty but it would appear this time I should have stayed heavy duty.
Thanks Bill
Wills03 is offline
To all The Newbies Starting Up Their Own Business dirt diggler General Discussion 53 04-27-2011 07:21 PM
New tires rino1494 Excavation & Site Work 0 04-07-2007 03:37 PM
New skidsteer tires Bone Saw Excavation & Site Work 11 01-05-2007 08:58 PM
Superduty Tires Jon F Contractor Swap 6 10-09-2006 05:37 PM
Tires denick Excavation & Site Work 3 05-05-2006 10:01 PM
