Magnetic Signs Stuck To Truck
Old 06-26-2008, 07:07 AM   #1
Crawdad's Avatar
Trade: Lawn Care
Rewards Points: 250
I generally use my white pickup for working, and my red one on the weekends, but a couple weeks ago, I used the red one to deliver some mulch, so I slapped my magnetic signs on it. I've used these signs before, with no problems. Until now.
I left my signs on the truck for 2 or 3 weeks, during very hot weather. Now they won't come off! I can lift a corner, but no further. I've even tried the pressure washer, at the car wash, and a plastic scraper. A small piece of paint came off, while trying to get the sign off.
Anyone ever have this happen before?
Crawdad is offline
Old 06-26-2008, 10:33 AM   #2
dougger222's Avatar
Trade: Roofing Contractor
Rewards Points: 1,116
Re: Magnetic Signs Stuck To Truck
Had this happen when I left the magnet on the black dump trailer for months. Took some chunks out of the magnet when I finally decided to yank it off. It still works and sticks well to the DRW.
I had two magnets blow off in the Winter time though. If I were to do it again would go with vynil on the windows.
Try a hair dryer???
dougger222 is offline
Old 06-26-2008, 04:27 PM   #3
tinner666's Avatar
Rewards Points: 1,000
New one to me. BTW, contrary to popular opinion, my magnetic sign dealer said to remove the signs from the MIDDLE, not the corners. That was news to me too.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 06-26-2008, 07:02 PM   #4
Teetorbilt's Avatar
Rewards Points: 2,000
I've had them stick a little bit but never like what you're talking about, it sounds like they've bonded to the paint. It gets plenty hot here too, like 120* in the time it takes to hit a Port-O-Let.
Is the paint new? Do you wax your trucks?
I'd go back to the sign guys and see if they have some tricks. Maybe you just need to heat them up again with a hair dryer or heatgun.
Albert Einstein
Teetorbilt is offline
Old 06-26-2008, 08:06 PM   #5
tgeb's Avatar
Rewards Points: 254
That would be my suggestion as well, that or maybe park it in the sun for a few hours.....then give it a pull.
www.gebcon.com
tgeb is offline
Old 06-26-2008, 08:19 PM   #6
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
X2 and you are suppose to apply a heavy coat of wax to the door to prevent the magnet from sticking like yours has.
woodchuck2 is offline
Old 06-26-2008, 09:16 PM   #7
LRG WoodCrafting
Leo G's Avatar
Trade: Self Employed Moron
Rewards Points: 2,440
Yup, had it happen. Both side stuck after I left them on for a few weeks without removing them. I peeled one of them off with a putty knife and it came off in chunks. The other I left on for quite a while until I bought a new truck. Had to turn the old one in for trade, just peeled it off with no regard, came off without much struggle, unlike the other one.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 06-27-2008, 05:54 AM   #8
Crawdad's Avatar
Trade: Lawn Care
Rewards Points: 250
I had used a carnuba wax product(Beats-Um-All) about 6 months ago. I was fixing to wax it again, that's why i was gonna remove the signs.
I tried on a hot day, and on a cold day.
A sign maker has recommended trying a hair dryer on another hot day.
Crawdad is offline
Old 06-27-2008, 09:35 PM   #9
j_builder's Avatar
Trade: Specializing in residential remodeling
Rewards Points: 250
fishing line or dental floss
Along with a hair dryer or heat gun (not to hot) on the settings, start at the corner that you didn't damage already attempting to remove and once its warm enough to remove it get the fishing line or dental floss and work it into the corner pulling tightly on the line between your hands(you might need some more hands) to help peel away the sign(s)...if you have any residue left just over remove that with either WD-40 or Goo-Gone and you're good-to-go. Ready for waxin' (in the shade) of course.
Good Luck Crawdad
j_builder is offline
Old 07-04-2008, 10:34 AM   #10
dougger222's Avatar
You also have to take them off every two weeks and wash the back side of the magnet and the truck. Guess metal can collect behind the magnet and rust the paint/truck.
Vinyl decals on the windows are the way to go.
Old 07-06-2008, 03:56 PM   #11
BUILDER / REMODELING CONT
buletbob's Avatar
Trade: Builder/Remodeler
Rewards Points: 81
Here's an Idea! I'm thinking if the heat made it stick in the first place would the heat make it more stickier using a dryer or heat gun ???? . What if you rubbed dry ice over it. Just a suggestion. I would hate to ruin the finish on my truck.
what do you all think????
Quality is remembered long after the price is forgotten
buletbob is offline
Old 08-13-2008, 10:55 AM   #12
Sign Man
Mardi's Avatar
Trade: sign installer
Send a message via Yahoo to Mardi
Attached is the care instructions for door magnets. They should NEVER be left on for long periods of time without cleaning them and the surface they are attached to.
As far as removal of "baked on" ones, above suggestions are valid, use a hard plastic tool to lift one corner after heating them and either continue in the same manner or use dental floss to remove them. Paint should not peel if it is factory paint.
And yes, keep at least the magnet area waxed.
File Type: pdf Magnet installation and care 2008 for web.pdf (16.1 KB, 566 views)
Mardi is offline
Old 01-08-2010, 12:19 PM   #13
esigns's Avatar
Trade: sign trade
this may be a late response, but I thought to post anyway, in case if anyone have a same problem.
Tips on using magnetic sigsn:
1. Signs shall be taken off every day and cleaned with warm water, as well as surface of the vehicle.
2. Magnets shall never be put on wet, unclean or freshly painted \ buffed vehicle
3. It is the best to take off signs for at least 1 full day a week to let the car paint under the signs equally faid with the rest of the vehicle.
Now, to adress OP issue: it is best to warm up stuck signs with a hot air heat gun (no propane and no flame) and then signs are very hot try to peel them off.
More details about magnetic sign care and usage can be found at esigns.com/magnetic-signs
Thanks,
Stan
I DIDN'T READ THE AD RULES
esigns is offline
Old 01-08-2010, 04:40 PM   #14
Crawdad's Avatar
Trade: Lawn Care
Rewards Points: 250
I finally took the signs off, sometime back in '08, using a heat gun and a plastic spatula. They came off in small pieces, it was a real PITA. It took the clearcoat too.
Freekin signs...
Crawdad is offline
Painted My Truck With a Roller ModernStyle Painting & Finish Work 44 07-21-2007 10:11 PM
Got another truck IHI Vehicles 14 11-12-2006 08:07 PM
magnetic signs kklick General Discussion 12 04-20-2006 08:11 PM
magnetic signs on a pickup wolffhomerepair Marketing & Sales 20 03-22-2006 12:11 PM
Magnetic truck signs ProWallGuy Business 9 08-12-2004 11:49 PM
