How Much For A New Clutch?
Old 05-21-2009, 04:48 PM   #21
Al Smith
A W Smith's Avatar
Re: How Much For A New Clutch?
Originally Posted by MALCO.New.York View Post
Ranger/Explorer TX should be no more than 700.00 rebuild. Plus "swing labor" of 150.00 to 200.00.
this would be a full size extended cab 91 f150 4.9 litre straight six auto with od. lock up converter
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 05-21-2009, 06:20 PM   #22
rustyjames's Avatar
If it has a hydraulic clutch that could also be the problem. the master cylinder or slave cylinder might not be fully retracting, not allowing the clutch to fully engage; thus causing the slipping. I've even seen the hose between them degrade internally and acting as a check valve causing this. Agreed, only 27k on a clutch assembly shouldn't be.
rustyjames is offline
Old 05-21-2009, 06:32 PM   #23
solar guy
naptown CR's Avatar
Trade: solar contracting
Has the service writer offered you a reach around. Make sure the shaft is well lubricated before insertion. It may be a little late for the second part
naptown CR is offline
Old 05-21-2009, 06:36 PM   #24
Al Smith
A W Smith's Avatar
Just the opposite, it wouldn't fully disengage. In fact that reminds me of a problem I had with an eighty something Nissan pickup 4X4 i had 11 years ago. Was low on fluid and I had a tough time changing gears.
Al Smith
Old 05-21-2009, 06:48 PM   #25
Originally Posted by A W Smith View Post
try pulling the pedal up with your toe. Is there free play? Is there a sticky spot when you depress the pedal real slow?
Probably a lot of free play
being it's in the shop and
torn down already.
neolitic is offline
Old 05-21-2009, 06:56 PM   #26
Handle It!
MALCO.New.York's Avatar
Ah! Yes! The Ranger and Bronco had the A4LD.......Anyhow......I think y'all be payin' too much!
Ultimate Wisdom---------
MALCO.New.York is online now
Old 05-21-2009, 07:00 PM   #27
Al Smith
A W Smith's Avatar
so do I, which is why I haven't let the shop have it.
Al Smith
Old 05-21-2009, 07:52 PM   #28
rustyjames's Avatar
Agreed and I understand that but what you're describing would be an issue with disengagement. I'm just relaying what I've experienced in the past. If the slave cylinder piston or the master cylinder piston is not fully retracting the clutch might not fully engage causing it to slip.
Old 05-21-2009, 08:10 PM   #29
LRG WoodCrafting
Leo G's Avatar
Which would be a warranty issue.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
rustyjames (05-22-2009)
Old 05-21-2009, 08:19 PM   #30
Al Smith
A W Smith's Avatar
Originally Posted by ChainsawCharlie View Post
4.0
It's too late for DIY. they're going to hit me with $500 in labor just for the teardown and diagnosis.
DIY might save me $500, but I don't have the tools, and my skills in that dept. are limited.
anyway. this appears to be your clutch
http://www.clutchcityonline.com/products/NSK1006.shtml
Kit Includes:
1. Pressure Plate
2. Clutch Disc (Friction Plate)
3. Throwout Bearing (Release Bearing)
4. Pilot Bushing
5. Alignment Tool
Price: $245.00
Al Smith
Old 05-22-2009, 12:25 AM   #31
Crash Test Dummy
ChainsawCharlie's Avatar
Trade: Landscaping
$1380.
3 beans for parts, the rest is labor. $99/hour. I fully expected this to be a warranty issue with the truck under two years and under 30k miles. Ohterwise, I'd never have gone to the dealer.
Thanks for all the info/input.
Anyway...I think my next vehicle will be a 70 something. I can still work on those.
ChainsawCharlie is offline
Old 05-22-2009, 04:24 AM   #32
trptman's Avatar
Trade: remodeling and restorations
How much for a clutch? the answer should be "tree fiddy" if contractor talk were to remain consistent.
And you should never attempt a clutch repair yourself, you should take it to the pro's.
sorry, couldn't help myself. that was too easy a setup.
I wouldn't know how to fix a clutch even if I wanted to.
trptman is offline
Old 05-22-2009, 06:54 PM   #33
rustyjames's Avatar
$1380.
It might be futile and a waste of some time but you might want to try writing an old fashioned letter to the manufacturer. I've done it before (with CAT) and while I never was fully covered, they met me half way, and it was a substantial amout of money. Squeaky Wheel
Old 05-23-2009, 12:35 AM   #34
747's Avatar
I say 7-800 dollars. Should have bought a F150. A truck like that really isn't set up to do pulling even with 4 wheel drive.
747 is offline
pocket screw torque sorethumbs Carpentry 19 05-05-2009 08:39 AM
2 speed axle question? Big Chris Excavation & Site Work 7 10-06-2008 02:44 AM
Our Other Skills – Let’s Brag a Bit elvinstheman Off Topic (Non Trade) 90 12-14-2007 05:09 PM
Blade Clutch quits when hot EDENSCAPES@DNET Landscaping 2 06-01-2006 06:32 AM
Cordless tools, besides dewalt chardog Tools & Equipment 40 12-20-2005 11:48 PM
