Fitting Big Tires On Truck
Old 03-25-2009, 12:03 AM   #1
Rock it...
BattleRidge's Avatar
So I got some 285/75R16 put them on my 07 silverado and they rub pretty bad. Is there any good way to corrrect that without getting a lift kit?
BattleRidge is offline
Old 03-25-2009, 12:04 AM   #2
mdshunk's Avatar
Re: Fitting Big Tires On Truck
Yes, put the old tires back on. Second option, Sawzall.
mdshunk is offline
Old 03-25-2009, 12:06 AM   #3
Rock it...
thats what I wanted to do, but the shop didnt want me to sawzall the well there, they said I was ruining my truck.
Old 03-25-2009, 12:13 AM   #4
KemoSabe
loneframer's Avatar
Keep the tires and put them on one of these. Plenty of clearance for that size.
loneframer is online now
Old 03-25-2009, 12:22 AM   #5
mickeyco's Avatar
Trade: Squirrel Handler
Cut the fenders and buy fender flares, they make ones that are specifically for this type of thing.
mickeyco is offline
Old 03-25-2009, 12:27 AM   #6
mdshunk's Avatar
Why did you do this, anyhow? Did they have a sale at the tire shop called "Tires That Won't Fit Your Truck"?
mdshunk is offline
Old 03-25-2009, 12:27 AM   #7
Rock it...
they arent that big you dont have to cut the fenders, it just catches the back of the bottom on the inside when you turn all the way.
Old 03-25-2009, 12:30 AM   #8
mdshunk's Avatar
Perfect! The simple solution is at hand... don't turn all the way.
mdshunk is offline
Old 03-25-2009, 12:37 AM   #9
Rock it...
So they arent huge or anything
Old 03-25-2009, 12:44 AM   #10
Palisade Point Const.
TempestV's Avatar
when the tires are turned all the way, what exactly does the tire rub up against? Can whatever that is be moved or removed?
How is that Hyperchip working out for you?
TempestV is offline
Old 03-25-2009, 12:49 AM   #11
Rock it...
they hit in the back of the well at the bottom, about 5 inches from the outside edge. It can be cut away, i just didnt know if there were other options
Old 03-25-2009, 12:50 AM   #12
Rock it...
didnt put the chip in since the tires arent on, I had to take them off and I dont want to recalibrate it for the tires later.
Old 03-25-2009, 09:50 AM   #13
woodchuck2
woodchuck2's Avatar
Lift the front end of the truck up so weight is taken off the suspension and crank the torsion bars. You will need to count the turns and do the same amount of turns from side to side. I did this on my first D-Max as i run 265's on it and carry a plow. The second D-Max i just bought has 285's on it and that too carries a plow, how many turns those bars were cranked i dont know as i didnt do it. Both trucks handle fine and the tires wear fine. My first D-Max is on its 4rth st of tires since i bought it and i just had it aligned for the first time a couple weeks ago.
woodchuck2 is offline
Old 03-25-2009, 11:45 AM   #14
Carpenter/Finisher
john5mt's Avatar
Usually that has to do with your wheel offset.
a +10 to +15 offset is typical for gm trucks
whereas my dodge uses a -10 to -15
i put some +12's on my truck and they rubbed like the dickens but with -12's i have to crank the wheel and hit a bump to make them rub.
Dont mind the weird fender trimming on this pic, that was damaged before i bought it. I have since trimmed it to look cleaner. (these are 35X13.50's with 2" leveling springs. The edge juice with attitude to be installed soon)
1st Gen tradesman
My summer job in college became my profession
john5mt is offline
Old 03-25-2009, 02:47 PM   #15
mmike032's Avatar
Trade: trim carpentry
can the torsion bars be cranked on an '07? if they can that is one option but it will cause premature where and tear.
leveling kit is another option. Or you could cut a little out where its scrubbing. or get a lift kit.
I got a 6" lift and still had to do some trimming on the wheel well but nothing drastic. you cant even tell unless you know its there.
My tires are 35X12.50
mmike032 is offline
Old 03-25-2009, 07:01 PM   #16
Rock it...
nice truck man, I dont want a lift kit, I mean these tires arent even very big, I always thought that looking just baller was bad for your customers to see.
Old 03-25-2009, 07:10 PM   #17
Rock it...
I jujst cut the inside of the wheel well, and got hailed on the whole time.
Old 03-25-2009, 08:15 PM   #18
hughjazz's Avatar
Trade: carpenter
ah, .................................................. .......
never mind.
hughjazz is online now
Old 03-25-2009, 08:33 PM   #19
KemoSabe
loneframer's Avatar
never mind.
Yeah Jazz, I think I know where you were going with that.
You can't be the Lone framer if you don't get outta Dodge.
Old 03-25-2009, 09:42 PM   #20
Nail banger's Avatar
you need a set of "green keys" do a google seach. this will level the front end
Nail banger is offline
Customer has 4 flat tires MEL Business 89 02-22-2009 06:42 PM
tires and pressure work trucks oldrivers Vehicles 15 02-19-2009 10:49 AM
Painted My Truck With a Roller ModernStyle Painting & Finish Work 44 07-21-2007 10:11 PM
Got another truck IHI Vehicles 14 11-12-2006 08:07 PM
New Tires Wills03 Vehicles 0 04-25-2006 03:57 PM
