Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Vehicles
Old 01-24-2008, 09:37 PM   #1
SANDBLASTING & REMODELING
plazaman's Avatar
Trade: SODA BLASTING & REMODELING
Engine Flush - Removing sludge
I am very neglectful owner on 1 of my pickups. I think i may have a sludge deposit in the engine. Do any of those engine flush kits work?
Thanks
Rich
www.perfectocorp.com
plazaman is online now   Reply With Quote
Old 01-25-2008, 12:09 AM   #2
dkillianjr's Avatar
I have used a couple different ones. Theres deffinetly no noticeable differences afterwards. They did clean out some of the gunk, I saw it in the old oil. I wouldn't spend to much on it though. When you change the oil make sure you get the motor good and hot if you can, that helps some of the gunk come out with the oil. If you want to clean out the motor Seafoam really works. What kind of truck is it?
11/6/2012 can't come soon enough!
dkillianjr is online now   Reply With Quote
Old 01-25-2008, 02:17 AM   #3
Trade: Roofing Contractor
The Service Manager at one of the Chevy Dealers told me to add one quart of transmission fluid and drive the vehicle "lightly" for no more than 1/2 hour and then drain all oil and replace the filter, and that does the same as the engine gunk deposit cleaners.
I experienced no problems from doing that.
Ed
Ed the Roofer is offline   Reply With Quote
Old 01-25-2008, 10:26 PM   #4
plazaman's Avatar
2003 dakota sxt quad cab 6. problem is that i hardly ever remember to change the oil make like 1-2 times a year.
Old 01-25-2008, 10:57 PM   #5
Trade: seamless gutters
buy a diesel
nlgutters is offline   Reply With Quote
Old 01-25-2008, 11:30 PM   #6
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Builder
Here's another idea:
We've switched most of our trucks over to Amzoil synthetic. WE drive 15k-25k per truck a year, so we change the fluids once a year, when we're slow in the Fall...
FWIW,
~Matt
Custom Decks: www.BreyerConstruction.com
~Excellence in Everything~
BreyerConstruct is offline   Reply With Quote
Old 01-25-2008, 11:49 PM   #7
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Send a message via AIM to Michaeljp86
Get some seafoam, that stuff will clean your engine out. It works great, gets crap off the rings and even rasies compression and stops burning oil because the rings can move.
I put amsoil in my jimmy and change it once a year.
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
Michaeljp86 is offline   Reply With Quote
Old 01-25-2008, 11:51 PM   #8
Charitable animal
Bone Saw's Avatar
Trade: decks
Originally Posted by nlgutters View Post
buy a diesel
Custom Decks & Carpentry LLC.
play
more play
raped ape
Originally Posted by nilscraft View Post
I'm doing a bid for a homeowners ass
Bone Saw is offline   Reply With Quote
Old 01-25-2008, 11:57 PM   #9
EVIL GENIUS
buy a diesel
Im rebuilding my tractor engine and that had some sludge in it, with over 14,000hrs I guess it should. Still ran though, just spun a bearing and Im sure the compression was a little low.
My 6.5L diesel has 251,000+ on it and never ran better.
Old 01-26-2008, 11:06 AM   #10
plazaman's Avatar
i have a diesel, 06 ram 2500 quad cab 8ft bed
Old 01-26-2008, 11:52 AM   #11
Something that works but was not done intentionally.
Our JD excavator lost a seal on the injection pump on the drive shaft. This shaft runs into the front timing cover. So we got diesel into the engine oil and not sure how long it had been leaking or how much. But after we fixed it and changed the oil and after several oil changes I have never seen the oil so clean even at change time.
Kgmz is online now   Reply With Quote
Old 01-26-2008, 12:33 PM   #12
dkillianjr's Avatar
Plazaman, if changing your oils the problem, I would also switch oils too either to amsoil, which I have heard is real good stuff or some other manufacturers also now make oils with extended change intervals. One word on the synthetic, I changed to synthetic oil in my one car just for the heck of it and every seal and just about every seal and gasket leaked. Needless to say I swithed back to regular.
Old 02-15-2008, 09:42 PM   #13
plazaman's Avatar
i bought an engine flush and the seafoam. How does that seafoam stuff work? How would i use it as a engine flush?
Cutting floor joists flush to a wall- preferred tool? Dustball Framing 20 01-29-2008 10:28 PM
Champion flush problems anyone? dkillianjr Plumbing 3 11-15-2006 08:01 PM
Engine loosing oil? denick Excavation & Site Work 23 10-08-2006 01:08 PM
How to dissolve sludge Browny Plumbing 4 06-14-2006 08:44 PM
Removing stain from a french door or replace? Mike F Painting & Finish Work 6 03-22-2004 10:46 PM
Contractor Talk™ © 2003 - 2010 The Building Network LLC
