Charitable animal
Trade: decks
Electric Trailer Brake Controllers
Im looking for some solid feedback on pros/cons of timed and inertia electric brake controllers. I hate mine, I have a drawtight timed controller, and I am constantly F&*King with it, brakes to hard, brakes to light, excessive wearing on shoes, always adjusting the shoes. Little backround, 5x10 wells cargo with a single 5200# torflex axle. It is a small trailer which for the most part is relatively light when loaded. I primarily needed that axle and brakes for when I put the mixer and mini loader in. so other than mobing and demobing those items don't ride everywhere the trailer goes. I initially leaned torward an inirtia unit, but I suspected that they have quirks too (level mounting, vehicle position relative to level, non braking related differences in inirtia etc)I feel as though the trailer brakes are not applied proportionally to tow vehicle braking and is the cause for the excessive wear... what do you guys have, what works good, any and all input tia
Re: Electric Trailer Brake Controllers
Mine sucks too, Im looking forward to some good info here guys
I'm a big fan of the Jordan Ultima brake controller- http://www.bestbrakecontroller.com/
I've been waiting a while for them to get more in stock so I can put one in my new-to-me truck. I really liked the LED amp display. I could set the bias to a certain number for an empty trailer then change it to a certain number for a known trailer load. Example- empty trailer would be 1.2A (.3 amps per brake drum) and a loaded trailer with a 6k lb load would be 8A (2A per brake drum). This would get me maximum braking without actual tire lockup during panic braking. Last edited by Dustball; 12-02-2007 at 08:12 PM. |
#4 | |
Charitable animal
Trade: decks
Re: Electric Trailer Brake ControllersQuote:
I stumbled on this which looks like a killer setup too, anyone have one? |
Trade: General Remodeling
I have the Tekonsha Prodigy. Well worth the money. Allows quick adjustment for different trailer loads. Digital display makes it easy to get back to the setting you need. It also the the brake spike feature that will spike the trailer brakes to a set level when braking is initiated. http://www.tekonsha.com/prodig.html
http://www.wolffhomerepair.com " Of course I don't look busy, I did it right the first time " |
#6 | |
Charitable animal
Trade: decks
Chief Toilet Mover
Trade: Bathroom Remodeling
I have a Prodigy in my F150 for hauling a 6000-7000 lb tandem axel tailer. Not sure what the model is, but it's the one that does it all automatically and you can program it. Whichever model it was, it was the expensive one, the cheaper one was too manual, you had to mess with it all the time. I've never touched this one, it just does it's thing.
Sounds like I have the one Wolf has. |
Trade: General/Remodeling
I have the Jordan and it is the smoothest controller I have ever used. It is easy to adjust and feels safe. It receives commands via a cable connected to the brake pedal.
Mike
Mont Vista Company, LLC Alpine, Apache Junction, Gold Canyon, and Mesa, Arizona Apache Junction Builder Gold Canyon Builder |
#9 | |
Any controller I have every used only applies brakes upon the brake pedal being pressed. If you downshift or just let off the gas there are no trailer brakes applied.
#10 | |
Charitable animal
Trade: decks
makes total sense, first and foremost my timed unit has got to go Now, these inirtia units,(which I initially leaned torwards) look good in theory, do they proportionally regulate voltage going to the brake magnets? what about backing up??? the more feed back, pros, cons etc the better, I want to hear it all before I change it once and for all tia gotta admitt though , that jordan unit and the other one I stumbled on seem to be designed well
Custom Decks & Carpentry LLC. Chester County Custom Decks Custom Deckbuilder Mainline Philadelphia Deck Builder Custom Decks & Carpentry on Facebook Last edited by Bone Saw; 12-03-2007 at 02:33 PM. |
The one issue I know of with the Jordan is routing the cable. You have to mount the unit where it'll route the cable with as minimal of a bend as possible. Too sharp of a bend and the cable won't slide smoothly.
I'm a Mac
Trade: ICF Construction
Have pulled 22000 lb triaxle 5th wheel with my chev 3500 and a Prodigy, easy to use and set up. Don't recommend pulling 22000 lbs daily little nerve racking.
Chris |
Tekonsha Prodigy is what I have in my dump truck and my pick up truck.
Pulling a 9 ton and 7 ton trailer. I have gotten good service from them, very reliable, and adjustable to varying loads easier than any I have used before. I have no experience with the Jordon controller talked about above, but looking at the site, and seeing how it works, to me, it seems that you would have excess wear on the pulling vehicles brakes. Which for me are much more expensive than the trailer brakes. |
Charitable animal
Trade: decks
2 for jordan
4 for prodigy anyone want my drawtight I'm getting a prodigy |
The prodigy works in reverse also.
Another vote for the prodigy. I use it for my 16ft car trailer with 5000lbs of 4wd truck on it. I tow with a half ton Chevy still loaded full of tools. Works great.
Charitable animal
Trade: decks
thanx ranger and the rest for your input, Im sold on the prodigy. Now I contacted the dealer that I got the trailer and controller from, and they don't have a problem taking back my 5 month old unit for store credit, but they dont have the prodigy, they have this instead looks to be the same thing, think this one is equivelent to the prodigy, or should I eat mine and go get a prodigy??? tia
Custom Decks & Carpentry LLC. Chester County Custom Decks Custom Deckbuilder Mainline Philadelphia Deck Builder Custom Decks & Carpentry on Facebook Last edited by Bone Saw; 12-05-2007 at 05:36 PM. |
#18 |
Chris
I gotta say that unit looks just like my prodigy. Mine is 4 years old so it looks different then the prodigy now but that intella-stop is a dead ringer for mine.
#19 |
Charitable animal
Trade: decks
this controller ROCKS!!! thanx
#20 |
The Deck Guy
I have a $99 timed controller because I wanted a Prodigy and no one local had it in stock, and two installers talked me out of it saying I really didn't need the inertial controller.
The timed controller works OK for pulling my 10k dump trailer. I've never had it fully loaded. Maybe 7,000 lbs max so far. I know empty I set it on "2" and the most I've had to set it up to is "3.5". It goes up to 10! The only thing I notice is that when I come to a slow stop the trailer brakes sort of slam the truck forward if I take my foot off the break right before I come to a stop. I am not a trailer junkie, so I don't know if there's a remedy for it.
| Let's discuss the van trailer thing again | JPV123 | Vehicles | 21 | 12-23-2009 02:07 AM |
| Enclosed trailer suggestions | Wellcraft | Tools & Equipment | 49 | 03-03-2008 09:03 PM |
| Electric in my trailer | STUMPFOOT | Vehicles | 21 | 10-08-2007 08:20 PM |
| Electric Brakes on Trailer Question | plazaman | Vehicles | 5 | 08-06-2007 09:49 PM |
| Trailer Electric | pruane | Vehicles | 9 | 01-13-2007 08:59 PM |
