Trade: painter
Electric In My Trailer
I would like to put an electrical outlet in my trailer, you know something I can plug an extension cord into on the outside and have electric on the inside. Is there a kit for this or do you have to peice that togethr from a hardware store?
Remodeler
Re: Electric In My Trailer
This is how I did it.
http://minichillosconstruction.com/trailer/trailer.htm |
#3 | |
Fentoozler
Re: Electric In My TrailerQuote:
![]() get into here: ![]() Did you cut the back of the boxes out or something? ![]() The trailer walls don't look more than an inch thick.
Remodeler
Yes with a hole saw. If I remember correctly the outside receptacle has a punch out in the back. The inside one I drilled. And yes the trailer walls are a bit over 1" thick. That is the reason for the 1/4" plywood behind the inside box.
Trade: Residential Remodeler
Great job and pictures. I am in the process of sittting up my new trailer. Did you attach the ground wire to the trailer?
Fentoozler
What kind of wire is in the PVC pipes?
Trade: Squirrel Handler
I'm betting it's electrical wire.
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
Doofenshmirtz Evil Inc.
As aposed to what....water wire?
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber |
No, as opposed to non-electrical wire like speaker wire (I have seen this), phone wire, etc
Fentoozler
The question goes deeper than "electric wire" ....but how would you know that? All wire carries electricity, right?
Let me ask a more precise question....what type INSULATION is on the wire? ..and electrically insulated ain't the right answer.
#11 | |
Trade: General/Remodeling
Mike |
Fentoozler
I'll give you a hint...it ain't "building wire".
#13 | |
Re: Electric In My Trailer |
Remodeler
For those who really care. I generally have 12-2 romex around and that is what is in the PVC pipes. And I did not run the ground to the trailer chassis in my mind it might electrify the trailer if there was a problem. MD?
#16 | |
There isn't anything in the NEC that would specificly apply to your tool trailer, but this is a requirement for mobile homes, RV's and such. Same idea applies to your tool trailer. |
Remodeler
Thank you MD. I guess I was relying on the GFCI too much. I will add the ground to the chassis.
#18 |
Well, crap... I forgot you had a GFCI. Yeah, as long as the fault is on the load side, you're protected. If the fault is somewhere else, like in the shore power cord laying on your fender or draped across the tongue on the way to the inlet, you're not protected. In most scenarios, the GFCI would help you out. In a few, only the bond wire will protect you in that situation. Rightfully, the shore power cord should be GFCI proteted where ever you have that plugged in at, but I think that probably doesn't always happen.
#19 |
Remodeler
I never drape the cord over anything. It allways runs on the ground to the trailer and up the wall to the plug. I think I will add the ground anyway if it is the proper way to do it. I might sell the trailer someday and the next owner might not be as carefull as I am.
#20 | |
| Trailer: Customizing ideas needed. Long | Robie | Vehicles | 195 | 11-06-2011 11:32 AM |
| Let's discuss the van trailer thing again | JPV123 | Vehicles | 21 | 12-23-2009 02:07 AM |
| trailer security | ApgarNJ | Vehicles | 10 | 10-18-2007 11:05 PM |
| Electric Brakes on Trailer Question | plazaman | Vehicles | 5 | 08-06-2007 09:49 PM |
| Trailer Electric | pruane | Vehicles | 9 | 01-13-2007 08:59 PM |
