Duramax Or Cummins?
Old 12-30-2017, 12:51 AM   #1
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Rewards Points: 4,434
Send a message via AIM to Michaeljp86
Duramax Or Cummins?
Im planning on getting a new to me used pickup this spring or summer. Ive always been a GM guy and always had good luck with them.
Dodge owners are always bragging about how awesome their cummins is and I made the mistake of buying a dodge. Ive got more money into that thing then I can ever get out. But since I have a family now I need to cut my losses and get a extended cab or 4 door.
So Im leaning very heavily towards the duramax but Ive never owned one. The few people I know who have only say good things but so did the cummins guys.
Ive been kinda looking around and came across a dodge that someone put a different bed on so it looks goofy but otherwise a clean looking truck and Ive been thinking about a utility bed so the price may be right. But Im not sure I want to risk buying another dodge.
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 12-30-2017, 09:11 AM   #2
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,092
Re: Duramax Or Cummins?
What years? That's a big thing with used cummins or Dmax.
I just got this. They are brining stupid money for 20 year old trucks.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Jaws (01-02-2018)
Old 12-30-2017, 09:30 AM   #3
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,022
The engine is probably the last thing to give you grief on these trucks. I'll never forget my friends 2006 Duramax which was brand new... constant stream of problems, changed every part of the engine under warranty including injectors... eventually found out it was a bad wiring harness after a year of chasing ghosts.
Sent from my Nexus 6P using Tapatalk
Inner10 is online now
Old 12-30-2017, 09:36 AM   #4
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 1,636
sausage smokers, not a fan of any of them.
kirkdc is offline
Old 12-30-2017, 10:21 AM   #5
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 278
Front suspension on the dodges are not good ,seems like guys are always rebuilding them. And new ones seem to have enough injector problems too. Duramax they says you want to use good , like OEM , fuel filter to keep the fines out of the injectors which kills them. Also IMO it seems like when guys start chipping the diesels to much that is when the problems start showing up.
Randy Bush is online now
Old 12-30-2017, 10:27 AM   #6
I like Green things
Dmax injectors are 800 each.
Cummins are still the cheapest engine to work on compared to dmax or psd.
The new 6.7psd is over 400hp and really close to 1000 ft/lbs. Of torque.
Crazy.
Warner Mill Works
Facebook
YouTube
Old 12-30-2017, 11:07 AM   #7
EVIL GENIUS
Crazy.
The reason I bought my dodge is you can get around that much torque with less then $1000 in modifications and it supposed to improve fuel economy.
It might be a great engine other then its always leaking oil but the rest of the truck is poorly built compared to my gmc.
U.S. Coast Guard
Old 12-30-2017, 11:36 AM   #8
I like Green things
I have a buddy that bought a 97 3500 4x4 dodge dually, 12 foot flat bed and a 5spd.
He put one clutch in it and rebuilt front end twice in 450k miles. Sold it for 4k last year.
It is a lot of engine in any pickup truck.
You don't want a 53 block, and the 02s had a poor fuel pump.
Warner Mill Works
Facebook
YouTube
Old 12-30-2017, 11:58 AM   #9
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,710
Sadly, I have an '08 Ram 3500. The Cummins is a great engine, been in big-rigs for years.
The problem is Dodge. They are just not made for working with. Already burnt up a tranny, and the guy at the Dodge specialist shop said that's just what they do. Forever. There is a RevMax tranny that is supposed to be bulletproof. Only $5,500.
Oh, and google "Ram TIPM". I'll let you discover that issue.
As it sits now, if you don't have to worry about emissions, like we do here in California, you're probably best getting an old, pre-emissions diesel, or a new, i.e., Ford, gas engine. You can get a 6.2 gas with a 4:30 rear-end and tow 15K with a Ford.
There is a reason nearly every fleet in this country uses Ford. But the PSD is junk as well.
Delta
I have an Edifice Complex.
Old 12-30-2017, 12:19 PM   #10
tjbnwi's Avatar
Rewards Points: 972
Delta
The PSD in my 2000 Excursion has 350K on it. Still going strong.
tjbnwi is online now
Old 12-30-2017, 01:00 PM   #11
I like Green things
The 7.3's were basically a 500k mile engine. The 6.0s were great if you dumped 6k into them, the 6.4s were junk. The new 6.7 seems to be a pretty rock solid platform.
Warner Mill Works
Facebook
YouTube
Seven-Delta-FortyOne (12-30-2017)
Old 12-30-2017, 01:04 PM   #12
I like Green things
Delta
Until they switched to the Japanese unit, the autos could never last behind that engine. Been going on since 1990.
The 5k built transmissions are worth it.
Warner Mill Works
Facebook
YouTube
Old 12-30-2017, 02:48 PM   #13
Trade: Builder/GC
Yea, the 7.3 was great. My first diesel was a 7.3. I had a lot of glow-head issues with mine, but other than that it was great.
I had 6.0 that was studded and deleted. It was good I guess, but holy s#!t it was expensive. $2,000 for a HPOP. Grand for a Hydro-Boost. Etc....
If I keep this rig, I'll get one of those. I just got the rebuilt, and the way I drive, I'll prolly get 200K out of it.
If I win the Powerball, I'll get this. Just in Fire-Engine Red.
Pearce Services (12-30-2017)
Old 12-30-2017, 02:58 PM   #14
BattleBornNV's Avatar
Trade: General contractor
Rewards Points: 136
I just traded in a ‘14 RAM 2500 with the 68RFE tranny at 104k miles. Turbo blew apart at 98k, covered by Cummins thankfully, then water pump supernova’d @ 101k. Tranny started slipping pulling my toy hauler at around 60k.
The emissions system was to blame for the turbo. They said I didn’t use it “hard” enough. Guess I should have just kept the 5th wheel hooked up to it full time. Whatever.
So now I have a ‘17 RAM 3500 with the AISIN tranny. It’s a MONSTER. I bought the super warranty and as soon as its expired the entire emissions system is getting deleted.
Every diesel specialist I know has all but guaranteed 500k out of this truck once that is gone.
BattleBornNV is offline
Old 12-30-2017, 03:09 PM   #15
Trade: Builder/GC
Yep.
I can do a DPF and EGR delete, but I have to buy the stuff out of Oregon. Of course, it needs a tuner as well, or it will go into "limp mode".
Problem is, if I decide to dump it, I can't sell it in Cali with the delete, so I'm kind of in limbo right now.
Just got it back yesterday, another $2,000 in electrical repairs.
Delta
Old 12-30-2017, 03:26 PM   #16
Lettusbee's Avatar
Rewards Points: 1,592
I've had a lot of Cummins and Powerchokes over the past 25 years.
The only way I'll operate a modern diesel is buy it brand new and spring for the extended warranty. I have 44K on my 2015 Ram and it is fully warranteed until 150K. I have no intention of modifying anything on this ever.
If I was going used I'd stick with the older and simpler ones. If you need a crew cab then that limits you to Chevy and Ford. It seems that the mid 2000s and newer trucks in all makes were having growing pains trying to accommodate the newer emissions requirements.
I wish I'd kept my '02 Ram. It was a real work truck. I did have to do a lot to the front end, but once it was dialed in it didn't give me any further trouble. I traded it in at about 162K, 6 spd with original clutch. I never trusted an auto tranny until the most recent Ram trucks.
Lettusbee is offline
Old 12-30-2017, 03:52 PM   #17
Rewards Points: 136
Yep.
Delta
I’m a Dodge loyalist.
This new one is my 7th. The one I traded in for the ‘14, an ‘06, I should have never gotten rid of. That was the best one I had ever owned, including up the one I have now.
Compound turbos, suncoast tranny, stacked tuners, banks intercooler, injectors, pump, 5” exhaust from turbos back, cat delete... it would gaptise a Z06 stop light to stop light and not puff an ounce of black smoke. Also never broke a single part. Ever. Not so much as a fuse. Not to mention 25 MILES TO THE GALLON, 18 TOWING MY 18k# TRAILER. Seriously. I could kick the chit out of myself for getting rid of that
Edit: Worst interior ever, parts did break inside. Rode like a granite counter top, not lifted whatsoever. Would rattle your kidneys out. Crew cab short bed 4x4.
Old 12-30-2017, 03:57 PM   #18
Trade: Builder/GC
That's interesting. I thought the mid-'00 had all kinds of drivetrain issues, no?
Delta
Old 12-30-2017, 04:06 PM   #19
Rewards Points: 136
Delta
Mine was the tranny. But that was completely my doing. I put it in the shop with 35 miles on it and had my performance guy start on the motor. The tranny took a beating. Ended up turning the underside of my truck into a salvage yard at a stop light brake boosting to race a new GTO. $6500 got me a suncoast and a billet torque converter.
That truck put 930hp/1450ftlbs to the tires. If there was another weak link, I’m sure I would have found it. Maybe I got rid of the weak stuff early and saved the life of parts down the line?
Add:
What is absolutely nuts to me now is my new truck with the AISIN is 400/900.... with no power adders. That’s absurd.
The Following User Says Thank You to BattleBornNV For This Useful Post:
Old 12-30-2017, 05:23 PM   #20
EVIL GENIUS
Thats what I like about my cummins, its very easy on fuel if I stay off the highway. The downside is everything on the truck is cheaply built like the transmission cooler lines as thick as a pop can. And it will knock your teeth out if you hit a pot hole.
U.S. Coast Guard
I could use some insight on a 6.6 Duramax Diesel utility service van bretth0214 Vehicles 27 10-14-2012 07:56 PM
2007 GMC 2500 Duramax Buckeye Don Contractor Swap 2 07-05-2012 09:23 PM
6 liter vs duramax fshrs1 Vehicles 89 11-04-2011 06:11 PM
2005 gmc duramax for sale kevin332 Contractor Swap 3 07-14-2010 05:02 AM
