Cracks In Tire Sidewalls
Old 05-23-2012, 07:33 PM   #1
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
I did a thorough spring cleaning on my trailer today. I noticed that both tires one one side have small cracks in the sidewalls.
What causes these cracks? And why only on one side of the trailer?
Strange.
Obviously I'll have to replace them, but I'm wondering what causes this. Weight seems to be evenly distributed in the trailer.
Thanks.
katoman is offline
Old 05-23-2012, 07:39 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 478
Re: Cracks In Tire Sidewalls
Orientation to weather & the sun...
griz is online now
Old 05-23-2012, 07:42 PM   #3
katoman's Avatar
Trade: carpenter
I guess I should get covers for them if they're going to sit in one spot for a time. Sometimes the trailer is on a site in the same spot for a few months.
katoman is offline
Old 05-23-2012, 07:45 PM   #4
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Strange.
Thanks.
It's pretty common. I wouldn't be too worried about them unless they are really bad. Putting tire coatings on when you wash your car helps but the best thing for the tire is to do miles. There's oils in the rubber that protect the tires when in motion but when the tires stop they don't force the oils from the rubber so they dry out and crack. As Griz said sun also takes its toll on the tires if they face the sun most of the day and don't move.
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
Tom Struble (05-23-2012)
Old 05-23-2012, 07:47 PM   #5
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,126
its most likely dry rot through lack of use
Anderson is offline
Old 05-23-2012, 08:07 PM   #6
katoman's Avatar
Trade: carpenter
It may just be from lack of use. It sits for long periods. Anyone know of a good conditioner for them?
I use that tire spray foam. Maybe there's a better product.
katoman is offline
Old 05-23-2012, 08:19 PM   #7
Trade: Construction
I spotted using the foams as they seemed to dry the tires out faster than not using them. The ones that are more of a gel seem to work better. I'm trying the new turtle wax stuff they bought out. Been on the tires for over 2 months now and they still shine like new. You don't have to reapply them each time you wash your vehicle. Just wash the tires and the stuff looks like you just applied it. Meant to last 3-4month between applications but no idea if it helps them stop cracking I would hope it does for the price it costs though.
This was the other day after washing. The tires still look that nice even after I applied that stuff over 2 months ago. Plus it don't fling all over your paint work after it drys. Stays dry to the touch after 2 hours.
That's the stuff on the right.
katoman (05-23-2012)
Old 05-23-2012, 09:35 PM   #8
tgeb's Avatar
Rewards Points: 632
This from an article I saw today.....
http://www.trucker.com/CMS.aspx?sect...ge=PROBLEMLESS
While age will always be a factor in determining the service status of a tire or casing, there are so many other variables that must be considered. Perhaps the most obvious is the physical condition of the rubber. When tires are not used for extended periods and directly exposed to ozone and ultraviolet (UV) light, they go through a natural process called “weather checking.” As long as the damage doesn’t extend to the body or belt plies, it may be purely cosmetic and pose minimal risk to the driver if the tire is properly inflated and not overloaded.
I recently sat down with an engineer from a tire manufacturer to discuss the subject of tire aging, and we laughed about the recreational vehicle snowbirds who insisted that they purchased a bad set of tires because the “sidewalls were all dried out.” Of course, they usually leave out the fact that the “dried out” tires were facing south for months and the vehicle was never moved, but that doesn’t stop them from demanding a refund. When tires are allowed to sit out in the sun for extended periods of time, ozone and UV damage is unavoidable.
Likewise, the periodic use of many tire dressings and sidewall conditioners can have an adverse affect on the condition of the rubber. The majority of tire companies will say that the best way to preserve the appearance of a tire is to use it regularly and keep it clean, properly inflated, and out of the sunlight when it is stored for more than a few weeks. It’s also important to note that sidewall paint applied during the retread process will help preserve the appearance to some degree, but it cannot reverse the natural effects of tire age.
Seems there are some things you can do to minimize the damage, but probably your tires will be fine.
www.gebcon.com
tgeb is offline
The Following User Says Thank You to tgeb For This Useful Post:
Old 05-24-2012, 06:14 AM   #9
General Contractor
greg24k's Avatar
Rewards Points: 7,258
Kato,
When I owned a junk yard in my younger days, we would stack tires up in the shade or cover them to keep the sun from beating on them, because UV rays and other elements break the rubber down, causing "dry rot".
I have a few friends with dealerships, they use 303 Aerospace Protection Spray on tires during winter months, this stuff is good for exterior covers covers, convertables, etc.
greg24k is online now
Old 05-24-2012, 07:48 AM   #10
ESSaustin's Avatar
Trade: Hauling/trucking
Rewards Points: 384
I own a bunch of trailers, and make sure I spray tire foam on them once in a while. Not only do I spray the side wall, but also the tread that is exposed to the sun. I do not have any rot problems.
ESSaustin is offline
Old 05-24-2012, 08:57 AM   #11
NHCremodeling's Avatar
Trade: Residential Remodeling
Rewards Points: 75
Check to see how old your tires are. You can buy "new" tires that may have been sitting around for years.
http://www.tirerack.com/tires/tirete....jsp?techid=11
NHCremodeling is offline
Old 05-28-2012, 07:43 PM   #12
TimNJ's Avatar
Rewards Points: 2,470
This is a common problem on RV's, camper trailers. The bad part is you can have a "new" set of tires and if you carry a load that is close to max most of the time, that's when that "new" looking tire will blow out and usually take parts of your camper with it.
A lot of RV'ers change their tires at a certain age point regardless what the tread looks like.
TimNJ is offline
Old 05-30-2012, 05:14 AM   #13
Big Shoe's Avatar
Rewards Points: 1,748
Ditto
Expect the Unexpected
Big Shoe is offline
Hairline cracks on conrete walls sparksfly Masonry 9 08-15-2011 08:01 PM
Has anyone ever repaired cracks in commercial masonry cladding panels tbrown2963 Commercial Construction 10 11-02-2010 11:05 AM
Cracks in a two day old driveway Katchlight Masonry 1 07-13-2010 10:11 PM
Wood Cracks or Checking go_hercules Historical Restoration 3 04-07-2010 06:48 PM
concrete stairs with sidewalls bop101 Masonry 3 08-25-2009 04:31 PM
