Concrete Nailer At Frozen Bolt?
Old 12-22-2016, 04:36 PM   #1
tipitop's Avatar
Trade: carpenter
Rewards Points: 2,635
I post here as it can be related to my trade for sure and I can use that trick in trade, if would survive. Lower bolt of my rear strut at small car is frozen. Head fall of, I removed nut and only shaft (about 5" long) is frozen in. I tried to spray it, heat it, and of course slam it with small sledge hammer. However there is not enough space to slam it hard. I taught about using demolition hammer, compact one at bolt but do not think it can slam better then me. Must be small one in not big space. Today I come at idea to put top of the bolt shank in my Remington barrel, load cartridge and shoot. Bolt shank is protruding like 1" at one side.
I worry about it at multiple level. First it will be much stronger hit for gun then standard concrete nail. Second I worry gun or bolt can explode from impact. Would definitely protect face with playwood but my hand would be exposed to shrapnel. I worry that impact can broke my hand or wrist.
Do anyone try something like that ever? Basically gun against bolt.
tipitop is online now
Old 12-22-2016, 04:38 PM   #2
tipitop's Avatar
Trade: carpenter
Re: Concrete Nailer At Frozen Bolt?
I just figure out when I asked about some danger business that it is post nr 666. F this world.
Edit would not do. To many unknown. Concrete guns are enginereed to shout concrete nails in concrete (through green). Even Remington engineers would not know what can happen.
Old 12-22-2016, 05:06 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 12
don't do it....
read here....http://www.contractortalk.com/f11/wh...ts-job-315498/
griz is online now
Old 12-22-2016, 05:08 PM   #4
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 80
Hold my beer and watch this...
Sent from my SM-G900P using Tapatalk
TxElectrician is offline
The Following 5 Users Say Thank You to TxElectrician For This Useful Post:
dayexco (12-22-2016), Deckhead (12-23-2016), hdavis (12-22-2016), RedAdobe (12-26-2016), SmallTownGuy (12-22-2016)
Old 12-22-2016, 05:17 PM   #5
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,045
Personally, I would try a mechanic.
But I do admire your out of the box thinking.
Easy Gibson
Warren is offline
Old 12-22-2016, 05:34 PM   #6
tipitop's Avatar
Trade: carpenter
Do not know it that two "Myth busters" guys are in business. They would like to check it for sure.
I did sent email to "Myth busters". Shade tree mechanics world wide will tanks me if it work.
Old 12-22-2016, 05:44 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 154
Get in touch with "Crazy Russian Hacker" on Youtube. You guys are made for each other.
Tinstaafl is online now
Old 12-22-2016, 05:48 PM   #8
Mordekyle's Avatar
Rewards Points: 2,458
Are there threads in the knuckle? Are you trying to push it through but there are threads behind where the lock nut was?
You might have luck cutting a groove in the bolt with a cutoff wheel, and then turning the bolt with a flat screwdriver (or impact)
You might also look it up on YouTube. That's where Cali Mike learned all about building decks.
Mordekyle is offline
The Following User Says Thank You to Mordekyle For This Useful Post:
hdavis (12-22-2016)
Old 12-22-2016, 05:50 PM   #9
hdavis's Avatar
Rewards Points: 1,735
So, you're proposing blocking the barrel of your Ramset with a bolt, hoping that the bolt will move on firing.
I wouldn't bet my life on that working, you're begging to have the Ramset explode.
hdavis is online now
Old 12-22-2016, 05:55 PM   #10
tipitop's Avatar
Trade: carpenter
There are not threads there just smooth shank. Rusted badly. My frend is shade tree mechanic entire life and wasn't capable do it. We heat it with propane, MAPP/pro (real MAPP do not exist anymore) and hit with sledge, nothing did work. I to know take car apart. Such things happen, it is not big dill, just need solve it. Probably find someone with oxy/ace torch.
http://www.partsgeek.com/hct3zp5-hon...ntrol+Arm+Bolt
Treads are out of knuckle and it is part of bolt that protrude out.
Old 12-22-2016, 05:57 PM   #11
tipitop's Avatar
Trade: carpenter
Yeah it is just that I'm thinking about. I guess Ramset is now name not Remington.
Old 12-22-2016, 06:01 PM   #12
tgeb's Avatar
Rewards Points: 90
I have used an air chisel with a blunt pointed bit to drive out frozen bolts, pesky ball joints, tie rod ends, and even unruly u-joints.
I would imagine a hammer drill set to hammer only with the right tool inserted will work also.
However thinking of your situation, if you have enough bolt sticking out you can add some washers and run the nut back on and it will pull the bolt out, add more washers/spacers and repeat.
You just have to be smarter than the bolt.
www.gebcon.com
tgeb is online now
The Following 6 Users Say Thank You to tgeb For This Useful Post:
Deckhead (12-23-2016), hdavis (12-22-2016), RedAdobe (12-26-2016), Rio (12-23-2016), Tinstaafl (12-22-2016), tipitop (12-22-2016)
Old 12-22-2016, 06:04 PM   #13
tipitop's Avatar
Trade: carpenter
Will try those in post #12 before risking my hand. Other bad thing that can happen if gun explode a shrapnel can brake through gas tank.
I'm glad I asked those question here rather then at Acura TL forum where nerds give advice.
Old 12-22-2016, 06:06 PM   #14
hdavis's Avatar
I've cut flats on them before, then used a socket, adjustable wrench, or vice grips. Spray, hammer, wiggle back and forth, repeat. If you can get it to turn, you can eventually get it out.
My machinist buddy would probably just drill it out.
TxElectrician (12-22-2016)
Old 12-22-2016, 06:09 PM   #15
Mordekyle's Avatar
Can you pull the whole strut and work on it on the bench?
Penetrating oil and time help.
Old 12-22-2016, 06:16 PM   #16
tipitop's Avatar
Trade: carpenter
Of course would work if would pull strut out with knuckle but it will not work.
http://www.justanswer.com/acura/3ccr...hits-bump.html
It is like 12 different rods there. Work smarter not harder definitely worth here.
Old 12-22-2016, 06:26 PM   #17
tipitop's Avatar
Trade: carpenter
That is really excellent idea. I can use 3/4 T bar with 3/4 to 1/2 adapter and 17mm socket. I can punch with big sledge hammer as t bar end will go out of wheel area.
Wery good to know that air chisel and rotary hammer can work to. Will try it but not soon as I do have to work during days currently. Will post here when will try it in week or so. But this yours tread is extremely helpful.
Basically I need bolt-washer technic just to move bolt 1/16. When it broke rust it will go out in any direction.
Old 12-22-2016, 06:30 PM   #18
tgeb's Avatar
Rewards Points: 90
Well, I don't understand what you said with the T bar and everything, but I hope it works out.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
Old 12-22-2016, 06:39 PM   #19
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 3,138
Famous last words of a red neck "watch this youall"
sunkist is offline
Old 12-22-2016, 06:42 PM   #20
tipitop's Avatar
Trade: carpenter
I have this bad ass.
http://www.sears.com/craftsman-18-in...Q&gclsrc=aw.ds
Used it with 6' steel extension bar and sledge hammer in past. Nothing can broke it.
Actually it is right at coin.
The Following User Says Thank You to tipitop For This Useful Post:
tgeb (12-22-2016)
Barn Water Heater - line frozen artinall Plumbing 16 01-23-2013 09:51 PM
stamped concrete losing its color in spots- TIGHTER MITER Masonry 18 01-19-2013 04:51 PM
concrete slab HUDSONVALLEYEXT Construction 4 06-04-2012 01:45 PM
Areosmith ct-90 concrete sub-floor nailer finaltouchfloor Flooring 0 11-12-2009 03:05 PM
