Wow, I personally beleive that it would not be cost effective to do that. Around here, you do not see that hoe part of the tractor off unless it was being repaired. The backhoes are sure cumbersome machines but are versitile. Some times in residential applications where it is tight, I will swing the hoe to one side or the other to access an area. Good luck on the adventure.
"The land of familiarity belongs to the dead."
"We're playing in the dirt BROTHER!"
www.macexcavating.com
