Astro Won't Start When It's Damp!
Old 09-07-2008, 07:56 PM   #1
Chris G's Avatar
Trade: Porch and Deck Builder
Every so often, after it rains, my Astro Van won't start. Turns over, fires for a second, and then stops. It's been going on for a year. I have had a full tune up with new wires, a new fuel pump and a new camshaft sensor. It's driving me nuts. Anyone else with a similar problem. My mechnic is pretty top notch and he doesn't know what to make of it, other than there must be an electrical problem somewhere.
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!"
http://www.vicporch.ca
Chris G is offline
Old 09-07-2008, 08:00 PM   #2
Steve
OCRS's Avatar
Re: Astro Won't Start When It's Damp!
Distributor cap?
OCRS is offline
Old 09-07-2008, 08:00 PM   #3
Chris G's Avatar
Originally Posted by OCRS View Post
Distributor cap?
Replaced it already.
Chris G is offline
Old 09-07-2008, 08:05 PM   #4
Steve
OCRS's Avatar
Had a car once that would do the same thing, turned out to be pin hole in fuel line. Short of that, fuel filter plugged?
OCRS is offline
Old 09-07-2008, 09:08 PM   #5
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
This may sound silly... but check your battery connections and your fuse box; a bit of moisture there can cause issues- I've had the same thing once upon a time with a Jeep..
~Matt
BreyerConstruct is online now
Old 09-07-2008, 11:06 PM   #6
kbsparky's Avatar
Trade: Electrical
Try this:
Remove distributor cap. Spray the insides with some WD-40. Replace cap. Will it now start?
kbsparky is offline
Old 09-07-2008, 11:17 PM   #7
dkillianjr's Avatar
Originally Posted by kbsparky View Post
Try this:
I had to do the same thing usually once a week on a car I used to have. I started with wd-40 then I found this stuff called wire dry. That was the only thng that fixed my non starting problem, I think I replaced every part on that car!
Chris, what motor is in your van?
dkillianjr is online now
Old 09-08-2008, 02:12 AM   #8
Handle It!
MALCO.New.York's Avatar
Try this:
That is the USUAL CULPRIT!!!!
WD 40 = Water Displacer, Lab (attempt, formula, clinical trial) # 40!
It IS NOT a lubricant!!!!
" WD-40 stands for Water Displacement, 40th formula. Larsen was attempting to concoct a formula to prevent corrosion, by displacing the standing water that promotes it. In the process, he arrived at a successful formula on his 40th attempt. "
"Typical uses of WD-40 in automotive repair include:
  • Driving moisture out of the high and low-tension electrical components of an internal combustion engine (e.g. cleaning and drying the inside of the ignition distributor cap) so that it will start, particularly on cold days. "
http://en.wikipedia.org/wiki/WD-40
Ultimate Wisdom---------
MALCO.New.York is offline
How to start your own plumbing & HVAC company? roullette Business 22 01-06-2012 12:28 AM
web site-Where to start? SES Constructio Marketing & Sales 15 09-06-2008 12:28 PM
penetrating damp from derelict neighbour markslostmarble Roofing 1 08-27-2008 06:30 PM
Penetrating damp from derelict neighbour markslostmarble Remodeling 1 08-27-2008 06:29 PM
Penetrating damp from derelict neighbour markslostmarble Masonry 2 08-27-2008 06:28 PM
